Page 4 of 5 1 2 3 4 5
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262884
03/03/17 08:39 PM
03/03/17 08:39 PM
AndyF Offline
AndyF  Offline
I heard that if you use Victor heads you never get your engine running. Something about the curse of the Victors......
Re: Trick Flow 270 intake and valley pan? [Re: AndyF] #2262886
03/03/17 08:45 PM
03/03/17 08:45 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That would explain a lot... work
Re: Trick Flow 270 intake and valley pan? [Re: BradH] #2262926
03/03/17 09:57 PM
03/03/17 09:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
when I heard the TF 270 was coming out I thought to myself that I probably should of waited instead of getting the 240's,,now I am glad I pulled the trigger and got them as it sounds to me the 270 isn't anything special, besides in a couple of years when I do a frshen-up the 240's will be sent out and professionally ported, by that time the head porters will know what they like, no more being a guinea pig for me.
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262976
03/03/17 11:00 PM
03/03/17 11:00 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I am happy with my 240s opened up to a 337 intake.
I didn't want a scoop, it pulls like a freight train.
Larry Smith worked on the intake as well as the heads. 370cfm @ .700 on his bench.
249 CC final intake runner volume.
Re: Trick Flow 270 intake and valley pan? [Re: 65Fury440] #2263014
03/03/17 11:48 PM
03/03/17 11:48 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Sounds nice! How big of a cam do you have? Enough to use that 370 cfm?
Re: Trick Flow 270 intake and valley pan? [Re: fast68plymouth] #2263016
03/03/17 11:50 PM
03/03/17 11:50 PM
P
PorkyPig Offline
PorkyPig  Offline
P
Originally Posted By fast68plymouth
Originally Posted By AndyF
I'd like to see a raised port standard port head.
It's called a Victor head wink
350+cfm from a true std port opening.
Compared to what sort of flow do you get from a Trick Flow 240?
Re: Trick Flow 270 intake and valley pan? [Re: AndyF] #2263020
03/03/17 11:56 PM
03/03/17 11:56 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Umm yeah but that is a Victor head with all the Victor weirdness....
I'm pretty sure nothing you ran into with them would be beyond your capabilities of being able to get the motor up and running wink
Re: Trick Flow 270 intake and valley pan? [Re: PorkyPig] #2263033
03/04/17 12:13 AM
03/04/17 12:13 AM
So. Burlington, Vt.
So. Burlington, Vt.
It's all here;
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2205428/1.html
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2263047
03/04/17 12:34 AM
03/04/17 12:34 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
For anyone interested, Larry and I put an INdy plate and 440-2 intake on a pair of 270s and that should work pretty well. The plate is off a smidge but nothing scary.
Todd
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2268573
03/13/17 12:12 PM
03/13/17 12:12 PM
AndyF Offline
AndyF  Offline
Here is a picture of the 270 chamber and bowl area. These heads have the smoother competition porting from Trick Flow so they are much smoother than the 240 heads.
Re: Trick Flow 270 intake and valley pan? [Re: fast68plymouth] #2268837
03/13/17 07:07 PM
03/13/17 07:07 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Originally Posted By sasquatch
yeah well try to find a standard port dominator intake?????Nothing that I know of.
Edelbrock SV 2891; std port, 4500 flange, RB motor
This is what the Edelbrock 2891 Super Victor ports look like. Port size is standard, BUT the ports are RAISED approx. .050". Bolts to a stock RPM head (and other stock port heads), but the ports don't line up. Wish I had seen this $412 ago. Edelbrock says the SV 2891 is made for their Victor heads.
Brian
Re: Trick Flow 270 intake and valley pan? [Re: '72CudaRacer] #2268861
03/13/17 07:54 PM
03/13/17 07:54 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Brian
WOW
solves my thoughts of using that intake instead of an adapter
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow 270 intake and valley pan? [Re: tex013] #2268917
03/13/17 09:03 PM
03/13/17 09:03 PM
Mooresburg, Tn
Mooresburg, Tn
Will some tell me what intake is being refered to as "337"?
Thanks, Brian
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2268943
03/13/17 09:22 PM
03/13/17 09:22 PM
AndyF Offline
AndyF  Offline
My shortblock for the 270 testing is going together. It will have a tad bit more compression than my last 470 and it will be dry sump but it will have the same cam as the last 470. I'm guessing the power level will be up slightly from the last 470 engine but we'll see what the dyno says.
Re: Trick Flow 270 intake and valley pan? [Re: '72CudaRacer] #2268967
03/13/17 09:44 PM
03/13/17 09:44 PM
BradH Offline
BradH  Offline
Brian
From what I see in your pics, that intake would NOT align properly with my Victors the way it's cast.
Re: Trick Flow 270 intake and valley pan? [Re: BradH] #2268984
03/13/17 09:56 PM
03/13/17 09:56 PM
Mooresburg, Tn
Mooresburg, Tn
Brian
I don't have any Victor heads to check them on Brad, but these gaskets are the Edelbrock gaskets(#7225) that Edelbrock says to use. They are indentical to Felpro's paper. I set this intake on my engine with RPM heads. The bolt holes lined up, but when you look into the carb opening to the heads, its a HUGE mismatch height wise.
Brian
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2269303
03/14/17 12:09 PM
03/14/17 12:09 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Crazy to me that they wouldn't release a matching (max wedge port) intake. I really wanted to try a set of these on a procharger build. But maybe the 240s will be good enough.
Re: Trick Flow 270 intake and valley pan? [Re: '72CudaRacer] #2269335
03/14/17 01:15 PM
03/14/17 01:15 PM
BradH Offline
BradH  Offline
Brian
I have an untouched std-port Victor head and those same Edelbrock gaskets: the gaskets align perfectly w/ the CNC'd port entries (holes, ports, etc.). The SV 2891 you showed would have the same port mismatch issue on either a Victor or Performer RPM. It's not the heads, it's the intake casting. down Could it be corrected? Yeah, but it's going to take somebody's time and/or $$$ to do it.
I wonder how the 2891 matches up to a typical MW head, and if in that application it would be more a case of doing a major port matching exercise to at least be usable?
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2305744
05/16/17 09:24 PM
05/16/17 09:24 PM
AndyF Offline
AndyF  Offline
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2305876
05/17/17 02:04 AM
05/17/17 02:04 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thanks Andy !!!!
