Re: 1970 440 HP Convertor Weights [Re: John_Kunkel] #2274879
03/23/17 04:40 PM
03/23/17 04:40 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Originally Posted By John_Kunkel
And not available. This is kind of like being on the last lap and running out of gas 50' from the finish line. John, thanks for digging this up. I may just post a wanted ad as this topic is going to come up again and it's nice to have another solution in addition to welding weights.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274974
03/23/17 07:57 PM
03/23/17 07:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OOPS. Didn't notice they were NLA.
Perhaps somebody who has a 10238 flexplate could make a tracing of the cutout and make it available so that the full-circle 10230 flexplate could easily be notched to duplicate it.
Re: 1970 440 HP Convertor Weights [Re: John_Kunkel] #2275060
03/23/17 10:55 PM
03/23/17 10:55 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
HAHAHA! John, great minds travel in the same gutters. grin
Re: 1970 440 HP Convertor Weights [Re: WO23Coronet] #2275123
03/24/17 12:43 AM
03/24/17 12:43 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By WO23Coronet
I thought the torque converters on forged crank 440's were all neutral balance, 6pack rods or not? I think the external balancing on 6 pack rod engines was done on the harmonic balancer
The 70 and up 440 large rod motors are eternally balanced at the harmonic balancer AND the torque convertor/flywheel
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2275134
03/24/17 12:59 AM
03/24/17 12:59 AM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
I found an NOS Mopar Performance set I had part #5249843. They are in the box with instructions that say they are for a 93 and newer Magnum that are 14 oz out of balance. It also states that the Non-Magnum 360 was 19 oz out of balance and uses #4120241. No mention of the 440.
Re: 1970 440 HP Convertor Weights [Re: Morty426] #2275135
03/24/17 01:00 AM
03/24/17 01:00 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Our engine is out at the moment, I can get some measurements in a day or so.
Joe
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2276599
03/26/17 04:46 PM
03/26/17 04:46 PM
A727Tflite Offline
A727Tflite  Offline
Here are a few pics - showing both 10238 driveplates. One with the weigth and one with the cutout - 180 degrees from where the weight would be. I'll post the tracing in a bit.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2276615
03/26/17 05:04 PM
03/26/17 05:04 PM
A727Tflite Offline
A727Tflite  Offline
more pics
Re: 1970 440 HP Convertor Weights [Re: A727Tflite] #2276883
03/27/17 12:16 AM
03/27/17 12:16 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Originally Posted By Transman
more pics
The 1.635" dimension, is that from the edge of the hole?
Re: 1970 440 HP Convertor Weights [Re: charge70] #2276886
03/27/17 12:18 AM
03/27/17 12:18 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Originally Posted By charge70
Bee,I have the drive train out of my 70 R/T at home.It's a 440 u-code car that still has the original motor and trans. I can take a pic of the face of the converter if you want me to.Let me know. John.
John, thanks for the pictures and dimensions of the converter weights. If I go this route, I definitely have enough information to do it correctly. Appreciate the help.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2276894
03/27/17 12:29 AM
03/27/17 12:29 AM
A727Tflite Offline
A727Tflite  Offline
6PakBee - yes - from the edge of the hole.
Re: 1970 440 HP Convertor Weights [Re: A727Tflite] #2277019
03/27/17 10:09 AM
03/27/17 10:09 AM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Thanks for the detailed sketch. If I can't get hold of one of the flexplates, I'm sure I can lay it out using your drawing.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2290315
04/18/17 10:58 PM
04/18/17 10:58 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Just to close this thread out, Transman has the machining capabilities to convert the B&M neutral balance 10230 flexplate to the external balance 10238. He did two for me and now I am set. Thanks so much!!
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2290496
04/19/17 11:13 AM
04/19/17 11:13 AM
an8sec70cuda Offline
Glad you got squared away!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1970 440 HP Convertor Weights [Re: A727Tflite] #3224985
04/04/24 11:54 AM
04/04/24 11:54 AM
MI, Livingston
P
plymth70 Offline
plymth70  Offline
P
MI, Livingston
Good information
