Re: TRUE compression ratio for 1969 440
[Re: BSB67]
#2274024
03/22/17 12:09 AM
03/22/17 12:09 AM
RapidRobert
IIRC JohnRR priorly posted that a 68-69 piston has a 2.030"CH & is ~.050 in the hole (as we know block deck heights vary) but you might plug it all into united machines' calculator. You know the std bore and stroke & the gasket dimention is available along with a good guesstimate on the 906's CC's & I'm assuming the piston has reliefs (find that info too) then let your fingers do the walking. also see if there are differences in 6pak pistons (not my area).
[Re: fast414]
#2274089
03/22/17 03:54 AM
03/22/17 03:54 AM
Posts: 43,298 Bend,OR USA
Cab_Burge
Iam to believe that a 1969 440 has a compression ratio of 10:1 to 10:5:1 ........how is that when the piston is down in the whole and the heads are open chamber ????......wouldn't the compression be like 9:2:1 ??
Not the four barrel magnum motors from the factory would be over 9.7to1, probably closer to 8.8 to 1 I've CC a lot of stock 906 heads that had 92.0+ CC per chamber and those stock magnum flat top pistons with no valve reliefs where down over -.030 in the hole No where close to NHRA blue print specs.
[Re: fast414]
#2274216
03/22/17 01:32 PM
03/22/17 01:32 PM
fast68plymouth
So. Burlington, Vt.
9.2-9.4 is about where the math comes out........ Depends on the actual deck clearance (block height) and chamber volume.
The added c/h of the 6bbl piston is offset by the 4 valve pockets, so there is no gain in compression with those pistons over the 2.030 c/h 4bbl piston.
[Re: fast68plymouth]
#2274268
03/22/17 03:34 PM
03/22/17 03:34 PM
Posts: 25,981 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Stock '68-'69 Magnum with 90 cc heads, .050" deck and a .022" head gasket is around 9.4-1
[Re: fast414]
#2274285
03/22/17 03:55 PM
03/22/17 03:55 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Factory advertised and ACTUAL compression ratio are not the same when it comes to Ma Mopar . they ran on pump gas in the day because the gas then is not the same as the swamp water being passed off a gasoline today ...
[Re: fast414]
#2274518
03/22/17 10:43 PM
03/22/17 10:43 PM
fast68plymouth
So. Burlington, Vt.
That's a fair question Russ.
You're probably correct in that "new" they were likely closer to 87-88cc.
