Re: Cam bearing tool, which one? [Re: RV2] #2270240
03/15/17 09:14 PM
03/15/17 09:14 PM
P
Porter67 Offline
Porter67  Offline
P
I do not understand all this rubber sleeve and o ring stuff, even in the military we had size specific tools.
Ive done near 250 small blocks with these and never had one single issue, even to reuse the cam bearings from the race motors in dirt track claimer builds.
I dont know how the Les tool works but ive caught 3 MP cam bearings that were sized wrong from the box with these as well by not fitting or fitting too loose.
Maybe I just know there might be a better way or ?
Re: Cam bearing tool, which one? [Re: Porter67] #2270543
03/16/17 01:19 PM
03/16/17 01:19 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
sleeve or o-ring allows a split mandrel to fit a range of sizes...you don't need bearing specific mandrels. Just this winter I've done a small chevy, a 400 olds, and a small mopar. The adjustable mandrels cover all the applications.
Re: Cam bearing tool, which one? [Re: Porter67] #2270559
03/16/17 01:38 PM
03/16/17 01:38 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Those solid drivers are nice. I ran into the same problem with a set of cam bearings where one was the wrong size. Would not fit the cam. Now I check that they at least fit the cam before installing them.
Re: Cam bearing tool, which one? [Re: Challenger 1] #2270585
03/16/17 02:34 PM
03/16/17 02:34 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted By Challenger 1
Originally Posted By RV2
I'm in the market for a cam bearing tool, I'd like to purchase a quality piece.
What's recommended?
What should I stay away from?
A snap On one is better than the Lisle tool. I have both, the snap on one uses O rings and the lisle uses rubber sleeves. O rings are better and easier to work with IMO. Plus the snap on one seems harder more solid when you hit it with a BFH.
Funny , I bought my Lisle tool off the snap on truck ...
I use it for more than cam bearings . I could use another set of sleeves for it .
Mainstream Media is the new Pravda
Re: Cam bearing tool, which one? [Re: JohnRR] #2270617
03/16/17 03:30 PM
03/16/17 03:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
What's recommended?
Might be able to get them here.
https://www.summitracing.com/parts/pow-pow181800
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Cam bearing tool, which one? [Re: pittsburghracer] #2271121
03/17/17 12:05 PM
03/17/17 12:05 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
thanks John
Re: Cam bearing tool, which one? [Re: JohnRR] #2271129
03/17/17 12:20 PM
03/17/17 12:20 PM
PA.
"Little"John
"Little"John
PA.
thanks John
Very welcome. Glad I could help
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
