Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: C_B5] #2263795
03/05/17 04:48 PM
03/05/17 04:48 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Originally Posted By C_B5
As others have stated the 70-71 style bumpers will bolt up to a 1972 model
However, as an FYI - as usual the 1970 is a one year only part. For 100% factory correct parts the 1970 bumpers have details that are different from the 1971 bumpers.
Also all years 70-71-72 use a different corner bumper rubber piece even though there is only one reproduction offered as correct for all years
Here are details on the rubber bumper fillers. Will post photos of the different year bumpers later
Part #'s
1970 models: 2962344 and 2962345
1972 models: 3464064 and 3464065 (may also be used on late 1971 models)
The main differences between the bumper fillers - See photos for reference
> skirt length of rubber on side and bottom is longer on the 1972 part
> the 1970 fillers do NOT have any internal support - material is all rubber
> the 1972 filler is molded over an internal solid support
> the 1972 filler has a noticeable extra tab molded into the rubber (along the groove) this fits into a notch of the bumper
> the part numbers are molded onto opposite sides of the part
See attached photos
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: C_B5] #2263798
03/05/17 04:52 PM
03/05/17 04:52 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
also in bottom photo note extra rubber molded on side of 72 filler to make part more rigid
the 1972 filler is on left and 1970 filler on right
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: C_B5] #2263807
03/05/17 05:01 PM
03/05/17 05:01 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
1972 filler on left and 1970 filler on right
bottom photo close up of the 1972 filler showing tab that fits into notch on bumper
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: C_B5] #2268169
03/12/17 06:31 PM
03/12/17 06:31 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Here are the reproduction rubber bumper fillers
Not certain if there is ONLY one vendor manufacturing the parts but this style does not have the correct factory features as the 1970 filler. The repro fillers available more resemble the later filler style
Still trying to locate the rubber fillers I had from an early 1971 Challenger. However, may have tossed them with another 1/2 dozen or so fillers because they were bent or torn.
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: C_B5] #2277458
03/28/17 12:29 AM
03/28/17 12:29 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Finally had the opportunity to take some photos of the different Challenger bumpers.
The photos show the different shape of the corners were the rubber filler part is mounted
For the different rubber fillers parts - Refer to the photos in my earlier post.
These are all original bumpers. A photo of each year 70-71-72 follows
The 1970 model uses the one year only unique bumper
Note that the bumper corner is smooth - there are no cut-outs which corresponds to the 1970 only rubber filler style
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: C_B5] #2277460
03/28/17 12:32 AM
03/28/17 12:32 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
1971 Challenger bumper from a Sept 1970 car
Note that the corner area is already changed from the earlier 1970 ONLY style
Not certain when this change over occurred but this early built 1971 car used a bunch of the 1970 parts in the interior
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: C_B5] #2277463
03/28/17 12:37 AM
03/28/17 12:37 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
1972 Challenger bumper
This bumper also has the cut-outs in the corner though the location seems to be moved forward and more defined compared to the the 1971 bumper which fits the tab molded into the 1972 rubber filler
This difference maybe the result of the stamping process that was used for manufacturing the bumpers
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: holtzdog55] #2277483
03/28/17 01:23 AM
03/28/17 01:23 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Chas
I have this rear bumper removed from a 72 Challenger.
I don't have a 70 to compare to but do you know if 70-71 area shown here underneath the bumperette have the same characteristic, rounded down or is it straight across
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: mccannix] #2277495
03/28/17 01:50 AM
03/28/17 01:50 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Terry,
I have the rear bumpers for all 3 years, 70-71-72, so I can check that area and post photos of any differences
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: holtzdog55] #2283200
04/06/17 03:13 AM
04/06/17 03:13 AM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Terry,
Checked the bumpers and ALL of them [70-71-72] have the same contour as the one shown in your photo - rounded under the bumperette mounting area.
I did notice one difference on the 1970 bumper - the bolthole that is used to mount the bumperette is "round" and NOT "oval" shaped
Re: 70-71 & 71-72 front and rear challenger bumpers the same? [Re: holtzdog55] #2283245
04/06/17 10:03 AM
04/06/17 10:03 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Thanks for taking the time to check and provide this information up
