Re: Power windows?
[Re: 80arrow]
#2451456
02/13/18 11:37 PM
02/13/18 11:37 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Also, They do not fit very well in an A-body. You can see how I had to mount it with the motor inside the door and the track on a pretty bad bind. Still doesn't work when I straighten the track out like I said earlier.
The only way to mount it straight would be to put it right where that big brace is inside the door, so that won't work.
Re: Power windows?
[Re: 80arrow]
#2451759
02/14/18 06:30 PM
02/14/18 06:30 PM
ProSport
Akron, Ohio
The electric window motors draw a lot of current, are your wires big enough? The wires to my window motors were at least 14 gauge, and may have been 12 gauge.
Yes I tried big wires, tried with and w/o a relay. I even attached the electric motor directly to a fully charged car battery to eliminate all the wiring and the motor still seemed very weak. I see that places like Gary Ball sell the same type of kit for triple the price. I wonder if they are better. But I still didn't like how they fit in my door on a bind.
Re: Power windows?
[Re: 80arrow]
#2453074
02/17/18 03:32 PM
02/17/18 03:32 PM
Posts: 200 Colorado
Bob J
Colorado
Or you can take a C body power window assembly and swap arms from your A or B body onto the C body. I drilled mine and only added 1 lbs per front assembly.
Plus I used the C body harness.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
