Page 2 of 3 1 2 3
Re: Header building Never again!! [Re: rowin4] #2276325
03/26/17 04:23 AM
03/26/17 04:23 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By rowin4
Originally Posted By cudaman1969
If I were doing them for a living there's a plastic tubing kit where there's a ton of curves and straights that snap together and make each tube (all four at one time). They come in different size tubes and allow for any bend and really look like a header when all snaped together, infinitely adjustable. They start at $245 and go up, no more guessing and trial fitting.
Isn't that the kit that you send in to have the pipes bent to there shape?
Ice engine works
"Dramatically simplify header and turbo manifold design and fabrication with these modeling blocks from Icengineworks! These blocks simply snap together to form header primaries that can then be duplicated by cutting and welding commonly available prebent U-bends and J-bends.
Included with each kit are both straight and curved blocks in a variety of radii. Each block represents a 1 inch arc length of tubing. Blocks of different sizes can also be connected to simulate stepped headers. Each block is molded with a series of markings and index points to make the transition to metal as easy as possible."
Re: Header building Never again!! [Re: Hemi_Joel] #2276394
03/26/17 11:33 AM
03/26/17 11:33 AM
E
earlymopar Offline
earlymopar  Offline
E
Hemi Joel is right. I worked with Schoenfeld when I made my headers and he regularly makes race-application only headers for small time groups like NASCAR & World of Outlaws. He has his own dyno and has proven that unequal length is often better. On one engine, he had runners that varied by more than a foot and it gave the best H.P. numbers on the dyno. He prescribes by the theory that rather than an engine being a set of cylinders working together, they are really a series of individual single cylinder engines working individually. Yes, you want them to work the same but equal length doesn't always equate to that. Bends are more critical. -EM
Re: Header building Never again!! [Re: JD Dart] #2276408
03/26/17 12:03 PM
03/26/17 12:03 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By JD Dart
Just finished doing a set for a friend of mine way too many hours and frustration to do this any more let more talent people do this.
His car was a hard one to fit the tubes into.
Very nice!
Re: Header building Never again!! [Re: voigtspeed] #2276415
03/26/17 12:18 PM
03/26/17 12:18 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Exactly. Its like cylinderhead porting. Its takes time and alot of work. Some people just dont get it.
Re: Header building Never again!! [Re: MR_P_BODY] #2276422
03/26/17 12:25 PM
03/26/17 12:25 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
Originally Posted By MR_P_BODY
Originally Posted By TRENDZ
Never again? That would be a shame. Looks like you did a nice job.
I agree... he knows how and nice welds
wave
Thank you and every one else for the kind words.
This felt more like a job and I wasn't enjoying it. Nobody will pay all the hours we have into making them.
Welding alone was 9hrs
Last set I made for mine had 2 to 3 welds per tube but being a chassis car was easy
Re: Header building Never again!! [Re: MR_P_BODY] #2276439
03/26/17 01:03 PM
03/26/17 01:03 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By toplescuda
Hot rod did a test (is a you tube videos of it) where they did back to pulls on a set of headers. Then took a hammer and beat a dent into a tube ....made a pull...more dents...a lot of dents. And I think was like a 6 or 7 hp loss. And the headers looked like junk
I watched that some time back.. I do have a
couple of questions on it.. first.. if a bented
up set of headers works just as well.. doesnt
that give you the idea that the area of those
were to large to start with.. second.. if that
held true.. why arent all the pro stocks beating
up there headers.. my opinion on that vid is they
were too big to start with.. but a lot of people
use to big
wave
They did a follow up episode, because so many people made that same argument. The Header Bash episode and the follow up Pick the Right Exhaust Header The results were interesting work
Re: Header building Never again!! [Re: JD Dart] #2276453
03/26/17 01:23 PM
03/26/17 01:23 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
thumbs Those headers look awesome! You have more patience than I.
72 Plymouth Roadrunner 11.08@123.25
Re: Header building Never again!! [Re: cudaman1969] #2276486
03/26/17 02:16 PM
03/26/17 02:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That is the Ice Engine works kit. Their full kit for one diameter size is around $1,500. That includes the $700 cutting jig.
http://www.icengineworks.com/
http://www.icengineworks.com/product-category/series/1750-series/
Re: Header building Never again!! [Re: 451Mopar] #2276712
03/26/17 08:04 PM
03/26/17 08:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yea, I was way off on the price, but I imagine they would make it easy for fitting in a tight chassis (440 in an a-body). There's a company that makes stainless steel headers for class cars and they start at $3500
Re: Header building Never again!! [Re: JD Dart] #2276765
03/26/17 09:43 PM
03/26/17 09:43 PM
MI
68shifter Offline
68shifter  Offline
MI
I just finished a set of ss B1-SB step headers for my brother. It's a lot of work, especiallly keeping all the stock front end stuff and working around a 4-speed setup in an a body. Came out nice and are at QC coatings getting done right now.
