Re: Enclosed trailer wishlist???
[Re: MR_P_BODY]
#2276497
03/26/17 02:26 PM
03/26/17 02:26 PM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
Another thing I want is LED lights.. I am changing all my exterior lights this year since I have a light issue from when I bottomed out last year and screwed up the wiring I did all my interior 12V lighting to LED last year, and what a difference...I don't even need 110v lighting anymore.
[Re: dart440_72]
#2276501
03/26/17 02:28 PM
03/26/17 02:28 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Locomotion had a good list. I forgot as a "wish" list:
* Bogey wheels or skids help keep from dragging the tail on hills/dips.
And maybe some RV type jacks at the rear corners so you can load and unload without having the truck connected.
Adding to wish list, built in air tank(s) and maybe even an air compressor. The "portable" air tank is another item that takes up space, and is either in the way, or stored in a hard to get at place.
[Re: dart440_72]
#2276576
03/26/17 04:14 PM
03/26/17 04:14 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
Rather than install a winch, I bought a Warn Pullzall 24 v battery powered portable winch. It can be used on any of my trailers, or for many other pulling chores. I've been very happy with it. I just need to make sure the batteries are charged when I need it. https://www.amazon.com/885005-PullzAll-C...rn+pullzall+24v
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: dart440_72]
#2276577
03/26/17 04:14 PM
03/26/17 04:14 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
I would make sure it has the dovetail floor for easier loading and a good winch. The dove tail is probably standard now but it wasn't at one time ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) 16 inch 6000 lb.+ axles and 8 lug wheels 16 inch truck tires
[Re: dart440_72]
#2276643
03/26/17 05:54 PM
03/26/17 05:54 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I'll throw in. I needed a trailer that I could take my dogs and wife comfortably. I have never been okay with leaving the car in the trailer and being inside a hotel. I am worried the whole time. The power awnings are the only way to go, as the legs are very high when extended and you can drive right under. I wanted a side ramp door to put a golf cart in as well. On top of that, wanted a slide, full living quarters, dual A/C, full size shower, fridge, etc...Oh and it had to be all aluminum. I like the spread axle look, but is so hard on tires in tight maneuvers, so no spread, but 17.5" tires. Took a LONG time to find a used one in my price range, but did actually find one. Not the color I wanted, but can't have everything! ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_1094_zpsfs5zhiqw.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/Mobile%20Uploads/IMG_1108_zpsy7urwg5d.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/Mobile%20Uploads/IMG_1106_zps8vhraskt.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_1051_zpssdl3uhhi.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_1054_zpsz1xhor6u.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_1055_zpsuh79ubkc.jpg)
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: 451Mopar]
#2276651
03/26/17 06:17 PM
03/26/17 06:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Adding to wish list, built in air tank(s) and maybe even an air compressor. The "portable" air tank is another item that takes up space, and is either in the way, or stored in a hard to get at place. I've had a set of wheels/casters sitting here for 2 years but keep forgetting to weld them on.. I have a compressor on my 43' with the lines plumbed in.. I dont use the compressor all that much.. but its there ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2276656
03/26/17 06:31 PM
03/26/17 06:31 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I asked about bogey wheels and 3 different people said don't bother they hang to low and won't help out on my gravel driveway. They all suggested getting a piece of heavy wall pipe, cutting it in half, and welding it in areas that are issues. Mine being across the rear of my trailer because I back it down the hill and it levels off at the bottom.
[Re: pittsburghracer]
#2276666
03/26/17 06:49 PM
03/26/17 06:49 PM
MR_P_BODY
My 43' sits up higher than most so the boogies do work.. when I tore up the wiring it was on a very steep driveway coming out of a gas station that I figured I could do but I was way wrong.. I got so far then I had no choice but go forward and tore up the left corner wires.. the boogies would have worked then ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Hemi_Joel]
#2276714
03/26/17 08:10 PM
03/26/17 08:10 PM
Posts: 656 Florida
CJD AUTOMOTIVE
CJD, that is a splendid trailer! How long is the garage vs. the living area? Thanks! It has a 22' garage and 26' living quarters. The generator is in the front, under the gooseneck, so it's clear without a gen cabinet. It has overheads down the sides and shallow fronts. I was a little concerned about the garage, but honestly, it's nicer to have the larger LQ's. I do have to store a few things in the front if I have the golf cart loaded, otherwise, plenty big enough. I am more than willing to "work with it" considering what I paid. That's an old pic. Have since swapped out the TV's to flat screens and the sofa bed to twin recliners.
#2276717
03/26/17 08:18 PM
03/26/17 08:18 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I asked about bogey wheels and 3 different people said don't bother they hang to low and won't help out on my gravel driveway. They all suggested getting a piece of heavy wall pipe, cutting it in half, and welding it in areas that are issues. Mine being across the rear of my trailer because I back it down the hill and it levels off at the bottom. Now 4 people. They hang too low and get torn off. The rolling pipe is the way to go and can be tucked up tight.
