Re: 470 dry sump engine on the dyno
[Re: AndyF]
#2278295
03/29/17 01:13 PM
03/29/17 01:13 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
So you won't be giving anyone a real world test to go by. I'd bet 99% of people reading about this test will use an out of the box intake if they were to use these heads.
Small heads w/ an expensive great flowing intake versus big heads w/ a crappy flowing intake. I'd like to see how much the bigger heads are worth over the smaller ones w/o having to make an assumption about the difference the intakes make.
[Re: justinp61]
#2278312
03/29/17 02:13 PM
03/29/17 02:13 PM
an8sec70cuda
Apples to oranges IMO. Realistically all you are doing is testing two engine combinations, no compairisons. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
[Re: an8sec70cuda]
#2278337
03/29/17 02:41 PM
03/29/17 02:41 PM
KOS
Small heads w/ an expensive great flowing intake versus big heads w/ a crappy flowing intake. I'd like to see how much the bigger heads are worth over the smaller ones w/o having to make an assumption about the difference the intakes make. 100% correct....whether its down on power or not your going to give it a fair comparison.the only way to do it is same manifold on both.
[Re: AndyF]
#2278365
03/29/17 03:38 PM
03/29/17 03:38 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Why not look at how each head works compared to the other, running the intake that most people would run for that port size? It doesn't make sense to me to do it any other way. The one thing I would do would be a port match, so each head/manifold COMBO is getting a fair shake on the dyno, and would be very representative of the way each head will be used.
[Re: RustyM]
#2278381
03/29/17 04:01 PM
03/29/17 04:01 PM
an8sec70cuda
I bet you could buy 2 new Trick Flow manifolds for less than just the port work on that one MP manifold from Wilson cost.
[Re: 70VcodeCoronetRT]
#2278385
03/29/17 04:05 PM
03/29/17 04:05 PM
Posts: 31,079 Oregon
AndyF
Andy, did you just have Wilson do their Competition porting on your M1? I'm looking at getting a 4150 version done. Thanks Yes it was the competition porting package. They added a lot of weld material on the outside of the runners in order to open them up to where they needed to be for a 470 inch engine.
[Re: RustyM]
#2278390
03/29/17 04:12 PM
03/29/17 04:12 PM
BradH
I have to wonder what the costs are in having intakes for both heads models and those port matched for each, not to mention dyno time.
I'll take a w.a.g. at about $1500 for what you described, including some (not all) of the dyno expenses.
[Re: AndyF]
#2278410
03/29/17 05:11 PM
03/29/17 05:11 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Andy ,Not wanting to hijack,but what is wrong with the Indy 400-3,400-2 ?
Thanks Charlie
[Re: CSK]
#2278476
03/29/17 07:19 PM
03/29/17 07:19 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We'll have our 270 heads soon...hope we don't go outside the usable rpm range of the hyd. roller cam with them.
Andy are you going to try the edelbrock Victor MW intake on the 270 heads?
Brian Hafliger
[Re: Brian Hafliger]
#2278504
03/29/17 08:48 PM
03/29/17 08:48 PM
AndyF
Andy are you going to try the edelbrock Victor MW intake on the 270 heads? I'm on a low deck so my Wilson prepped Super Victor will not fit. If that intake would fit then it is the one I'd use. (although the ports in that intake are larger than the small window ports that TF put in the 270 head)
[Re: CSK]
#2278507
03/29/17 08:55 PM
03/29/17 08:55 PM
AndyF
Thanks Charlie Just depends on your point of view. The average bracket guy can bolt it on and run just fine but if you're trying to squeeze power out of an engine they leave a lot to be desired. The port size is small, the plenum is poorly cast, etc. If you ever have the chance to compare an Indy intake casting next to a Trick Flow casting you'll see that Indy doesn't really put much effort into their pattern making. The plenum on my 440-3 is really sloppy. The cloverleaf pattern is uneven and the casting quality is kind of poor. On a high horsepower engine that uneven pattern is going to mess up the fuel distribution between cylinders. If you compare a raw Indy casting to an intake that Wilson has prepped you'll see a world of difference.
[Re: AndyF]
#2278525
03/29/17 09:33 PM
03/29/17 09:33 PM
CSK
Pattison Texas
Thanks Charlie Just depends on your point of view. The average bracket guy can bolt it on and run just fine but if you're trying to squeeze power out of an engine they leave a lot to be desired. The port size is small, the plenum is poorly cast, etc. If you ever have the chance to compare an Indy intake casting next to a Trick Flow casting you'll see that Indy doesn't really put much effort into their pattern making. The plenum on my 440-3 is really sloppy. The cloverleaf pattern is uneven and the casting quality is kind of poor. On a high horsepower engine that uneven pattern is going to mess up the fuel distribution between cylinders. If you compare a raw Indy casting to an intake that Wilson has prepped you'll see a world of difference. Thanks Andy, not much choice on the low deck max wedge, when I got mine had to open up the ports to MW, & clean up the plenum, but mine is mostly a street car. Thanks again.
