Re: Mounting electronics inside your race car...pics?
[Re: an8sec70cuda]
#2274897
03/23/17 04:19 PM
03/23/17 04:19 PM
Posts: 13,643 Marion, South Carolina [><]
an8sec70cuda
Thanks for all the pics yall, much appreciated!
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
[Re: shorthorse]
#2274902
03/23/17 04:24 PM
03/23/17 04:24 PM
an8sec70cuda
What thickness lexan is good for this? Is 1/8" too flimsy?
[Re: an8sec70cuda]
#2275304
03/24/17 10:35 AM
03/24/17 10:35 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
1/8 is what I use...no issues here
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: an8sec70cuda]
#2275385
03/24/17 01:18 PM
03/24/17 01:18 PM
Posts: 19,691 Las Vegas
Al_Alguire
Las Vegas
Mine is mounted on .040" carbon
[Re: an8sec70cuda]
#2275570
03/24/17 07:38 PM
03/24/17 07:38 PM
Posts: 360 Ohio
shorthorse
Ohio
What thickness lexan is good for this? Is 1/8" too flimsy? I use 1/4 because all the panels I've done are movable but 1/8 would be just fine on a fixed installation. It also depends on the total weight of all the devices you are going to mount and any possible effects of the panel/weight on acceleration and braking.
[Re: shorthorse]
#2293194
04/24/17 12:08 PM
04/24/17 12:08 PM
an8sec70cuda
OK, so I got my electronics board made and installed it in the car. Used several ideas I found here (thanks yall!) and on the YB thread and came up w/ something I'm real happy with. I used a 16" square piece of 1/4" thick lexan. 2 small hinges bolted to the firewall allow it to swing down from under the dash to allow access to everything. I have one dzus fastener that fastens it to the bottom edge of the dash frame. The electronics are mounted on top, so when it's up in place, nothing is visible from inside the car...unless you open the glove box. When funds allow, I want to upgrade to a MSD programmable 6AL-2 box...that one box will replace the 3 I use now (the 6AL, 2 step, and 3 stage retard). Eventually I'll go to a Leash nitrous progressive. What I have now is very old school, but it works (just somewhat limited as far as tuning). I only have this one pic...before I installed it under the dash. I'll get some more when I get a chance to work on it again. Thanks again for all the ideas and help. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
![Name: wiring.jpeg
ID: 282007 wiring.jpeg](/ubbthreads/ubbthreads.php/ubb/download/Number/282007/filename/wiring.jpeg)
[Re: John_T_Brown]
#2293218
04/24/17 12:56 PM
04/24/17 12:56 PM
Posts: 1,509 TN
SCATPACK 1
TN
Here are pics of the electrical system as it is today. The MSD Grid is mounted in triangle plate on the passenger side of the roll cage. The Racepak Smartwire is mounted just behind the passenger door along with Racepak V300SD to prevent any electrical interference with the Grid. The electrical panel for the Grid shifter and associated wiring connections are mounted in the glovebox opening. Hope it give you some ideas for your build. Hey john I would like to see more of your car, please sir. Sorry not trying to Hijack this thread, just intrigued by anything GTX or Road Runner related. Jerry
Old Geezer Racing
[Re: JERICOGTX]
#2293219
04/24/17 01:03 PM
04/24/17 01:03 PM
Posts: 1,509 TN
SCATPACK 1
TN
Jericho I hope your magnet idea works better than mine did. Every time we dropped the clutch on the line or hit a gear, it would invariably pop open. We tried using the switch like on the 68 glove boxes and it did not work either. We ended up putting a dzus fastener there, the kind that has the wing and twist. love your GTX though. I like anything stick shift. Jerry
Old Geezer Racing
[Re: an8sec70cuda]
#2310239
05/24/17 09:21 AM
05/24/17 09:21 AM
an8sec70cuda
Got the board in and hooked up. It did crank up so I must have done OK, lol. Still need to tie up some stuff to make it look neater, but it's a big improvement over what was there before. It looked a lot neater when I had it prewired on the table.
[Re: an8sec70cuda]
#2310240
05/24/17 09:22 AM
05/24/17 09:22 AM
an8sec70cuda
Here it is when fastened up out of the way...wanted it to be hidden.
[Re: an8sec70cuda]
#2310241
05/24/17 09:23 AM
05/24/17 09:23 AM
an8sec70cuda
The view looking in from the glovebox. Can't really access anything like this due to the narrow cuda glovebox door. It is really easy to lower down...used one wingnut style Dzus fastener to hold it up to the lower edge of the dash frame,
[Re: an8sec70cuda]
#2310245
05/24/17 09:27 AM
05/24/17 09:27 AM
an8sec70cuda
Cleaned up some wiring under the hood too.