[Re: CJD AUTOMOTIVE]
#2276744
03/26/17 09:16 PM
03/26/17 09:16 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
I have a 20 ft Haulmark, short but it fits in my driveway and my Dart fits fine. I like the idea of the interior led lights, Did you just change the 12V overhead bulbs? Part#s and were did you find them? Thanks
#2276761
03/26/17 09:37 PM
03/26/17 09:37 PM
Posts: 3,465 Back in NJ....
EWJ
Back in NJ....
I asked about bogey wheels and 3 different people said don't bother they hang to low and won't help out on my gravel driveway. They all suggested getting a piece of heavy wall pipe, cutting it in half, and welding it in areas that are issues. Mine being across the rear of my trailer because I back it down the hill and it levels off at the bottom. Now 4 people. They hang too low and get torn off. The rolling pipe is the way to go and can be tucked up tight. Got a picture of this set up?
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: dart440_72]
#2277299
03/27/17 07:02 PM
03/27/17 07:02 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
Thanks for all the words of wisdom!! This has been great!
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: dart440_72]
#2277699
03/28/17 02:06 PM
03/28/17 02:06 PM
11secdart
new jersey usa
Got them ( bulb # 1141 ) at Advance $20 a pair , Thanks for the idea!
#2277731
03/28/17 02:44 PM
03/28/17 02:44 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'll throw in. I needed a trailer that I could take my dogs and wife comfortably. I have never been okay with leaving the car in the trailer and being inside a hotel. I am worried the whole time. The power awnings are the only way to go, as the legs are very high when extended and you can drive right under. I wanted a side ramp door to put a golf cart in as well. On top of that, wanted a slide, full living quarters, dual A/C, full size shower, fridge, etc...Oh and it had to be all aluminum. I like the spread axle look, but is so hard on tires in tight maneuvers, so no spread, but 17.5" tires. Took a LONG time to find a used one in my price range, but did actually find one. Not the color I wanted, but can't have everything! Very nice. Anyplace I would go is 2-5 days and/or multiple events. I gave up on hotels looong ago. Motor homes are nice, but a truck with an LQ trailer makes sense for me. A vehicle that can be used for towing and also for transportation during the week or to leave the track if needed for supplies, go to dinner, whatever. The ATC units I've seen are super nice. Dealing with the DOT cops has become a big part of the equation over the last few years.
[Re: CMcAllister]
#2277762
03/28/17 03:37 PM
03/28/17 03:37 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Very nice. Anyplace I would go is 2-5 days and/or multiple events. I gave up on hotels looong ago. Motor homes are nice, but a truck with an LQ trailer makes sense for me. A vehicle that can be used for towing and also for transportation during the week or to leave the track if needed for supplies, go to dinner, whatever. The ATC units I've seen are super nice. Dealing with the DOT cops has become a big part of the equation over the last few years. Agreed. Wife likes those big toter homes, but not the most nimble thing for chasing a part, dinner, or grocery store! Besides, it would just sit. My pull truck is my DD. As far as DOT, mine is an RV ![cool cool](/ubbthreads/images/graemlins/custom/cool.gif) , which is why I really like the windows in the garage area.
[Re: EWJ]
#2277766
03/28/17 03:43 PM
03/28/17 03:43 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I asked about bogey wheels and 3 different people said don't bother they hang to low and won't help out on my gravel driveway. They all suggested getting a piece of heavy wall pipe, cutting it in half, and welding it in areas that are issues. Mine being across the rear of my trailer because I back it down the hill and it levels off at the bottom. Now 4 people. They hang too low and get torn off. The rolling pipe is the way to go and can be tucked up tight. Got a picture of this set up? I don't, sorry. Trailer is up against the fence! I just used a scrap piece of pipe with another slid inside. The inside piece has brackets on each end, that captures the larger piece, and attaches to the frame. If it bottoms, the long pipe distributes the load down the length into the frame and rolls to reduce friction against the asphalt or concrete.
#2277923
03/28/17 07:34 PM
03/28/17 07:34 PM
MR_P_BODY
I asked about bogey wheels and 3 different people said don't bother they hang to low and won't help out on my gravel driveway. They all suggested getting a piece of heavy wall pipe, cutting it in half, and welding it in areas that are issues. Mine being across the rear of my trailer because I back it down the hill and it levels off at the bottom. Now 4 people. They hang too low and get torn off. The rolling pipe is the way to go and can be tucked up tight. Got a picture of this set up? I don't, sorry. Trailer is up against the fence! I just used a scrap piece of pipe with another slid inside. The inside piece has brackets on each end, that captures the larger piece, and attaches to the frame. If it bottoms, the long pipe distributes the load down the length into the frame and rolls to reduce friction against the asphalt or concrete. On your set up is it riding on bearings or just loose pipe.. I understand the ground clearance.. I have seen that set up with loose fitting pipe.. I didnt care for it due to rattling and making noise ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2277946
03/28/17 08:05 PM
03/28/17 08:05 PM
Dragula
Well, the RV I had money down on, the guy just cancelled cause he wants his money next week.
I told him the house refi paperwork was all signed, but I still need 2-3 weeks to get thru everything...He ain't willing to wait that long and is sending my check back....I told him he was silly for thinking he is getting $30k from a guy he hasn't even met yet....
SOOOOOOO......I am back in the market looking at living quarter trailers and or whatever....What have you guys got?
