Page 5 of 6 1 2 3 4 5 6
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2304556
05/14/17 09:34 PM
05/14/17 09:34 PM
tri-cities Washington/Denver, ...
5280Dart Offline OP
5280Dart  Offline OP
fender gaps are going to need some attention...
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2304559
05/14/17 09:39 PM
05/14/17 09:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2304568
05/14/17 09:46 PM
05/14/17 09:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
As much as I hate to say it, it looks like the front of the nose needs to come down to align the fenders and door gaps. That will make the hood clearance even worse.
How close is the hood to throttle body, and is it just the throttle body, or the intake as well? Will you have clearance for an air filter assembly? Maybe if its just the throttle body clearance, you can add a tapered shim between the intake and the throttle body to gain the clearance you need. Gene
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2304752
05/15/17 09:04 AM
05/15/17 09:04 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Oh man I can truly sympathize. I had exactly the same problem on my 57 when I put the Hemi in. The slope on the hood interfered with the front of the air cleaner for the Tri-Power. In my case it was either lose the Tri-Power for a shorter intake or use a hood scoop.
I agonized over that for about a month (especially as IMO there are no scoops that really look good on these cars). In my case the Tri-Power won and I sacrificed a 61 Thunderbird hood for the scoop.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: dodge dakota frame swap, custom coils or air bags needed [Re: Mike P] #2305246
05/15/17 11:12 PM
05/15/17 11:12 PM
5280Dart Offline OP
5280Dart  Offline OP
Well for what it is worth, it looks good. I actually was trying to figure out what you used....
Kinda leaning toward a 1969 dodge power bulge.... I am going to contact some of the supercharger manufactures and hope that they offer a unit for the 6.1 with about an inch less total height than the srt intake manifold. I briefly considered a 1" body lift, and then a corresponding 1" suspension drop. Dont really want to go that route.
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2323396
06/19/17 12:10 AM
06/19/17 12:10 AM
5280Dart Offline OP
5280Dart  Offline OP
Starting to install the wiring harness...
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2323398
06/19/17 12:12 AM
06/19/17 12:12 AM
5280Dart Offline OP
5280Dart  Offline OP
Trying to find a place for all the stuff is a bit of work...
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2323399
06/19/17 12:15 AM
06/19/17 12:15 AM
5280Dart Offline OP
5280Dart  Offline OP
Had to cut a 2.375" hole in the firewall, behind the passenger side fuel rail for the harness to pass thru. There is a portion of the harness that has to be snaked under the intake manifold, cam sensor, water temp, a/c pump, etc. That took some doing.
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2324401
06/20/17 08:53 PM
06/20/17 08:53 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
Looking good! Can't wait to see that thing finished!
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2360699
08/27/17 05:17 PM
08/27/17 05:17 PM
5280Dart Offline OP
5280Dart  Offline OP
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2360806
08/27/17 08:23 PM
08/27/17 08:23 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Originally Posted By 5280Dart
thumbs
John
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2361010
08/28/17 05:48 AM
08/28/17 05:48 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Great to see/hear it run! Did you come up with a hood clearance solution?
Re: dodge dakota frame swap, custom coils or air bags needed [Re: Mike P] #2361591
08/29/17 09:12 AM
08/29/17 09:12 AM
5280Dart Offline OP
5280Dart  Offline OP
No solution on the hood just yet.
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2496232
05/14/18 11:05 PM
05/14/18 11:05 PM
5280Dart Offline OP
5280Dart  Offline OP
Well, time for an update. Here is my hood clearance solution...
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2496233
05/14/18 11:06 PM
05/14/18 11:06 PM
5280Dart Offline OP
5280Dart  Offline OP
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2496237
05/14/18 11:14 PM
05/14/18 11:14 PM
5280Dart Offline OP
5280Dart  Offline OP
I had to deepen the driveshaft tunnel due to the need for a larger diameter driveshaft, lowered stance, and the elevated install height of the transmission.
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2496243
05/14/18 11:18 PM
05/14/18 11:18 PM
5280Dart Offline OP
5280Dart  Offline OP
I am running 3" exhaust all the way back, with an H-pipe and Dynomax Ultraflo mufflers...
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2496247
05/14/18 11:21 PM
05/14/18 11:21 PM
5280Dart Offline OP
5280Dart  Offline OP
And I swapped in a 8.8 ford rear end out of a 1998 ford explorer. That provided 3:73 gears, tracloc differential, 31 spline axles, and disc brakes for the low cost of $300.
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2496478
05/15/18 01:58 PM
05/15/18 01:58 PM
southwest Alabama
southwest Alabama
Awesome!
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2496513
05/15/18 03:09 PM
05/15/18 03:09 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Nice work
