Page 5 of 5 1 2 3 4 5
Re: gettin spark for a second [Re: mopar muscle7271] #2268831
03/13/17 08:00 PM
03/13/17 08:00 PM
Which wire was burnt? You might get it going with a stock dist/ECU/ballast then see if you want to upgrade. The ignitor I II and III are modules that bolt in the dist & elim the pickup/ECU/ballast. I have the I and the III (uninstalled as of yet). The I was 2 bucks at a swap meet for a Toyota & I can redrill the plate if I can get the V8 black ring with the green tape. the III I splurged on for the stock car (& my racing partner is paying for it) so I took a chance cuz it ain't my money in the hat.
Re: gettin spark for a second [Re: RapidRobert] #2268884
03/13/17 09:29 PM
03/13/17 09:29 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Ok well im the whole distributor made by them and non vacuum advance one to.
Re: gettin spark for a second [Re: mopar muscle7271] #2268913
03/13/17 09:58 PM
03/13/17 09:58 PM
I would (highly) suggest a vac adv unit
Re: gettin spark for a second [Re: RapidRobert] #2268944
03/13/17 10:23 PM
03/13/17 10:23 PM
las vegas,nv
las vegas,nv
My 440 isnt stock its midly built,.564 high extreme energy comp cam,noisy gear drive 30 over pistons and im a runnin a 850 demon carb that doesnt have a opening for it.beefed up 906 heads with bigger intake and exhaust valves. Why you say i need one?
Re: gettin spark for a second [Re: mopar muscle7271] #2269041
03/14/17 12:17 AM
03/14/17 12:17 AM
I'm thinking it would give a better mileage (probably not the highest on your list) and it would keep the plugs cleaner but if the demon doesn't have a ported nipple then its a moot point. EDIT might run a bit cooler (but you want no cooler than 180)
