Re: "La Putita" Bullit in but no fire in the hole! [Re: Al_Alguire] #227290
02/19/09 12:41 AM
02/19/09 12:41 AM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
We went through 5 gallons, have not checked the oil yet but will before we go out again. What should I look for?
Ted
Re: "La Putita" Bullit in but no fire in the hole! [Re: Diego_Ted] #227291
02/19/09 08:28 AM
02/19/09 08:28 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
check to see if it is milky
Re: "La Putita" Bullit in but no fire in the hole! [Re: Defbob] #227292
02/19/09 09:19 PM
02/19/09 09:19 PM
Diego-Town, CA
Diego-Town, CA
Thx Def, I thought on Alky the oil is going to be kind of milky anyways?
Diego
Re: "La Putita" Bullit in but no fire in the hole! [Re: Diego_Ted] #227293
02/19/09 10:16 PM
02/19/09 10:16 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
good to see you started It up,sounded like it has a couple of fouled plugs in the last video!
Re: "La Putita" Bullit in but no fire in the hole! [Re: Diego_Ted] #227294
02/19/09 10:58 PM
02/19/09 10:58 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Diego
a little milking happens time to time, Gotta get the oil really hot to avoid it, I try to get my oil temp up to a minimum of 180 during warm up. Curtis
Taking over the World one win light at a time.
Re: "La Putita" Bullit in but no fire in the hole! [Re: afxcoronet] #227295
02/19/09 11:34 PM
02/19/09 11:34 PM
Diego-Town, CA
Diego-Town, CA
Thx Curtis, will makd sure I get her good an hot!
Boat racer will check them plugs.
Diego
Re: "La Putita" Bullit in but no fire in the hole! [Re: boatracer572] #227296
02/20/09 12:12 AM
02/20/09 12:12 AM
San Diego
formula S Offline
formula S  Offline
San Diego
It needs a idle bi pass its a little rich at idle. I could have leaned it out a little with the fuel shut off. When you wack the throttle its hitting on all eight
Re: "La Putita" Bullit in but no fire in the hole! [Re: formula S] #227297
02/20/09 01:18 AM
02/20/09 01:18 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
We are running toilets on 2 cars w/ no bypasses, you gotta keep working the fuel shut off to keep it lean/ build heat and save gas, when running it on alky as soon as it fires up, pull the fuel shut-off until the rpms start coming up, even in the shut down area and return road keep it pulled and lean on the return road I usually put it in 3rd and lean it out enough to drive itself back. The only time I run mine w/ full fuel is when I'm rolling into burn out box and through to the shut down, I'll even lean it out if waiting for a bit between burnout and staging. It may seem like a lot of work, but it becomes second nature after a few hits...Now I run the primer plus so I warm it up, and drive it on Gasoline, and switch to alky when rolling into the burnout box and back to gasoline before the turn off.
Have you put a leakdown gauge on the Barrel valve yet? check out the attached link, has leakdown proceedures, pretty simple; mine is set at 26% leakdown with .014 throttle blade gap.
http://www.killerrons.com/why.cfm
Later Curtis
Re: "La Putita" Bullit in but no fire in the hole! [Re: afxcoronet] #227298
02/20/09 10:24 AM
02/20/09 10:24 AM
Diego-Town, CA
Diego-Town, CA
Thx Curtis, yes we put the gau I will run everything off the primer system except from the burnout box to the stripe.
Diego
Re: "La Putita" Bullit in but no fire in the hole! [Re: afxcoronet] #227299
02/20/09 10:28 AM
02/20/09 10:28 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Later Curtis
Thanks for the advise we will use it. we did a leak down test, our B.V is the purple one and it calls for .010-.012 throttle blade gap and 28% to 30% leak down so this is where we started. thanks again
Re: "La Putita" Bullit in but no fire in the hole! [Re: formula S] #227300
02/20/09 10:38 AM
02/20/09 10:38 AM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
good deal, sounds like you all are pretty close then.
