Re: Front end alignment for drag racing..chamber issues ..*PIC*
[Re: Chassisman]
#2269467
03/14/17 06:03 PM
03/14/17 06:03 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Something is seriously worn out. There has to be some worn out bushings somewhere. I suspect upper and lower control arm bushings. Maybe a set of tubular uppers with heim joints are in order to start.
[image][/image]
[Re: sgcuda]
#2269487
03/14/17 06:24 PM
03/14/17 06:24 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
Something is seriously worn out. There has to be some worn out bushings somewhere. I suspect upper and lower control arm bushings. Maybe a set of tubular uppers with heim joints are in order to start. It's all energy suspension stuff. I'm probably gonna go that route just to give more adjustment. My Dad has always tossed wrecking yard parts at this car when he raced it....so knowing him when he did the disc brake swap no telling what he used...it has 68 Dart springs under the back....SMH.
[Re: Chassisman]
#2269495
03/14/17 06:29 PM
03/14/17 06:29 PM
sgcuda
Is the pic when the tires touched down after a wheelstand or is that just under normal acceleration? If after a wheelstand, I would check the bushings in the front rods. There are heim joint kits for those, too now.
[image][/image]
[Re: sgcuda]
#2269497
03/14/17 06:32 PM
03/14/17 06:32 PM
Chassisman
Chowchilla,ca
Is the pic when the tires touched down after a wheelstand or is that just under normal acceleration? If after a wheelstand, I would check the bushings in the front rods. There are heim joint kits for those, too now. Car runs 13.17 @ 4185 Lbs.... My dad used an old dumpster for floor pans and tubs...and trunk floor...couldn't pull the fronts with a rocket booster....LOL
[Re: Chassisman]
#2269676
03/14/17 11:45 PM
03/14/17 11:45 PM
Posts: 9,897 MI, usa
dvw
MI, usa
I've seen a few A Bodys do that. Short spindle and the front end raised puts the upper A-Arm at a downward angle. Then when the suspension drops the upper arms pivot down and in. The fix? Late model FMJ knuckles are taller. The factory upper ball joint stud is to small so you'll need these: http://www.doctordiff.com/a-body-upper-ball-joint-tapered-adapter.html.Now with the upper A arm level or poniting slightly up the camber won't dive so bad when the suspension drops. I'd add the Moog offset bushings in the front of the A-arm as well. As long as the upper arm location is correct it'll look like this. Doug
[Re: Chassisman]
#2269679
03/14/17 11:48 PM
03/14/17 11:48 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Car runs 13.17 @ 4185 Lbs.... My dad used an old dumpster for floor pans and tubs...and trunk floor...couldn't pull the fronts with a rocket booster....LOL 4185 are you sure? That is incredibly heavy for an early A body.
1974 Roadrunner
1967 Charger
[Re: dvw]
#2269680
03/14/17 11:49 PM
03/14/17 11:49 PM
Chassisman
Chowchilla,ca
I've seen a few A Bodys do that. Short spindle and the front end raised puts the upper A-Arm at a downward angle. Then when the suspension drops the upper arms pivot down and in. The fix? Late model FMJ knuckles are taller. The factory upper ball joint stud is to small so you'll need these: http://www.doctordiff.com/a-body-upper-ball-joint-tapered-adapter.html.Now with the upper A arm level or poniting slightly up the camber won't dive so bad when the suspension drops. I'd add the Moog offset bushings in the front of the A-arm as well. As long as the upper arm location is correct it'll look like this. Doug I'll ask my Dad when he did the DB swap if he used the 73 Scamp upper arms... What did the FMJ knuckles come in? Thanks
[Re: Saskabusa]
#2269695
03/15/17 12:01 AM
03/15/17 12:01 AM
Chassisman
Chowchilla,ca
Car runs 13.17 @ 4185 Lbs.... My dad used an old dumpster for floor pans and tubs...and trunk floor...couldn't pull the fronts with a rocket booster....LOL 4185 are you sure? That is incredibly heavy for an early A body. Ya...we are sure...most west coast guys have seen this car...my dad was a drag racer in the 60's...off roader in the 70's...and Demo Derby guy in the 80's...Early 90's he built this car with left over derby stuff. The rear leak link bars are threaded power pole down guide anchors and weigh 35 lbs each.Made his own front leaf spring mounts out of 1/4" plate Trunk floor is 3/16 plate from hump to tail light panel. Mini tubs are made from 3/16 plate for sides and 1/8 steel 26" well casing flattened out. Subframe connectors are 2x2 1/4" wall tubing. K member is completely plated in 3/16 steel. 1960's vintage roll bar/ headrest is made from 2" thick wall black pipe with 6x6 1/4 plates sandwiched on the bottom. It has 361 truck cast iron manifolds running out the front of the K member for exhaust. Has PB...heater...carpet. Front seat is from an 80's Mustang and is heavy. He has 4/0 battery cables for both power and ground all the way to the trunk.It has all stock front fendewells.Has a full boat smogger 440/727 in it with 8 3/4 under it. I keep threatening to put it on a diet...but my Dad freaks out everytime I mention it. Threatens to take the car back from my boy My boy is 6' 270 football player and the car was wegihed with him in it....its a TANK...not an Early A Body... SMH.
