Re: 1973-1990 Truck 1/2 ton disc brakes. What diffrence?
[Re: moparborn]
#2272801
03/20/17 06:37 AM
03/20/17 06:37 AM
Posts: 1,970 ID/MT
Cheeto
ID/MT
I agree with using the '84 as your base sample. It still had 5x4.5" bolt pattern (for the older trucks) but used the larger outer bearing of the later trucks and Dakotas. NOTE: It's late at night and my memory isn't what it used to be so corrections to my comments may need to be made.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: migsBIG]
#2277320
03/27/17 07:51 PM
03/27/17 07:51 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Lots of people out there would like to have spindles for these! The 72-93 trucks use the same spindle on 1/2 tons. the difference is the rotors. Later trucks have bigger bearing diameter rotors. Yes the 84 is the year spindle that you should spec. By no means is the market dead. Look on fb for 72-93 truck groups. There are several, and with huge memberships. One of the biggest issues with these trucks is the lack of readily available parts to drop them with. Suspension geometry gets crazy when you use drop pocket lower control arms, things get dangerous in a hurry when done wrong,with shorter springs, not to mention ride quality ummm suffers.
O.G.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
