Re: Removable Parachute mount.
[Re: hemi-itis]
#2278252
03/29/17 11:50 AM
03/29/17 11:50 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I know it seems nit-picky, but is there a preference for having the anchor pin horizontal or vertical...I see it both ways.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: RMCHRGR]
#2278290
03/29/17 01:06 PM
03/29/17 01:06 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Bottom line Al, you need some sort of support bar with a tube sticking out the back for the chute mount. However you execute that is pretty much up to you. This is RVW's '64 Plymouth from B Bodies only. That is nice where you can pre fab the whole thing and then mount it.
[Re: hemi-itis]
#2278319
03/29/17 02:20 PM
03/29/17 02:20 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
My cars are in California right now. I will be there this weekend racing and will get some pics of that I have. The anchor point it tied tot he chassis and the cute pack themselves are on liteweight small diameter(3/8")moly tubing. This is what we use to mount the chute pack itself. Just attach it to the anchor point mount with pins. http://quartermax.com/single-parachute-mount-kit/
[Re: Al_Alguire]
#2278366
03/29/17 03:39 PM
03/29/17 03:39 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Here is mine. Slides in and out. Has a clevis pin similar to a trailer hitch receiver.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: actionange]
#2279235
03/30/17 11:57 PM
03/30/17 11:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I like your optimism about running 8s Al. But don't you think you should get the car down the track consistently first before spending on a chute? I've seen lots of cars running in the 8s with no chute as well as others with chutes that are never used. You can buy lots of fuel with what a chute will cost. Best of luck with your project. I agree.. I have a chute and only use it on a few tracks.. I prefer not to use it unless needed.. I hate packing it even if its so called "easy"
[Re: actionange]
#2280057
04/01/17 01:14 AM
04/01/17 01:14 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I like your optimism about running 8s Al. But don't you think you should get the car down the track consistently first before spending on a chute? I've seen lots of cars running in the 8s with no chute as well as others with chutes that are never used. You can buy lots of fuel with what a chute will cost. Best of luck with your project. The car is consistant.It goes consistanty faster every pass The track will see over 150 MPH and they will give you one warning.Have been almost 145 on pump gas.With the other mods that are being done 150 should be off the truck with a street driven heap.I follow in Freds footsteps in being an exibitionist and maybe some match race bandits
[Re: hemi-itis]
#2448483
02/08/18 01:35 PM
02/08/18 01:35 PM
Al_Alguire
Las Vegas
Its not a question of really how far. A lot of cars put them back a little bit to avoid the wheelie bars, wings etc. The spring will launch the pilot far enough to make sure it blooms you just don't want it caught up on anything back there. Don't angle it down for sure, slight upward angle and far enough to clear anything in the way easily. On the Vette it is MAYBE 4" from the body, never an issue with it...
[Re: hemi-itis]
#2449288
02/09/18 10:30 PM
02/09/18 10:30 PM
hemi-itis
Does the spring launcher get flush mounted or does it protrude from where the chute pack is mounted? Is the spring launcher that much better ????
