Page 3 of 5 1 2 3 4 5
Re: Trick Flow 270 intake and valley pan? [Re: AndyF] #2262254
03/02/17 04:33 PM
03/02/17 04:33 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
May be an optical illusion.......
Seems the outer ports fit the gasket better than the inner ports?
What is the width and height of the trick Flow window?
BTW, that's an Old gasket..... I updated and modified that application years ago.
Re: Trick Flow 270 intake and valley pan? [Re: sasquatch] #2262267
03/02/17 05:25 PM
03/02/17 05:25 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By sasquatch
yeah well try to find a standard port dominator intake?????Nothing that I know of.
RB
- MP M1 4500
- Edelbrock SV 2891
B - Only the MP M1 4500 AFAIK...
I have no idea if those MP intakes are available any more, either.
EDIT: And any MW intake + a tub of Belzona! bondo
grin
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262268
03/02/17 05:26 PM
03/02/17 05:26 PM
AndyF Offline
AndyF  Offline
Intake ports are 2.63 x 1.34 so they are smaller than most gaskets. I guess they fit the FelPro 1218 but I don't have a set of those gaskets on the shelf.
Re: Trick Flow 270 intake and valley pan? [Re: AndyF] #2262301
03/02/17 06:56 PM
03/02/17 06:56 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
It wouldn't take much to get a 337 intake to that size.
Re: Trick Flow 270 intake and valley pan? [Re: AndyF] #2262308
03/02/17 07:32 PM
03/02/17 07:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The Superformance gasket "should" fit that port
2.660" x 1.365"
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262329
03/02/17 08:23 PM
03/02/17 08:23 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Brad
You said Mopar intakes as if we can just order one up like they have them in stock. NOT! And not going to either. Swap meet or egag. That super victor is not stock port window and would take one heck of a motor as the volume on that is pretty serious. Not to mention hood clearance issues. I used to drill and weld up the Team Gs but that is a pain. Just not much to crow about. I believe that the Victor and the Trick flow both would be great with a 4500 flange.
Todd
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262383
03/02/17 10:36 PM
03/02/17 10:36 PM
Andrews,In. U.S.of A.
67_Satellite Offline
After seeing the 240 T.F. head first hand, making a mold and comparing it to the "old standard" Perf. R.P.M.,and flow testing it,it is clear what would need to be done to the 240 to take it to M.W. size.A slight casting modification(add material) to half of the intake port, a different c.n.c. program, and an offset rocker requirement. If trick flow is going to try to sell a "big" port head,I think they would do themselves a favor by making the obvious changes which would make the head what the customer would expect in a M.W. head.The "last half"of the port has enough size,and a good looking profile,to support a much larger upstream cross sectional area. After developing the head in a logical fashion, make a dedicated intake to feed the necessary airflow to match the head.Build it and they will buy.
Re: Trick Flow 270 intake and valley pan? [Re: sasquatch] #2262388
03/02/17 10:44 PM
03/02/17 10:44 PM
BradH Offline
BradH  Offline
Brad
You said Mopar intakes as if we can just order one up like they have them in stock...
Bullsh!t. I said very clearly that I did not know if the MP intakes were even available.
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262431
03/03/17 12:02 AM
03/03/17 12:02 AM
AndyF Offline
AndyF  Offline
I'd like to see a raised port standard port head. The extended face on the 270 head moves the port window up in the casting and gives a straighter shot to the back of the intake valve. I think a high port 240 head would be a killer. I'm sure it would pick up power over the low riser 240 head and TF could make it with this same casting.
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262452
03/03/17 12:27 AM
03/03/17 12:27 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Calm down Brad
I was just TRYING to be funny and failing evidently. No Mopar has discontinued them and yes I did get your Belzona joke.
