Re: 1972 Road Runner emission/engine decal location
[Re: 6bblgt]
#2266979
03/10/17 07:40 PM
03/10/17 07:40 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Here is my 72 Satellite Sebring Plus, St. Louis Car but build of 424. Car is a 400 4bbl. auto. This car is a California car so when I restored it I had to use a NON-Cali. sticker. (None made at this point in time).
Look closely at this first picture to show the outline of where the sticker was factory applied, This picture shows over spray on Fender Mount area because the car got it's first exterior paint.
The second picture is how I applied it after the engine compartment was stripped and restored. ( It is a little off from factory placement.
Also note factory placement was very hard to read. Ron
[Re: RJS]
#2267057
03/10/17 09:59 PM
03/10/17 09:59 PM
Posts: 4,920 new berlin wisconsin
Mr T2U
that's where my stlouis 2-29 built date 72 road runner emissions decal was also.
perception is 90% of reality
[Re: scatpacktom]
#2268032
03/12/17 03:01 PM
03/12/17 03:01 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
THANKS! I didn't take it apart, but this is the best pic I can find of the LH inner fender & no pics of the bottom of the hood. & Jim's (username?) '72 GTX 4-spd engine compartment
[Re: RJS]
#2268057
03/12/17 03:28 PM
03/12/17 03:28 PM
6bblgt
Las Vegas, NV
I've owned 2 72 B-Bodys Plymouths and been around many. All were where I'm showing you, can't speak for a Dodge but then you didn't ask for a Dodge. Ron I understand, I just added the (wrong plant & Dodge) pic because that was the only survivor 440 '72 b-body I had a pic of & the source of the confusion. this '72 GTX moved under its own power Friday night - first time in ~20 years
[Re: 6bblgt]
#2268150
03/12/17 05:55 PM
03/12/17 05:55 PM
Posts: 6,224 JERSEY
RJS
JERSEY
are these two clips on top of RH inner fender correct, what is routed there? Not on any I saw, go back up and look at my engine compartment. Ron
[Re: RJS]
#2268174
03/12/17 06:45 PM
03/12/17 06:45 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Autoxcuda that was a cool thread, I kept a bunch of those pictures.
Nice that the Runner is running again. Ron Here's another thread with pics of 71-72 survivor and original B-Bodies. https://board.moparts.org/ubbthreads/ubbt...1-2-b-body.html
[Re: RJS]
#2268447
03/13/17 02:44 AM
03/13/17 02:44 AM
6bblgt
Las Vegas, NV
are these two clips on top of RH inner fender correct, what is routed there? Not on any I saw, go back up and look at my engine compartment. Ron vacuum line retainers for the AIR GRABBER reservoir? black or white retainers for the lines attached on the bottom of the hood?
[Re: 6bblgt]
#2268490
03/13/17 09:47 AM
03/13/17 09:47 AM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
are these two clips on top of RH inner fender correct, what is routed there? Not on any I saw, go back up and look at my engine compartment. Ron vacuum line retainers for the AIR GRABBER reservoir? black or white retainers for the lines attached on the bottom of the hood? They don't even look like Mopar to me. The Air Grabber clips on the hood don't have ridges on them and can't open up without removing them from their mounting holes. It looks like these can open up from the top side.
[Re: 6bblgt]
#2268556
03/13/17 12:42 PM
03/13/17 12:42 PM
Posts: 6,224 JERSEY
RJS
JERSEY
are these two clips on top of RH inner fender correct, what is routed there? Not on any I saw, go back up and look at my engine compartment. Ron vacuum line retainers for the AIR GRABBER reservoir? black or white retainers for the lines attached on the bottom of the hood? No to them being there for Air Grabber and the one's on the hood should be opeq (white).
[Re: 6bblgt]
#2269436
03/14/17 05:23 PM
03/14/17 05:23 PM
autoxcuda
So Cal
ok, found my picture of the 72 RR/GTX 440 4bbl non-airgrabber
Looks similar to RJS's strap for hoses to the Charcoal Canister
Well preserved and not messed with. Minus aluminum radiator. Maybe one older repaint.
