Plastic caliper pistons for track use? #2265353
03/08/17 02:00 AM
03/08/17 02:00 AM
n.c.
geo. Offline OP
geo.  Offline OP
n.c.
Would like to hear from anyone who's "tracked" their Mopar with plastic pistoned slider calipers.
My only experience is with several sets of stuck calipers that I've replaced on trucks and a Durango.
I'm wondering how they hold up under hi-heat, and heavy braking.
The only rebuilt calipers I've seen for sale all have plastic pistons.
The later Kit Cars were equipped with the truck front caliper in front and the car caliper in the rear, both sliders.
Were all slider calipers supplied with plastic pistons from the factory?
Re: Plastic caliper pistons for track use? [Re: geo.] #2265398
03/08/17 03:27 AM
03/08/17 03:27 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Wow I have never heard of plastic brake caliper parts before? I learned something new!
I would just imagine a red-hot glowing disc from hard braking at the track and the heat eminating from it being at least 1000*F, yeah any plastic part will eventually melt.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Plastic caliper pistons for track use? [Re: geo.] #2265443
03/08/17 08:38 AM
03/08/17 08:38 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'm sure he meant phenolic not plastic.
Phenolic pistons don't rust to the bore.
Phenolic pistons don't transfer heat to the brake fluid like steel.
But high heat can cause the phenolic material to break down over time due to oxidation.
Don't be the exception.
Re: Plastic caliper pistons for track use? [Re: geo.] #2265547
03/08/17 01:33 PM
03/08/17 01:33 PM
n.c.
geo. Offline OP
geo.  Offline OP
n.c.
Sorry, yes the other P word.
It just made me wonder if the fact that the calipers eventually stick on street cars is any indication of how they will hold up with road-course use.
Or is caliper sticking more a result of not changing brake fluid,seals hardening,or something else?
Re: Plastic caliper pistons for track use? [Re: Supercuda] #2265584
03/08/17 02:30 PM
03/08/17 02:30 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The bold above, is also IMO a significant cause of why they overheat in the first place, they can't depend on the fluid as heat path to help cool themselves. SS types seems to be best compromise.
Re: Plastic caliper pistons for track use? [Re: geo.] #2265614
03/08/17 03:16 PM
03/08/17 03:16 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
The reason calipers stick usually isn't due to the material of the piston. Poor maintenance is the cause. Not flushing fluid regularly allowing moisture to corrode the metal--aluminum or iron, of the caliper body, deteriorating rubber hoses, etc; fills the caliper body with crud/debris. The dirt then gets between the piston and caliper and locks it up.
**Photobucket sucks**
Re: Plastic caliper pistons for track use? [Re: 70Cuda383] #2265663
03/08/17 04:46 PM
03/08/17 04:46 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I highly agree with the above and unfortunately it happens to most vehicles that are street use only!
Track use is a different game as you basically want all your brake components to be top notch. 3500+ lbs. has to be able to stop consistently from high speed for 15-20 minute stints through out the entire day.
I run Carbotech pads as they have a way higher heat range than street pads and can cope with the abuse. Any of the other brake manufacturer should also work if their compounds are for high heat.
I use a white plastic brake fluid reservoir so that I can shine a flashlight through to see if any contaminants are in my fluid. I run Castrol SRF which is supposed to be the best brake fluid out there due to the high wet boiling point and replace that every other year.
Think you can install stainless steel brake lines and forget about them? Nope! Those should be replaced periodically as the crimps loosen over time and you can have a burst hose at the track.
Brake components are only half the equation in stopping as tire compounds and tire width/contact patch also play a huge role in slowing down. Yes all of these consumables get expensive but its still a lot cheaper than using a wall or another car to stop for you.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Plastic caliper pistons for track use? [Re: geo.] #2266340
03/09/17 06:51 PM
03/09/17 06:51 PM
AndyF Offline
AndyF  Offline
Go dig thru the Green Brick articles and I'm pretty sure you'll find that Eberg was a fan of the phenolic pistons. That car got a lot of track time back in the day.
Re: Plastic caliper pistons for track use? [Re: AndyF] #2266591
03/10/17 03:08 AM
03/10/17 03:08 AM
n.c.
geo. Offline OP
geo.  Offline OP
n.c.
Thanks for that!
Forgot how "stock" the brick was in the beginning.
Re: Plastic caliper pistons for track use? [Re: geo.] #2269421
03/14/17 05:01 PM
03/14/17 05:01 PM
so cal
alltime Offline
alltime  Offline
so cal
Slider calipers have a well deserved reputation for not releasing efficiently. This is what makes them a poor choice for track days or road racing. The hotter the get the worse this gets as well.
The only true fix is going with a fixed caliper. Otherwise you will always be adjusting your driving to the limitations of the slider style calipers.
Re: Plastic caliper pistons for track use? [Re: geo.] #2269442
03/14/17 05:33 PM
03/14/17 05:33 PM
AndyF Offline
AndyF  Offline
Yeah I know that Rick worked thru some of those issues and so did Tim with his Valiant. Eventually everyone who runs these cars really hard ends up in the same spot with fixed multi-piston calipers and big rotors. It is just the only thing that works consistently at 150+ mph.
Re: Plastic caliper pistons for track use? [Re: geo.] #2269590
03/14/17 09:21 PM
03/14/17 09:21 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Look at what Porsche or other hot cars are doing. 4 or 6 piston Brembo's that are fixed. Do it once and save money in the long run.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Plastic caliper pistons for track use? [Re: geo.] #2280700
04/02/17 02:17 AM
04/02/17 02:17 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Are "plastic" pistons made for the a-body fixed KH caliper?
Re: Plastic caliper pistons for track use? [Re: geo.] #2281881
04/03/17 10:31 PM
04/03/17 10:31 PM
USA
Consulier Offline
Consulier  Offline
USA
Phenolic piston transfer plenty of heat and are a known failure point on a track car that goes for any type of endurance race length. I've holed Phenloics on Neons during races and track days will disintegrate the pistons fairly quickly. Common Neon swap for Showroom Stock cars was Titanium Pistons.
The Brick could survive because it just didn't produce much brake temperature. The stock semi metallic pads you got from the dealer couldn't get hot enough to destroy the piston. Put on a set of race pads and it would have been a different story.
Re: Plastic caliper pistons for track use? [Re: cudaman1969] #2282150
04/04/17 12:40 PM
04/04/17 12:40 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Not seen any. Stainless is available and provides the advantage of corrosion resistance with higher thermal resistance (compared to chromed steel).
Re: Plastic caliper pistons for track use? [Re: Consulier] #2282153
04/04/17 12:44 PM
04/04/17 12:44 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"Thermal conductivity units is W/(m K) in the SI system and Btu/(hr ft °F) in the Imperial system."
Aluminum 205
Phenolic cast resins 0.15
Phenol-formaldehyde moulding compounds 0.13 - 0.25
Stainless Steel 16
Titanium 22
@77F
http://www.engineeringtoolbox.com/thermal-conductivity-d_429.html
Re: Plastic caliper pistons for track use? [Re: geo.] #2282180
04/04/17 01:16 PM
04/04/17 01:16 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Steel, Carbon 1% 43
This is the baseline comparison.
