Re: Port CCs
[Re: 451Mopar]
#2268821
03/13/17 07:46 PM
03/13/17 07:46 PM
Posts: 31,105 Oregon
AndyF
When I watched that Engine masters, I was thinking they should do a show about port cross section area. Dyno the same engine with the same type of head, but different port cross section size and see how the torque curve changes? I'm getting ready to do a back to back dyno test with a 470 inch Mopar. I'll run the Trick Flow 240cc heads on the engine and then replace them with the 270 cc heads. I do expect the torque peak to move up with the larger heads. I'm almost positive that the 470 inches pulls harder on the 240 cc heads than they can deliver. The question will be how does the engine respond to the back to back testing since I'll use the same headers, cam and carb. I should have the answer by the end of the month.
Re: Port CCs
[Re: 451Mopar]
#2268872
03/13/17 09:09 PM
03/13/17 09:09 PM
Posts: 43 California USA
LowDeck451
California USA
When I watched that Engine masters, I was thinking they should do a show about port cross section area. Dyno the same engine with the same type of head, but different port cross section size and see how the torque curve changes? Me too. I think something like that is coming. In one of their short video 'extras', Dulcich said he would give DF a set of his max ported-relocated pushrod hole Eddy heads. Should be interesting.
Re: Port CCs
[Re: LowDeck451]
#2269273
03/14/17 12:45 PM
03/14/17 12:45 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Speaking in extremely general terms, this is a trend I have seen play out many many times.....
-motors built with nice flowing heads that would generally be thought of as "too small" for the application are often "over achievers".
-cars powered by motors with "bigger" heads seem to often be underachievers, and/or seem to be much fussier about things like cam selection, converter stall speed, rear gear....... Basically the whole combo is less forgiving.
Certainly there are many examples of the bigger heads doing just what they should, or even beating expectations....... But I've seen enough "big head" combos that were duds(of all brands) to know that just having big heads with big flow numbers does not guarantee big power or fast ET's. At the same time, small heads with modest flow numbers often run way better than "conventional wisdom"(or many of the formulas) would suggest.
It's pretty easy to beat the 2hp/cfm(for an 8 cyl engine) yardstick when the heads are on the small side for the build, especially if the rest of the combo is well thought out.
Re: Port CCs
[Re: LowDeck451]
#2269289
03/14/17 12:59 PM
03/14/17 12:59 PM
fast68plymouth
So. Burlington, Vt.
I'm getting ready to do a back to back dyno test with a 470 inch Mopar. I'll run the Trick Flow 240cc heads on the engine and then replace them with the 270 cc heads. Andy, since it sounds like TF did their testing of the 270 heads using their std port manifold, do you have any plans on trying that yourself? I think it would be a good test, since you've already run it on the 240 heads, so that would be a back-to-back test where the only change was the heads.
Re: Port CCs
[Re: LowDeck451]
#2269944
03/15/17 01:15 PM
03/15/17 01:15 PM
fast68plymouth
So. Burlington, Vt.
I'm assuming the peaks you're referring to are horsepower peaks, not tq peaks.
I had a 451 with 300cfm rpm heads making peak hp at 7200rpm, peak tq was in the 5500 range.
I trust the real world results more than I do the computer sims.
