Re: Cam Recommendation - 340 [Re: dd340] #2266292
03/09/17 05:20 PM
03/09/17 05:20 PM
CA
crackedback Offline
crackedback  Offline
CA
273 rockers can work well. Try to get them set up with a jam nut.
Re: Cam Recommendation - 340 [Re: crackedback] #2266318
03/09/17 06:06 PM
03/09/17 06:06 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
the set i am looking at do not appear to have jam nuts, just the adjuster. How do they keep their position without the jam nut?
Re: Cam Recommendation - 340 [Re: dd340] #2266508
03/09/17 11:59 PM
03/09/17 11:59 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Interference thread. Adjusters with jam nuts are easy to come by - Crane and others make them. 273 rockers are great til you start needing wider springs, which is where the tend to rub, But with your goals I don't see that as a problem. Me personally, I'd go with the Comp XE268 for a hydraulic or the MP 284 528 solid.
