Re: Four Wheel Disc Brakes-Is it worth It??
[Re: RapidRobert]
#2263007
03/04/17 12:35 AM
03/04/17 12:35 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Good points above. I guess I don't like change so much as I used 2, but when drum brake parts get hard to find, what else can a fella do? Surely can't hurt. I guess you have convinced me to "upgrade" when I get into the next brake job. Got several coming up.
I have mechanical Aptitude. I can screw up anything.
[Re: Dave Hall]
#2263127
03/04/17 09:27 AM
03/04/17 09:27 AM
Posts: 16,012 RI Deep in the rust belt
chargervert
Repairing accident damage and the increased insurance costs will easily outweigh the cost of a 4 wheel brake upgrade. Don't ask me how I know!
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: 65pacecar]
#2263141
03/04/17 10:48 AM
03/04/17 10:48 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Sorry, 4 wheel disc brakes are not going to stop you faster than disc/drums. Heck, most of the front disc kits sold for our rides these days barely stop the car at all. Too many people have problems they fail to address and blame it on "inferior 50 year old drum brakes" when the problem really is inferior knowledge, maintenance or both.
[Re: dart4forte]
#2263225
03/04/17 02:02 PM
03/04/17 02:02 PM
Posts: 6,733 KY
65pacecar
KY
I have already converted my 65 Sport Fury to front disc, is it worth the extra money/effort to go with four wheel disc brakes? I have a 65 300 Vert. Which kit did you use? I've done three 65 Sport Fury front disc conversions. One was the scarebird kit, ok but not the greatest. Second one I found a set of spindles etc from a 73 Fury disc car, love that combo, great results. I just installed the ssbc kit for a C body but haven't driven it yet, but appears to be nice quality and set up. Easy installation.
[Re: 65pacecar]
#2263429
03/04/17 09:25 PM
03/04/17 09:25 PM
Posts: 3,698 jersey
Spaceman Spiff
jersey
think about this. even if you're not an aggressive driver, and maintain speed limits, when ANY other car on the road can stop much quicker, and in a shorter distance than you can....that means you'll end up in their bumper. even driving down the road at 35mph, if the car in front suddenly slams on the brakes, it's going to stop before you. sure drums stop fine.... as long as everyone around you has them too. what if a child, or a deer, or other animal ran in front of your car. even at 25mph, drums vs disc could mean saving a life.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2263479
03/04/17 11:32 PM
03/04/17 11:32 PM
Posts: 23,295 Here
jcc
Here
A major reason modern cars have 4 wheel discs is they are better able to handle ABS inputs. Most of the anecdotal cases mentioned so far center around emergency/panic braking, I assume most know approx 70% of your braking is on the fronts, and discs there are very useful in many situations. And the OP asked I believe mainly about rear disc addition. Furthermore, any braking force generated beyond locking up your tires, in a single panic stop, at any speed, is useless. Remember Tires stop your car. Nobody here is modulating their rear brakes close to lock in a panic stop. Normal thinking is front's should lock up before rears, and they are the ones modulated if the driver has the skills/experience. OP should spend his time/effort/money in places offering much better bang for buck. edit: with full disclosure I'm currently adding rear discs to a street driven car , many reasons other then performance/braking issues, like rear end change (7.25 to 8.75), BP change, internal drum parking brake, tiny discs ( weight & MOI), car will see some track time, etc
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
#2263517
03/05/17 02:03 AM
03/05/17 02:03 AM
Posts: 18,165 Mass
DAYCLONA
Mass
think about this. even if you're not an aggressive driver, and maintain speed limits, when ANY other car on the road can stop much quicker, and in a shorter distance than you can....that means you'll end up in their bumper. even driving down the road at 35mph, if the car in front suddenly slams on the brakes, it's going to stop before you. sure drums stop fine.... as long as everyone around you has them too. what if a child, or a deer, or other animal ran in front of your car. even at 25mph, drums vs disc could mean saving a life. Trying to convince some of the Mopar brethren to the advantages of brake, OD, fuel or ignition upgrades is a lost cause for some (maybe most), maybe an analogy that may help them understand? think of having rear discs like having a condom, better to have it, and not need it, than need it, and not have it...
[Re: DAYCLONA]
#2263635
03/05/17 01:12 PM
03/05/17 01:12 PM
bboogieart
Lost and Spaced
Addition of O.D's, fuel injection, and rear wheel disc brakes, usually offer no real advantage let alone never pay for themselves.
Especially in hobby cars. It's more for bragging rights. I enjoyed my cars when they were current, and more so now that they are rare and different.
I believe properly maintained drum brakes work just fine for someone that drives reasonably safe in the first place. They only fade after repeated hammering. Not really needed. Even on today's freeways. Most folks just drive way to aggressively today. Not to mention all the other things folks do while driving on those commutes. My reason for swapping would simply be availability issues.
The above mention of crashed newer cars bares out this belief. It's not the car so much as the nut that holds the wheel.
[Re: 65pacecar]
#2263654
03/05/17 01:41 PM
03/05/17 01:41 PM
Supercuda
About to go away
About to go away
up yours
What did the Green Brick run?
11" drums in the back
How many 4 wheel disc brake cars did it beat?
[Re: Supercuda]
#2263698
03/05/17 02:50 PM
03/05/17 02:50 PM
chargervert
You guys put what you want in your cars,but I already had to replace a 3/4 nose on my finished car because it didn't stop fast enough or straight enough. After seeing first had how much of a night and day difference they made on my friends 71 Charger R/T,I am upgrading all my cars.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: 65pacecar]
#2263766
03/05/17 04:03 PM
03/05/17 04:03 PM
Supercuda
About to go away
About to go away
up yours
If a car isn't stopping straight the problem is not the drums but the mechanic.
#2263775
03/05/17 04:22 PM
03/05/17 04:22 PM
Posts: 240 Spring City , Pa.
SIKPUP
Spring City , Pa.
think about this. even if you're not an aggressive driver, and maintain speed limits, when ANY other car on the road can stop much quicker, and in a shorter distance than you can....that means you'll end up in their bumper. even driving down the road at 35mph, if the car in front suddenly slams on the brakes, it's going to stop before you. sure drums stop fine.... as long as everyone around you has them too. what if a child, or a deer, or other animal ran in front of your car. even at 25mph, drums vs disc could mean saving a life. This is it exactly !! And if you leave yourself enough room , someone will fill that safety zone you have created !
[Re: Supercuda]
#2263808
03/05/17 05:08 PM
03/05/17 05:08 PM
chargervert
Both Chargers that didn't stop straight had disc brakes on the front.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#2263820
03/05/17 05:32 PM
03/05/17 05:32 PM
Posts: 23,295 Here
jcc
Here
Both Chargers that didn't stop straight had disc brakes on the front. Were they both red, because that will make them pull to the right. Seriously,typical thread with opinions, or a tinge of https://en.wikipedia.org/wiki/Cognitive_bias or https://en.wikipedia.org/wiki/Confirmation_biasTo repeat, the OP asked " Is it worth It?" Not "are they better?" I rest my case.