Larry Smith just tuned up a set of 270 heads and got some sweet intake numbers but not great exhaust. He is coming over tomorrow and we are going to mock up a 440-3 intake and an Indy valley plate to see how that will work. Just trying to figure out the easiest way to get these on a motor until Trick flow gets all of it produced. (sorry cannot do flow numbers as the customer is trying to be hush hush about it). BUT think really good 440-1/Victor on the intake not so great exhaust.
Todd
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262471
03/03/17 12:50 AM
03/03/17 12:50 AM
Texas
RustyM Offline
RustyM  Offline
Texas
I too look forward to seeing the results of your work.
Re: Trick Flow 270 intake and valley pan? [Re: RustyM] #2262482
03/03/17 01:18 AM
03/03/17 01:18 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
so do I
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow 270 intake and valley pan? [Re: sasquatch] #2262741
03/03/17 04:06 PM
03/03/17 04:06 PM
BradH Offline
BradH  Offline
Calm down Brad
beer
Re: Trick Flow 270 intake and valley pan? [Re: sasquatch] #2262768
03/03/17 05:03 PM
03/03/17 05:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Edelbrock SV 2891; std port, 4500 flange, RB motor
Re: Trick Flow 270 intake and valley pan? [Re: AndyF] #2262769
03/03/17 05:07 PM
03/03/17 05:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
It's called a Victor head wink
350+cfm from a true std port opening.
Re: Trick Flow 270 intake and valley pan? [Re: 70VcodeCoronetRT] #2262772
03/03/17 05:20 PM
03/03/17 05:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
I have to chuckle at the notion that you "can't" make a TF 240 head into a MW head.
Will it have the "correct" taper throughout the length of the runner to be a high end "race" head?
No.
But......... They would still be more spacious down stream of the pinch than an original MW head, or the MW versions of the stage 6 heads...... And people have been able to make decent power from both of those.
There is no doubt in my mind that a set of TF 240's, opened up to facilitate the use of a MW intake manifold would work just fine, and make more power on a suitable build than the same heads with a std port opening and intake manifold.
Since the 240's are also std port height, opening them to MW size and running the 337 intake would be a nice combo that would eliminate the need for a valley cover.
Re: Trick Flow 270 intake and valley pan? [Re: fast68plymouth] #2262791
03/03/17 06:15 PM
03/03/17 06:15 PM
BradH Offline
BradH  Offline
And a 5" hood scoop. no
Re: Trick Flow 270 intake and valley pan? [Re: fast68plymouth] #2262798
03/03/17 06:22 PM
03/03/17 06:22 PM
BradH Offline
BradH  Offline
INTAKE - AVG (4)
0.100 -- 75.0
0.200 -- 151.3
0.300 -- 220.1
0.400 -- 280.3
0.500 -- 326.1
0.550 -- 338.2
0.600 -- 346.0
0.650 -- 350.5
0.700 -- 355.5
0.750 -- 346.7
EXHAUST - AVG (4) - W/ 2” PIPE
0.100 -- 55.0
0.200 -- 116.2
0.300 -- 154.9
0.400 -- 194.0
0.500 -- 223.3 -- 237.6
0.550 -- 233.3 -- 249.2
0.600 -- 241.3 -- 258.5
0.650 -- 247.2 -- 267.5
0.700 -- 251.8 -- 273.5
0.750 -- 255.4 -- 278.3
Sorry, sometimes I can't help myself. tonguue
Re: Trick Flow 270 intake and valley pan? [Re: fast68plymouth] #2262818
03/03/17 07:03 PM
03/03/17 07:03 PM
AndyF Offline
AndyF  Offline
Umm yeah but that is a Victor head with all the Victor weirdness....
Re: Trick Flow 270 intake and valley pan? [Re: AndyF] #2262839
03/03/17 07:24 PM
03/03/17 07:24 PM
BradH Offline
BradH  Offline
My doctor prescribed me these little pills to help me deal with the Victor weirdness... and the voices in my head... and those flying pink spotted polar bears I see occasionally in my backyard. Life is good.
