Re: Trick Flow 270 intake and valley pan?
[Re: sasquatch]
#2262267
03/02/17 05:25 PM
03/02/17 05:25 PM
BradH
yeah well try to find a standard port dominator intake?????Nothing that I know of. RB - MP M1 4500 - Edelbrock SV 2891 B - Only the MP M1 4500 AFAIK... I have no idea if those MP intakes are available any more, either. EDIT: And any MW intake + a tub of Belzona!
[Re: 70VcodeCoronetRT]
#2262383
03/02/17 10:36 PM
03/02/17 10:36 PM
Posts: 1,028 Andrews,In. U.S.of A.
67_Satellite
After seeing the 240 T.F. head first hand, making a mold and comparing it to the "old standard" Perf. R.P.M.,and flow testing it,it is clear what would need to be done to the 240 to take it to M.W. size.A slight casting modification(add material) to half of the intake port, a different c.n.c. program, and an offset rocker requirement. If trick flow is going to try to sell a "big" port head,I think they would do themselves a favor by making the obvious changes which would make the head what the customer would expect in a M.W. head.The "last half"of the port has enough size,and a good looking profile,to support a much larger upstream cross sectional area. After developing the head in a logical fashion, make a dedicated intake to feed the necessary airflow to match the head.Build it and they will buy.
[Re: sasquatch]
#2262388
03/02/17 10:44 PM
03/02/17 10:44 PM
BradH
Brad You said Mopar intakes as if we can just order one up like they have them in stock... Bullsh!t. I said very clearly that I did not know if the MP intakes were even available.
[Re: RustyM]
#2262482
03/03/17 01:18 AM
03/03/17 01:18 AM
Posts: 2,509 Sydney,Australia
tex013
Sydney,Australia
I too look forward to seeing the results of your work. so do I Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: sasquatch]
#2262768
03/03/17 05:03 PM
03/03/17 05:03 PM
Posts: 14,587 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
yeah well try to find a standard port dominator intake?????Nothing that I know of. Edelbrock SV 2891; std port, 4500 flange, RB motor
[Re: AndyF]
#2262769
03/03/17 05:07 PM
03/03/17 05:07 PM
fast68plymouth
So. Burlington, Vt.
I'd like to see a raised port standard port head. It's called a Victor head 350+cfm from a true std port opening.
#2262772
03/03/17 05:20 PM
03/03/17 05:20 PM
fast68plymouth
So. Burlington, Vt.
I have to chuckle at the notion that you "can't" make a TF 240 head into a MW head.
Will it have the "correct" taper throughout the length of the runner to be a high end "race" head? No. But......... They would still be more spacious down stream of the pinch than an original MW head, or the MW versions of the stage 6 heads...... And people have been able to make decent power from both of those.
There is no doubt in my mind that a set of TF 240's, opened up to facilitate the use of a MW intake manifold would work just fine, and make more power on a suitable build than the same heads with a std port opening and intake manifold.
Since the 240's are also std port height, opening them to MW size and running the 337 intake would be a nice combo that would eliminate the need for a valley cover.
[Re: fast68plymouth]
#2262798
03/03/17 06:22 PM
03/03/17 06:22 PM
BradH
I'd like to see a raised port standard port head. It's called a Victor head 350+cfm from a true std port opening. INTAKE - AVG (4) 0.100 -- 75.0 0.200 -- 151.3 0.300 -- 220.1 0.400 -- 280.3 0.500 -- 326.1 0.550 -- 338.2 0.600 -- 346.0 0.650 -- 350.5 0.700 -- 355.5 0.750 -- 346.7 EXHAUST - AVG (4) - W/ 2” PIPE 0.100 -- 55.0 0.200 -- 116.2 0.300 -- 154.9 0.400 -- 194.0 0.500 -- 223.3 -- 237.6 0.550 -- 233.3 -- 249.2 0.600 -- 241.3 -- 258.5 0.650 -- 247.2 -- 267.5 0.700 -- 251.8 -- 273.5 0.750 -- 255.4 -- 278.3 Sorry, sometimes I can't help myself.
#2262818
03/03/17 07:03 PM
03/03/17 07:03 PM
Posts: 31,338 Oregon
AndyF
I'd like to see a raised port standard port head. It's called a Victor head 350+cfm from a true std port opening. Umm yeah but that is a Victor head with all the Victor weirdness....
[Re: AndyF]
#2262839
03/03/17 07:24 PM
03/03/17 07:24 PM
BradH
I'd like to see a raised port standard port head. It's called a Victor head 350+cfm from a true std port opening. Umm yeah but that is a Victor head with all the Victor weirdness.... My doctor prescribed me these little pills to help me deal with the Victor weirdness... and the voices in my head... and those flying pink spotted polar bears I see occasionally in my backyard. Life is good.
