Page 2 of 3 1 2 3
Re: She's Done! [Re: STEFF] #2272882
03/20/17 11:52 AM
03/20/17 11:52 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Love it !!!! Damn that intake is tall.
Re: She's Done! [Re: STEFF] #2273058
03/20/17 03:47 PM
03/20/17 03:47 PM
Renton Washington
Triple Threat Offline
Renton Washington
Love it!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: She's Done! [Re: STEFF] #2273173
03/20/17 06:43 PM
03/20/17 06:43 PM
Canada
onig Offline
onig  Offline
Canada
I always wondered, what is the advantage to a belt drive oil pump? Also is their a pre-filter on that line before going to the pump?
69 Dart
Re: She's Done! [Re: fbs63] #2273627
03/21/17 01:06 PM
03/21/17 01:06 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Originally Posted By fbs63
Cool! Keep us posted on how it runs. You have a part number for the T&D rockers? I looked on their website and they don't list them yet. Also do you recall the crank to cam centerline dimension? Wondering how close it is to an LA motor.
Part # 8360 list for 2916.00
Re: She's Done! [Re: MattW] #2273646
03/21/17 01:31 PM
03/21/17 01:31 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Thanks!
Re: She's Done! [Re: STEFF] #2273670
03/21/17 02:04 PM
03/21/17 02:04 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Crank to Cam Centerline is 189mm (7.4409")
Re: She's Done! [Re: STEFF] #2273679
03/21/17 02:20 PM
03/21/17 02:20 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Awesome. Thanks Steff!
Re: She's Done! [Re: STEFF] #2274120
03/22/17 09:06 AM
03/22/17 09:06 AM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Originally Posted By STEFF
Yes. They are very well built. I should've just bought these before I wasted all the time I did trying to make my own.
Awesome engine!
Do you have any pics of the T&D stuff on the heads or otherwise?
Re: She's Done! [Re: STEFF] #2274157
03/22/17 11:37 AM
03/22/17 11:37 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Steff, did T and D improve the maximum valve lift or is it still limited to .680 or so?
Adriel Paradise
Substation Design Engineer III
Re: She's Done! [Re: STEFF] #2274181
03/22/17 12:25 PM
03/22/17 12:25 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
And do you have a build thread? It's a 6.4 block right?
Re: She's Done! [Re: STEFF] #2274206
03/22/17 01:10 PM
03/22/17 01:10 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
bada$$!!!
Re: She's Done! [Re: STEFF] #2274236
03/22/17 02:24 PM
03/22/17 02:24 PM
STEFF Offline OP
STEFF  Offline OP
MoparMitch, yes, I do have pics. I will get them posted later.
Adrielp, no, the ratio is stock. They are designed as "bolt-on". The Jesel System is your only option for more ratio and it's the best way to go. To get more ratio with a common shaft rocker assy, the shafts need to move and even then, it is limiting.
WO23Coronet, no build thread this time around. It is basically the same shortblock I built 4 years ago, with new heads, rockers, cam....
Re: She's Done! [Re: STEFF] #2274417
03/22/17 07:53 PM
03/22/17 07:53 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Might be a silly question but do you have any idea how much taller it is at the carb base then a LA with a Indy 360-1 intake? Can a person mill the carb base down an 1" or 2"? Or would it hurt performance to much? It will be a Procharged set-up if I go this way, I was thinking of possibly doing a Gen3 when/if my R3/Indy combo goes pop. I want to keep a flat hood on my Dart so that's why I ask.
Re: She's Done! [Re: STEFF] #2274418
03/22/17 07:54 PM
03/22/17 07:54 PM
8
80arrow Offline
80arrow  Offline
By the way your motor looks awesome.
Re: She's Done! [Re: STEFF] #2274814
03/23/17 02:53 PM
03/23/17 02:53 PM
STEFF Offline OP
STEFF  Offline OP
Rocker pics.....
A little clearancing required for the Intake adjuster.
Re: She's Done! [Re: 80arrow] #2274818
03/23/17 02:57 PM
03/23/17 02:57 PM
STEFF Offline OP
STEFF  Offline OP
No clue how they compare. You can cut the plenum shorter. I dont think the plenum volume means much with forced induction. I do know that NA, the more I made the plenum larger, that faster it went down the track. I'm going to add spacer to see where it tops out at, then look at making the plenum larger by modifying the intake, instead of using spacers.
Re: She's Done! [Re: STEFF] #2274833
03/23/17 03:15 PM
03/23/17 03:15 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Nice stuff! The spacers polymer?
Re: She's Done! [Re: fbs63] #2274896
03/23/17 05:18 PM
03/23/17 05:18 PM
STEFF Offline OP
STEFF  Offline OP
Yes. Some type of Delrin or ??
Re: She's Done! [Re: STEFF] #2274911
03/23/17 05:56 PM
03/23/17 05:56 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Looks exactly like the material that Koffel has made his spacers out of for ever.
Re: She's Done! [Re: STEFF] #2275027
03/23/17 09:33 PM
03/23/17 09:33 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
That rocker setup rocks! pun intended!
Page 2 of 3 1 2 3
