Re: Summit Motorsports Park Seeks Alternative On Light Pole
[Re: theraif]
#2273181
03/20/17 06:55 PM
03/20/17 06:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its crazy that a LITTLE air port can have this kind of impact on a big business.. I have only seen a dozen planes land or take off from there over the years.. it may come down to Baders buying it then closing it for good.. but I'm sure the pilots that fly out of there dont want that ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Challenger 1]
#2273372
03/20/17 11:46 PM
03/20/17 11:46 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
IMO as a pilot after looking at the situation on goggle earth, foreflight and looking at the AD(airport directory) that give me the pattern info on the the airport, I agree the poles are a concern. The planes are not at 600' the whole time, JR is confused. Pattern altitude is 1850msl', that's a 1000' AGL above ground level on the down wind and then it is lower the closer you get to the runway. By the time the plane is on final it can be below 65'AGL when it's approaching the runway. Not all approaches are straight in either. This airport has displaced thresholds meaning the whole asphalt strip is not used for landing and puts the poles more in the approach area. In a emergency you head to the runway at any angle if you can get there and you can see why those 2 poles I saw were too close to the runway. I have never seen anything that close to a runway approach in my short pilot career. I have landed at 9 airports so far.
The place survived for 44 years without those 3 lights since they just got 2 or them last year in 2016. So it is not like making them remove 3 lights are going to run them out of business. IMO I agree.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: theraif]
#2273404
03/21/17 12:34 AM
03/21/17 12:34 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Sounds like a plan, buy it and shut it down. That will take care of the problem. While at Pomona last month for the Winter Nationals I noticed that there was a air port at the end of the track on the west side. It was very busy with small planes. Maybe that is why there no lighting at the track. Speakers were in boxes on the ground also, they sucked big time.
[Re: Challenger 1]
#2273438
03/21/17 01:13 AM
03/21/17 01:13 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Oh No, Those three lights, made the track what it is. Track is now doomed. Alternative, lower those 3 light poles from 60' to 10' or 15', no big deal IMO Other then that, looks like a Ego power struggle issue..
[Re: rowin4]
#2273599
03/21/17 12:13 PM
03/21/17 12:13 PM
Challenger 1
Cincinnati, Ohio
Sounds like a plan, buy it and shut it down. That will take care of the problem. While at Pomona last month for the Winter Nationals I noticed that there was a air port at the end of the track on the west side. It was very busy with small planes. Maybe that is why there no lighting at the track. Speakers were in boxes on the ground also, they sucked big time. First off I bet it is not cheap or even possible to buy an airport and then try to shut it down! I bet plenty of drivers/owners get to the drag strip via the airport. And think about how many parts have been flown into the drag strip on big race weekends via the airport. Pretty handy to have it so close by. It might be a little too close though.
[Re: Challenger 1]
#2273604
03/21/17 12:22 PM
03/21/17 12:22 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have been going to Norwalk for to many years to count but this battle didn't just start over a few light poles. This battle has been going on for many years and will probably go on for many more. The Baders are land-locked now and the next direction they desire to go is through the airport. I really don't think they would pull up stakes and leave but if they did the economy in the area WOULD take a hit. Racers spend a lot of money while in the area.
[Re: theraif]
#2273654
03/21/17 01:36 PM
03/21/17 01:36 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
There was no permit or surveying done when the lights went up? No ordinances to follow?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2273666
03/21/17 01:59 PM
03/21/17 01:59 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
There was no permit or surveying done when the lights went up? No ordinances to follow? Kinda what I was thinking too. The FAA is pretty strict on what goes on around airports. Small airports can be a PITA.
[Re: theraif]
#2273687
03/21/17 02:34 PM
03/21/17 02:34 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Like John already said, this battle has gone on for many years and it stems from way more than just those 3 light poles. Being land-locked has been the biggest problem.
[Re: Challenger 1]
#2273727
03/21/17 03:49 PM
03/21/17 03:49 PM
Posts: 4,704 Wichita
GY3
Wichita
Sounds like a plan, buy it and shut it down. That will take care of the problem. While at Pomona last month for the Winter Nationals I noticed that there was a air port at the end of the track on the west side. It was very busy with small planes. Maybe that is why there no lighting at the track. Speakers were in boxes on the ground also, they sucked big time. First off I bet it is not cheap or even possible to buy an airport and then try to shut it down! I bet plenty of drivers/owners get to the drag strip via the airport. And think about how many parts have been flown into the drag strip on big race weekends via the airport. Pretty handy to have it so close by. It might be a little too close though. AOPA will fight shuttering any airport tooth and nail!
#2274021
03/22/17 12:07 AM
03/22/17 12:07 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
There was no permit or surveying done when the lights went up? No ordinances to follow? From what I understand, the poles have been up for 20 years. The lights haven't.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#2274045
03/22/17 12:41 AM
03/22/17 12:41 AM
Posts: 4,466 Morristown Tn.
71birdJ68
Morristown Tn.
This happens all the time. Local governments don't consult the FAA when they give out building permits or change zoning laws, so somebody puts up a light pole, or builds a shopping center right off the end of a runway, only later does the FAA get involved after it's too late. The really bad thing here is that the two entities involved, a RACE TRACK, and a small AIRPORT are an endangered species. After looking at it on satellite , the pole is back behind the tree line that parallels the runway, so it shouldn't be a problem. BUT, on the other have I taken a Piper Cub down to about 30 feet over a dirt track, and raced around with the cars during a race, so maybe somebody might try to land on the drag strip, it sure looks like a nicer runway.
[Re: 71birdJ68]
#2274054
03/22/17 01:03 AM
03/22/17 01:03 AM
rowin4
This happens all the time. Local governments don't consult the FAA when they give out building permits or change zoning laws, so somebody puts up a light pole, or builds a shopping center right off the end of a runway, only later does the FAA get involved after it's too late. The really bad thing here is that the two entities involved, a RACE TRACK, and a small AIRPORT are an endangered species. After looking at it on satellite , the pole is back behind the tree line that parallels the runway, so it shouldn't be a problem. BUT, on the other have I taken a Piper Cub down to about 30 feet over a dirt track, and raced around with the cars during a race, so maybe somebody might try to land on the drag strip, it sure looks like a nicer runway. I don't think it is wise to publicize that you were flying around a track with the race cars.
[Re: 71birdJ68]
#2274065
03/22/17 01:23 AM
03/22/17 01:23 AM
MR_P_BODY
Nobody knows me, I'm the phantom flier, besides, the statute of limitations has run out. LOL... years ago I was with a buddy... he didnt have a pilots license but he could taxi... we took off and he flew under a international bridge (no name here) and we ended up landing.. the FAA was all over his butt.. but nothing happened because he didnt have a license.. other than to taxi(AP license)
[Re: theraif]
#2274311
03/22/17 04:25 PM
03/22/17 04:25 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
Being both a drag racer and pilot and knowing about so many NIMBY raising heck over both airports and race tracks and the continuing closing of both I think the Bader family or one of its contractors representative did not do their require checking before having those light poles put in so close to the airport. I'm assuming the airport was there first, correct? Either way, it is a no win situation for all involved, the track, the airport, pilots and racers ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif)
