Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: Mopar_Rich] #2266771
03/10/17 02:02 PM
03/10/17 02:02 PM
central il.
second 70 Offline
second 70  Offline
central il.
Rich is there an advantage to running a Hemi duel quad manifold over a single throttle body manifold on efi?
I'm currently running a stage 5 carb version with a shaker on my Cuda and would need to chance manifold or put bungs in this one to upgrade.
Might be almost a wash if I sell the one I have and buy an efi manifold.
Thanks Mike
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: 72Challenger] #2266785
03/10/17 02:16 PM
03/10/17 02:16 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Mike,
With EFI, more air is good. You can't overcarburate with throttle bodies. There are only two potential issues with dual TBs on a big HEMI. 1) The expense of the second TB. 2) Throttle tip-in is more aggressive. Most people actually like this but it can be a problem with a radical HEMI in a light car.
Just FYI: You block off the IAC on one of the TBs and keep the second TPS as a backup.
Re: Hemi efi dual quad, Edelbrock vs Stage V [Re: Mopar_Rich] #2266801
03/10/17 02:46 PM
03/10/17 02:46 PM
central il.
second 70 Offline
second 70  Offline
central il.
Thanks Rich. Should be fine in a 3800# cuda
