Re: 6.1 cam degreeing-in a 5.7
[Re: RTSrunner]
#2518469
07/06/18 04:27 PM
07/06/18 04:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Plenty of others can post pics, maybe it's you.
You cannot post pics using quick reply.
You must use full screen reply.
You must click on "file manager" right below the reply window
You must click on "browse"in the new window that pops open.
You must select a picture that is on your computer, under 2MB in size or you will be rejected.
Once you have selected your picture you must click on "add file".
You will now see the file you selected listed right above the File Caption window.
When you are done adding files click on "Done Adding Files"
The pop up closes and you can now click on "Submit" to post
[Re: Supercuda]
#2518486
07/06/18 04:54 PM
07/06/18 04:54 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The pop up closes and you can now click on "Submit" to post I shouldnt need to worry about what size my pics are. So its me and Ill take my info elsewhere
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2518566
07/06/18 08:31 PM
07/06/18 08:31 PM
Posts: 153 MI, USA
moparmitch
MI, USA
Trying suggested pic posting...got it. Thanks for the help!
[Re: RTSrunner]
#2519098
07/08/18 09:38 AM
07/08/18 09:38 AM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
I can confirm that its 121.5 ICL .. Sixpackgut came by to double check the readings I was getting and we moved it ahead 1 tooth 14 degrees and checked the piston to valve clearance. The white dot represents the -0- mark on the top gear, the bottom gear is at TDC. Thanks Ray