My brother and I still laugh because he bought a "builder kit" from Columbia river and they said was enough to build a set. I think I got through 2-1/2 tubes.lol. It takes much more material then you think and I didn't waste a single bend. We debated on an ice kit, then just put the Tig and chop saw to work.
Re: Header building Never again!! [Re: JD Dart] #2276812
03/26/17 11:01 PM
03/26/17 11:01 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Cutting and piecing together is the easy part, you just have to know how to cut angles. I made a angle chart on a piece of aluminum from 90 ,45 and 22 1/2 degree's, marked the angle I needed and cut.
Re: Header building Never again!! [Re: rowin4] #2276843
03/26/17 11:32 PM
03/26/17 11:32 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I built a set for my small block D50. And there is not much room at all under the hood of it and it has inner fenders. I would probably be faster if someone that knows what they were doing built me some. This was my first set I have built. I ordered flanges from TTI and 2 header kits for a small block Chevy from Summit.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Header building Never again!! [Re: JD Dart] #2276885
03/27/17 12:18 AM
03/27/17 12:18 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yeah lots of work, you have done a great job, just don't tell anyone smile . I made my own fenderwells, that was a lot easier than dealing with starters, torsion bars and inner guards.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Header building Never again!! [Re: JD Dart] #2276902
03/27/17 12:44 AM
03/27/17 12:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Header building is definitely an art.... Greg Holman at REF Unlimited in Kingman AZ builds them in a day. Make the appt, drop the car off in the am, by 2 to 4 in the afternoon he calls you to pick up your car. He does incredible work. Both of my engines have his pipe.
Re: Header building Never again!! [Re: JD Dart] #2277148
03/27/17 01:57 PM
03/27/17 01:57 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Tell someone 2.5K for a nice set of headers and they often look at you like you have 3 heads. Quality material and parts, keep them equal length within .5", make them fit, make them reasonable to get on and off, the handwork of the collectors and the inside of the tubes at the flanges, etc., etc. Any less and you are just doing it for a hobby.
Re: Header building Never again!! [Re: JD Dart] #2277157
03/27/17 02:15 PM
03/27/17 02:15 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
there are some very impressive skills floating around this place, in spite of the slight differences of opinion...mighty fine handiwork shown here.
Rich H.
Esse Quam Videri
Re: Header building Never again!! [Re: JD Dart] #2277175
03/27/17 02:52 PM
03/27/17 02:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My turbo headers I built followed by my A body Big Block headers.
Re: Header building Never again!! [Re: JD Dart] #2277253
03/27/17 04:52 PM
03/27/17 04:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm going to try building my first set for the Jensen. I actually bought the 1-3/4" Ice Engine kit, as I'm fairly sure I will be doing some for a few other cars.
If you seen my other posts, I'm looking at a tri-y setup, and right now, looking to make my own 2-1 "y" merges as the pre-built ones are sort of pricy. Hopefully the Ice kit will help reduce the amount of waste. It is supposed to help in ordering the number and type of bends?
I'll need some scrap to practice on. I want to try some with pulsed tig vs. regular tig.
Re: Header building Never again!! [Re: 451Mopar] #2277292
03/27/17 06:48 PM
03/27/17 06:48 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
We may to build a set also for a 392 Hemi first gen in a 57 Desoto Firesweep.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Header building Never again!! [Re: 451Mopar] #2277295
03/27/17 06:56 PM
03/27/17 06:56 PM
fresno ca
mikeysmopars Offline
fresno ca
I struggled with headers on mine and was ready to load up and take my pile to Arizona but I found a local guy that did some header work. The headers I had made for a low deck big block a body which was a challenge especially made as I wanted. I absolutely did not want in chassis headers which limits any header builder especially with 2 1/8 stepped to 2 1/4 primary. I notched my firewall to give him clearance and came out awesome but a little long which he said run them and we can shorten them if it hurts the HP. So far I've gained 60 foot and lost 1 mph.
IMG_20170208_180744931-800x600.jpgIMG_20170218_152802473_HDR-600x800.jpgIMG_20170129_172918486-800x600.jpg
Founder and CEO of the Central Valley Mopar Drag Pack
Page 2 of 3 1 2 3
