Page 1 of 3 1 2 3
Header building Never again!! #2276138
03/25/17 07:40 PM
03/25/17 07:40 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
Just finished doing a set for a friend of mine way too many hours and frustration to do this any more let more talent people do this.
His car was a hard one to fit the tubes into.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Header building Never again!! [Re: JD Dart] #2276141
03/25/17 07:46 PM
03/25/17 07:46 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I get looked at cross eyed when I say I wouldn't do it for 2 grand lol. I had 1/2 that much in material
Re: Header building Never again!! [Re: JD Dart] #2276142
03/25/17 07:52 PM
03/25/17 07:52 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I built my own, I would do it again in a second. Loved it.
Brutal tight area and 2 1/8" primaries, I made spike collectors and equal length tubes, fit like a glove!
CrAzYMoPaRGuY
Re: Header building Never again!! [Re: JD Dart] #2276156
03/25/17 08:20 PM
03/25/17 08:20 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Nice welds though!
Re: Header building Never again!! [Re: Mopar_Rich] #2276157
03/25/17 08:35 PM
03/25/17 08:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like doing them... sometimes its a bit more
time to get them as close to equal length as
possible
wave
Re: Header building Never again!! [Re: JD Dart] #2276160
03/25/17 08:51 PM
03/25/17 08:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I know of dyno tests that indicate equal length is unimportant. I wouldn't spend my time trying to make them equal length. Make the bends as smooth as possible, that is more important.
JD, those headers you built are art!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Header building Never again!! [Re: Hemi_Joel] #2276170
03/25/17 09:06 PM
03/25/17 09:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Equal length is like port timing.. I try to get
it as close as I can.. I seen it on the dyno..
on my W-9 set is within .1 in length.. but what
do I know
wave
Re: Header building Never again!! [Re: MR_P_BODY] #2276177
03/25/17 09:24 PM
03/25/17 09:24 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
do I know
wave
More than me, you've been there, done that. My friend Jay Brown was meticulous about always building equal length. Then someone told him smooth bends are more important than equal length. He didn't really believe it. He has his own dyno, so he did back to back tests. He reports to me that equal length didn't make any more power. But you have your own experience, go with what you know. wave
Re: Header building Never again!! [Re: Hemi_Joel] #2276181
03/25/17 09:41 PM
03/25/17 09:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
do I know
wave
Smooth bends are a standard.. you have to do
them if you want any decent header.. but equal
length is important also
EDIT
Also if you can you want large radius bends.. but
number 1 thing is they have to fit in the car
wave
Re: Header building Never again!! [Re: JD Dart] #2276207
03/25/17 10:37 PM
03/25/17 10:37 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Never again? That would be a shame. Looks like you did a nice job.
Re: Header building Never again!! [Re: TRENDZ] #2276214
03/25/17 10:49 PM
03/25/17 10:49 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I agree,very nice,but I also understand the "never again" feeling on a project!
Re: Header building Never again!! [Re: TRENDZ] #2276215
03/25/17 10:58 PM
03/25/17 10:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree... he knows how and nice welds
wave
Re: Header building Never again!! [Re: JD Dart] #2276218
03/25/17 11:01 PM
03/25/17 11:01 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I still like my JD LT's...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Header building Never again!! [Re: JD Dart] #2276248
03/25/17 11:58 PM
03/25/17 11:58 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If I were doing them for a living there's a plastic tubing kit where there's a ton of curves and straights that snap together and make each tube (all four at one time). They come in different size tubes and allow for any bend and really look like a header when all snaped together, infinitely adjustable. They start at $245 and go up, no more guessing and trial fitting.
Re: Header building Never again!! [Re: cudaman1969] #2276261
03/26/17 12:24 AM
03/26/17 12:24 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Isn't that the kit that you send in to have the pipes bent to there shape?
Re: Header building Never again!! [Re: rowin4] #2276269
03/26/17 12:37 AM
03/26/17 12:37 AM
merrill, wisconsin
V
voigtspeed Offline
voigtspeed  Offline
V
merrill, wisconsin
Look's Good to me something to be proud of... If there is a next time it will go faster and pay better people who understand the process will pay.........
ACCELERATION SPECIALIST
Re: Header building Never again!! [Re: rowin4] #2276286
03/26/17 01:34 AM
03/26/17 01:34 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Yea and no. Stainless Header Co. has jointed pipe kit you can use for a model so they can make make a header to your design. I suspect if you had the ICE kit they'ld be fine with that too.
But you can buy the ICE blocks for your own projects too. My impression is that they can be helpful but are not magic. It probably depends on the builder and the specific situation. Brian Slowe built me a set of headers last year and in this case he did not use them (even though he has them).
Here's a post about them over in Speedtalk.
http://speedtalk.com/forum/viewtopic.php?f=1&t=41836&p=565969#p565969
BTW That's a great thread to read in general for anyone interested in headers, at least the first 5 plus pages anyway. Lots of points about building as well as design and theory all mixed in.
Re: Header building Never again!! [Re: JD Dart] #2276314
03/26/17 02:35 AM
03/26/17 02:35 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Hot rod did a test (is a you tube videos of it) where they did back to pulls on a set of headers. Then took a hammer and beat a dent into a tube ....made a pull...more dents...a lot of dents. And I think was like a 6 or 7 hp loss. And the headers looked like junk
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Header building Never again!! [Re: JD Dart] #2276315
03/26/17 02:43 AM
03/26/17 02:43 AM
Renton Washington
Triple Threat Offline
Renton Washington
Looking good Jess
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Header building Never again!! [Re: toplescuda] #2276319
03/26/17 03:02 AM
03/26/17 03:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I watched that some time back.. I do have a
couple of questions on it.. first.. if a bented
up set of headers works just as well.. doesnt
that give you the idea that the area of those
were to large to start with.. second.. if that
held true.. why arent all the pro stocks beating
up there headers.. my opinion on that vid is they
were too big to start with.. but a lot of people
use to big
wave
Page 1 of 3 1 2 3
