Re: Steering coupler research help - FREE coupler clamp for info
[Re: 135sohc]
#2280602
04/01/17 10:59 PM
04/01/17 10:59 PM
Posts: 12,431 Warren, MI
71TA
Warren, MI
79 B200 van, 3" coupler 85 B250 van also a 3" coupler.
Both were original 1 owner vehicles. Wow. I woulda guessed the longer coupler.
[Re: 71TA]
#2280608
04/01/17 11:04 PM
04/01/17 11:04 PM
71TA
Warren, MI
Heres an odd one. From a friend in New Zealand with a US 75 Ramcharger. Neither the 3" or 3-1/2" but an odd looking coupler.
So cool to have Mopar friends all over the world.
Also from the Moparts Truck Forum....
"Don't forget spline diameter, trucks were typically larger since most used Saginaw boxes. Trucks pre 80 or so tended to use Saginaw couplers vs the Mopar style."
Based on the info above that had a 3" coupler on a 79 truck, was the Saginaw coupler a 4WD thing or maybe pre 79 instead of pre 80?
[Re: flypaper]
#2280615
04/01/17 11:14 PM
04/01/17 11:14 PM
71TA
Warren, MI
74 challenger manual steering = 3 1/2 Thanks flypaper. Nudder one. From an older Moparts coupler thread. 86 Ramcharger. Looks like a 3" coupler like the post aove that said a 79 truck and 85 van had 3" couplers.
[Re: 71TA]
#2280671
04/02/17 01:03 AM
04/02/17 01:03 AM
Posts: 1,822 Colorado
denfireguy
Colorado
73 Cuda 3 1/2 inches, late November, 1972 build (black Friday after Thanksgiving to be exact) Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 71TA]
#2281390
04/03/17 09:28 AM
04/03/17 09:28 AM
Posts: 19,421 north of coder
moparx
i had a 74 power wagon with that type of coupler, [it's been gone since '83] and i thought it was an extra measure to insure the shaft didn't bind during any added flex when the cab and frame moved around during off road excursions ? i never had one of those apart however, to see what was inside. if you have a rag joint, the "common" type of coupler, and the one you show in your last pic, it should add quite a bit of movement before the steering shaft would bind up. does anyone happen to have a shot of the insides of one of those joints ? upon more reflection, that coupler might allow movement in and out to a certain degree ?
[Re: 71TA]
#2281850
04/03/17 09:31 PM
04/03/17 09:31 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
Both were original 1 owner vehicles. Wow. I woulda guessed the longer coupler. B vans are an oddity. A little bit of everything from all the parts bins. Just to add in, the vans also used the car steering box and not the saginaws found in most of the trucks.
[Re: 71TA]
#2282763
04/05/17 12:10 PM
04/05/17 12:10 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
73 Cuda 3 1/2 inches, late November, 1972 build (black Friday after Thanksgiving to be exact) My 73 was built in October. I need to check it because other 73 owners have said theirs are 3". Now I'm wondering what mine has.
