Page 5 of 7 1 2 3 4 5 6 7
Re: 33 plymouth 2 dr. sedan [Re: 5wndwcpe] #2236037
01/17/17 01:44 PM
01/17/17 01:44 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
Ready for paint.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2236040
01/17/17 01:52 PM
01/17/17 01:52 PM
Shelby, Ohio
2
Shelby, Ohio
Who sells new windshield frames for 33 Plymouth ??
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2236479
01/18/17 12:11 AM
01/18/17 12:11 AM
Shelby, Ohio
2
Shelby, Ohio
After 25 years, I finally got some paint on it. Dusty Orchid Poly with Dark Plum fenders and side aprons.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2236603
01/18/17 10:39 AM
01/18/17 10:39 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
very nice color combo ! up what are your interior plans ?
beer
Re: 33 plymouth 2 dr. sedan [Re: moparx] #2236720
01/18/17 02:08 PM
01/18/17 02:08 PM
Shelby, Ohio
2
Shelby, Ohio
the interior is whatever the wife picks out. All the interior metal trim and dash will be a Kameleon color that changes. It's called Rosey Purpleen. It will be this color.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2237142
01/19/17 03:39 AM
01/19/17 03:39 AM
British Columbia, Canada
cocobolo Offline
cocobolo  Offline
My oh my! But that is just gorgeous! She is going to look spectacular when you put her all back together.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2237143
01/19/17 03:44 AM
01/19/17 03:44 AM
cocobolo Offline
cocobolo  Offline
You might try srpmstreetrods.com
Re: 33 plymouth 2 dr. sedan [Re: cocobolo] #2237348
01/19/17 04:49 PM
01/19/17 04:49 PM
Shelby, Ohio
2
Shelby, Ohio
Thanks. I called them and they are closed until the 30th. i'll try then.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2239048
01/22/17 02:29 PM
01/22/17 02:29 PM
Az
Crizila Offline
Crizila  Offline
Az
Awesome!! I basically did the same thing with my 33 Coupe - "interior is what ever the wife picks out". There are some things that are better left up to the lady of the house so to speak. Interiors are one of them IMO. I would have ended up with some cheap bucket seats in basic black with a steering wheel and gauges to match, but ended up with - - - - thanks to the wife.
Fastest 300
Re: 33 plymouth 2 dr. sedan [Re: Crizila] #2241459
01/26/17 02:00 AM
01/26/17 02:00 AM
cocobolo Offline
cocobolo  Offline
Very nice. Do you have a build thread anywhere on your car?
Re: 33 plymouth 2 dr. sedan [Re: cocobolo] #2241772
01/26/17 04:43 PM
01/26/17 04:43 PM
Az
Crizila Offline
Crizila  Offline
Az
Go to Custom33 on face book. Owner of the company posted lots of pics of my build.
Fastest 300
Re: 33 plymouth 2 dr. sedan [Re: Crizila] #2243415
01/29/17 02:43 PM
01/29/17 02:43 PM
Shelby, Ohio
2
Shelby, Ohio
Finally getting it back together. Spent all day Saturday setting the body back on the frame.
Don't know why, but it won't let me download pictures today.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2244588
01/31/17 10:55 AM
01/31/17 10:55 AM
Shelby, Ohio
2
Shelby, Ohio
Here we go.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2244619
01/31/17 11:51 AM
01/31/17 11:51 AM
Az
Crizila Offline
Crizila  Offline
Az
Looking good!! You are making great progress. Anxious to see how all the periphery's (HVAC, wipers, electrical, etc ) are all going to go in. Since I have reverse mounted ( under the dash ) dual Wilwood masters, space went from tight to TIGHT between the dash and firewall on my build. I went with the smallest Vintage air unit available. Still ate up the entire right side of the under dash area. Ducting for 3 levels of heat ( defrost, mid, floor) also killed lots of space. Wiper system sits directly in front of the heater box. If I had to do it again, don't think I would have installed a wiper system. Rain-X just works too good! I did split up my electrical system. My battery and controls for the power door locks and windows are located behind the seat with access doors in the trunk front wall. Main fuse panel is located in the center area under the dash in a swing down panel ( that don't swing down much anymore) for easy access - NOT!
Fastest 300
Re: 33 plymouth 2 dr. sedan [Re: Crizila] #2245611
02/01/17 10:16 PM
02/01/17 10:16 PM
Shelby, Ohio
2
Shelby, Ohio
Since my windshield still opens, I put the wipers overhead. My brake system is under the floor, and I'm not installing a/c. So I have plenty of room behind the dash for all my wiring. I am planning ahead and leaving room to add air later if she wants it.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2247464
02/04/17 10:50 PM
02/04/17 10:50 PM
Shelby, Ohio
2
Shelby, Ohio
insulation , sound deadener installed today.
Re: 33 plymouth 2 dr. sedan [Re: 2abodymcodes] #2247609
02/05/17 09:19 AM
02/05/17 09:19 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What did you use for insulation and sound deadener? And where did you get it from? Gene
Re: 33 plymouth 2 dr. sedan [Re: poorboy] #2247714
02/05/17 01:06 PM
02/05/17 01:06 PM
Shelby, Ohio
2
Shelby, Ohio
It's called FatMat. This particular style is their Rattle Trap. Thicker than normal. It's made in Painesville, Ohio. They have a website. I have 4 cars with this stuff. Makes a real big difference.
Re: 33 plymouth 2 dr. sedan [Re: poorboy] #2248285
02/06/17 02:15 AM
02/06/17 02:15 AM
cocobolo Offline
cocobolo  Offline
Home Depot sells what appears to be an identical product for home duct use. The Fat Mat may be slightly thicker, but the idea is the same. Far less money. I tried some and it really does work.
Re: 33 plymouth 2 dr. sedan [Re: cocobolo] #2258861
02/24/17 05:33 PM
02/24/17 05:33 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have used the "duct" product with great results for around 80% less cost than fat mat....
