Re: Oil shelf life question
[Re: MI_Custumz]
#2267607
03/11/17 07:57 PM
03/11/17 07:57 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
No shelf life or required storage that I know of. I'm still using motor oil my Dad had before he died 11 years ago. He had this thing about buying stuff on sale and the cases of oil kind of got out of hand.
Lead, follow or get the hell out of the way
[Re: MI_Custumz]
#2267648
03/11/17 09:06 PM
03/11/17 09:06 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The oil folks do set a shelf life; it seems that moisture can penetrate the plastic containers through permeation and cause the additives to drop out of suspension during extended storage.
[Re: MI_Custumz]
#2267821
03/12/17 01:37 AM
03/12/17 01:37 AM
RapidRobert
Sweet, now to find a place to stash it in the house so the wife won't see it. What about a secluded spot in the attic or the basement?
[Re: MI_Custumz]
#2267855
03/12/17 03:13 AM
03/12/17 03:13 AM
Posts: 3,134 N.W. Florida
Fat_Mike
N.W. Florida
Sweet, now to find a place to stash it in the house so the wife won't see it. Well, I guess my first suggestion would have been to stash it behind the cleaning supplies (most wive's would never find it there), but you kinda ruled that out above. Perhaps go through her shoes, pick out the ones you ain't seen in awhile and pile them on top of it in the back of the closet. OK, but seriously...are we talking about stashing one quart of oil???
[Re: MI_Custumz]
#2268003
03/12/17 02:06 PM
03/12/17 02:06 PM
Posts: 22,783 Bitopia
jcc
Bitopia
I'm having a hard time accepting moisture entrapment of an oil filled sealed plastic container, to any amount, to be detrimental. That being said, not sure a simple shake before using wouldn't allow its use in one's lifetime, after that, it will be a collector item anyway. This assumes, reasonable temp storage conditions and no UV. The oil will surely last another million years, and the additives really have nothing else present to precipitate break down, or separation, except gravity, if that is a possibility.
[Re: MI_Custumz]
#2268014
03/12/17 02:25 PM
03/12/17 02:25 PM
Posts: 2,260 IL
furious70
IL
I've been using northern labeled 20w50 that's at least 20 yrs old in my fury...
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: jcc]
#2268113
03/12/17 05:01 PM
03/12/17 05:01 PM
John_Kunkel
Rio Linda, CA
I'm having a hard time accepting moisture entrapment of an oil filled sealed plastic container, to any amount, to be detrimental. Well, believe it. Moisture permeation through High Density Polyethylene (the stuff oil containers are made of) is a known fact. Introduction of moisture causes the calcium (part of the detergent package) to drop out of suspension.
[Re: John_Kunkel]
#2268314
03/12/17 09:58 PM
03/12/17 09:58 PM
jcc
Bitopia
I'm having a hard time accepting moisture entrapment of an oil filled sealed plastic container, to any amount, to be detrimental. Well, believe it. Moisture permeation through High Density Polyethylene (the stuff oil containers are made of) is a known fact. Introduction of moisture causes the calcium (part of the detergent package) to drop out of suspension. So the airborne moisture goes thru the plastic, but none of the oil comes out of the plastic, and once the moisture goes thru the plastic, it goes thruout the stagnant oil, and attacks/attaches to the calcium? My loss, I'm just not there yet. If for a simple test, if I immersed a sealed plastic oil container, I would see accelerated oil breakdown evidence?
[Re: jcc]
#2268645
03/13/17 03:08 PM
03/13/17 03:08 PM
John_Kunkel
Rio Linda, CA
So the airborne moisture goes thru the plastic but none of the oil comes out of the plastic, Yep. Happens at the molecular level. Google "permeation". and once the moisture goes thru the plastic, it goes thruout the stagnant oil, and attacks/attaches to the calcium? "Absorb" is the word you're looking for.
[Re: jcc]
#2268795
03/13/17 07:20 PM
03/13/17 07:20 PM
Posts: 4,266 State of Fascism
52savoy
State of Fascism
I'm having a hard time accepting moisture entrapment of an oil filled sealed plastic container, to any amount, to be detrimental. Well, believe it. Moisture permeation through High Density Polyethylene (the stuff oil containers are made of) is a known fact. Introduction of moisture causes the calcium (part of the detergent package) to drop out of suspension. So the airborne moisture goes thru the plastic, but none of the oil comes out of the plastic, and once the moisture goes thru the plastic, it goes thruout the stagnant oil, and attacks/attaches to the calcium? My loss, I'm just not there yet. If for a simple test, if I immersed a sealed plastic oil container, I would see accelerated oil breakdown evidence? I'm a skeptic too.. I have oil that's a few million years old and still use it. Well 30 year old Kendal GT.