[Re: Chassisman]
#2269698
03/15/17 12:07 AM
03/15/17 12:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've seen a few A Bodys do that. Short spindle and the front end raised puts the upper A-Arm at a downward angle. Then when the suspension drops the upper arms pivot down and in. The fix? Late model FMJ knuckles are taller. The factory upper ball joint stud is to small so you'll need these: http://www.doctordiff.com/a-body-upper-ball-joint-tapered-adapter.html.Now with the upper A arm level or poniting slightly up the camber won't dive so bad when the suspension drops. I'd add the Moog offset bushings in the front of the A-arm as well. As long as the upper arm location is correct it'll look like this. Doug I'll ask my Dad when he did the DB swap if he used the 73 Scamp upper arms... What did the FMJ knuckles come in? Thanks They came in the Volare and the transverse front end cars(the bars in front went across the front end) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2269702
03/15/17 12:10 AM
03/15/17 12:10 AM
Chassisman
Chowchilla,ca
I've seen a few A Bodys do that. Short spindle and the front end raised puts the upper A-Arm at a downward angle. Then when the suspension drops the upper arms pivot down and in. The fix? Late model FMJ knuckles are taller. The factory upper ball joint stud is to small so you'll need these: http://www.doctordiff.com/a-body-upper-ball-joint-tapered-adapter.html.Now with the upper A arm level or poniting slightly up the camber won't dive so bad when the suspension drops. I'd add the Moog offset bushings in the front of the A-arm as well. As long as the upper arm location is correct it'll look like this. Doug I'll ask my Dad when he did the DB swap if he used the 73 Scamp upper arms... What did the FMJ knuckles come in? Thanks They came in the Volare and the transverse front end cars(the bars in front went across the front end) ...now to try to find any of those in Calif....everything here has been crushed....
[Re: Chassisman]
#2269705
03/15/17 12:13 AM
03/15/17 12:13 AM
Posts: 1,506 TN
SCATPACK 1
TN
Are you still using the original style idler arm that has the single bracket for the mount? May want to switch to the later model and add that top brace with the thru bolt instead of the single bracket. My Bro n law had one of those early A bodies and that idler arm would move all over the place. Let me try to find my old Mopar manual that shows how to modify the brackets so the idler arm, pitman arm and both tie rod ends are the same level on the drag link.
Old Geezer Racing
[Re: J_BODY]
#2269716
03/15/17 12:24 AM
03/15/17 12:24 AM
Chassisman
Chowchilla,ca
went to Comp Chassis in Phoenix and spent money.... that's what I did.
... Ya...well...you know AJ has a fleet of cars and is trying to put me in the poor house ...LOL Wait til the the 7.0 Pro car debuts....I'm gonna be selling organs to keep it going. And the S/C dragster...and the Junior Comp...and...and...LOL
[Re: SCATPACK 1]
#2269717
03/15/17 12:25 AM
03/15/17 12:25 AM
Chassisman
Chowchilla,ca
Are you still using the original style idler arm that has the single bracket for the mount? May want to switch to the later model and add that top brace with the thru bolt instead of the single bracket. My Bro n law had one of those early A bodies and that idler arm would move all over the place. Let me try to find my old Mopar manual that shows how to modify the brackets so the idler arm, pitman arm and both tie rod ends are the same level on the drag link. I'll have to see...I believe he swapped the entire 73 Scamp K member.
[Re: Sport440]
#2269797
03/15/17 03:03 AM
03/15/17 03:03 AM
Posts: 13,204 aZLiViN
J_BODY
aZLiViN
No need to be arrogant. Who is Comp Chassis by the way, any good? Ron and I have an understanding.... and chop on each other when the chance is provided ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) He's pretty much relegated his own racing to the back burner to support his kid.... who is a great kid with a passion for the sport. The Canary is a cool old school build. It aint perfect, but it's a family tradition that keeps going. To be perfectly honest, I'd try to modernize it some, and that would start with a mucho better front end set up.... but they do have more irons in the fire than the average joe for sure. Comp Chassis has done pretty much all the work on both of my cars the 20 years I've been in the desert. I went to them on a few recommendations and have always been satisfied with the work and how the car performs. Living in the plains states to get any work done you pretty much knew your car was going to chassis jail.... Comp has gotten any project I've needed done in a timely manner. The last big visit was years ago when I adopted my dads Duster. I took it in for a full cage and tube K front end complete with coil overs and rack steering. Also had them fix the ladder bar set up. prior to me molesting the Duster, we also ran a complete K from a 73 era scamp (easy way for disc and big bolt pattern). I seem to recall having to change the pitman arm and idler, but I'm thinking it was more for a clearance issue. I know on wheels up shots, the camber was quite noticeable, but nothing like that coming down.
