Re: 1970 440 HP Convertor Weights
[Re: John_Kunkel]
#2274879
03/23/17 04:40 PM
03/23/17 04:40 PM
Posts: 10,781 North Dakota
6PakBee
North Dakota
And not available. This is kind of like being on the last lap and running out of gas 50' from the finish line. John, thanks for digging this up. I may just post a wanted ad as this topic is going to come up again and it's nice to have another solution in addition to welding weights.
[Re: 6PakBee]
#2274974
03/23/17 07:57 PM
03/23/17 07:57 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
OOPS. Didn't notice they were NLA.
Perhaps somebody who has a 10238 flexplate could make a tracing of the cutout and make it available so that the full-circle 10230 flexplate could easily be notched to duplicate it.
[Re: John_Kunkel]
#2275060
03/23/17 10:55 PM
03/23/17 10:55 PM
6PakBee
North Dakota
HAHAHA! John, great minds travel in the same gutters. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: WO23Coronet]
#2275123
03/24/17 12:43 AM
03/24/17 12:43 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I thought the torque converters on forged crank 440's were all neutral balance, 6pack rods or not? I think the external balancing on 6 pack rod engines was done on the harmonic balancer The 70 and up 440 large rod motors are eternally balanced at the harmonic balancer AND the torque convertor/flywheel
[Re: 6PakBee]
#2276599
03/26/17 04:46 PM
03/26/17 04:46 PM
Posts: 3,114 Michigan
A727Tflite
Here are a few pics - showing both 10238 driveplates. One with the weigth and one with the cutout - 180 degrees from where the weight would be. I'll post the tracing in a bit.
[Re: 6PakBee]
#2276615
03/26/17 05:04 PM
03/26/17 05:04 PM
A727Tflite
more pics
[Re: A727Tflite]
#2276883
03/27/17 12:16 AM
03/27/17 12:16 AM
6PakBee
North Dakota
The 1.635" dimension, is that from the edge of the hole?
[Re: charge70]
#2276886
03/27/17 12:18 AM
03/27/17 12:18 AM
6PakBee
North Dakota
Bee,I have the drive train out of my 70 R/T at home.It's a 440 u-code car that still has the original motor and trans. I can take a pic of the face of the converter if you want me to.Let me know. John. John, thanks for the pictures and dimensions of the converter weights. If I go this route, I definitely have enough information to do it correctly. Appreciate the help.
[Re: A727Tflite]
#2277019
03/27/17 10:09 AM
03/27/17 10:09 AM
6PakBee
North Dakota
6PakBee - yes - from the edge of the hole. Thanks for the detailed sketch. If I can't get hold of one of the flexplates, I'm sure I can lay it out using your drawing.
[Re: 6PakBee]
#2290315
04/18/17 10:58 PM
04/18/17 10:58 PM
6PakBee
North Dakota
Just to close this thread out, Transman has the machining capabilities to convert the B&M neutral balance 10230 flexplate to the external balance 10238. He did two for me and now I am set. Thanks so much!!
[Re: 6PakBee]
#2290496
04/19/17 11:13 AM
04/19/17 11:13 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Glad you got squared away!
