Brake Lining Edge Codes
#2260239
02/27/17 01:05 AM
02/27/17 01:05 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Edge codes were a practice established by manufactures. In general they don't seem to be government mandated, but something the industry found helpful for themselves and maybe because the OEMs wanted it. However, since I last looked at this two states have mandated a phased reduction of certain lining materials and a revised edge code is being used to show the compliance level of the material. The marking standard is SAE J866 The first letters represent the manufacturer. (web search for a AMECA list of edge codes for abreviations) The next segment is the material. This is followed by a two letter Friction Code. The Friction code is based on the SAE J661. The new marking standard adds onto that as shown. [img] https://www.toyota-4runner.org/atta...um-brake-shoe-replacement-leaf_codes-jpg[/img] Not all manufacturer's complied with marking the old friction code when selling aftermarket pads and shoes. But most did. The J661 specifies a pretty basic test to come up with a coefficient of friction in two temperature ranges: First letter represents the "Normal" test coefficient of friction (some interpret as 0-250 degrees F) Second letter represents "Hot" coefficient of friction from (some say representative of 200-600 degrees F) D Over 0.15 up to 0.25 E Over 0.25 up to 0.35 F Over 0.35 up tp 0.45 G Over 0.45 up to 0.55 H Over 0.55 So for example a shoe marked ED would suggest it looses friction once over 200 or 250 F. On drum brake, especially in the front, that could mean a notible loss in braking when hot and increasing force needed on the pedal just to get maintain the stopping power. Maybe on the rear effect would not as bad and even reduce possibility of lock up. Keep in mind these ratings only are a rough indication. For example they don't show the trends from 200 to 600 F, and the range of friction coeficient within each letter designation is really wide. They also don't reflect other real application characteristics, just friction of a sample against a turning wheel. As far as the temperatures go, an article in SHO Times gives some idea of how hot an undersized OEM brake can get. These are heavy cars and the front disks were pretty small. "...measured 385 F on my front rotors in rush hour traffic on a 45 mph street because of several sequential stoplights. (I have an 89 SHO with 10.1 in. rotors.) ...four back to back 60 mph stops generated 550 F."
Re: Brake Lining Edge Codes
[Re: Mattax]
#2260412
02/27/17 12:42 PM
02/27/17 12:42 PM
Posts: 22,697 Bitopia
jcc
Bitopia
Very nice. Thank you. This should go right to archives after it gets discussed.
[Re: moparx]
#2262256
03/02/17 05:34 PM
03/02/17 05:34 PM
Mattax
Phila. Pa.
were these tests done with new, properly bedded in linings, or just whatever factory lining was on the particular car being tested ? Neither. The procedure is a series of tests of the friction lining material; not the pads or shoes. A sample of a given size, I think its 1" x 1", is tested on a Chase Machine which has a drum that can be brought to different temperatures by the operator. Therefore friction rating can only be used to compare identical shoes or pads. AFAIK bedding is/was not really an issue with factory or factory replacement brakes. Brake service needs to put them on, adjust the shoes, check the parking brake, road check (maybe) and done. That said, its certainly possible that an aftermarket manufacturer could run the test so that the material is bedded into the drum. Would need to actually know much more about the J661 procedure and testing requirements. An OEM supplier would most certainly be expected to share something like that, if done, with the car's engineers for several reasons. One is that it might fail in independent testing verification during design or production validation. Second, the bed-in procedure has to be so consistant that the resulting performance meets spec every time. Car systems are designed for at least 6 sigma statistical performance..maybe higher, its been a while. Safety systems are often higher anyway. It comes down like this, even 1 failure to be in spec for every 100,000 cars is too high a percentage to be acceptable by any manufacturer.
[Re: Mattax]
#2262412
03/03/17 12:33 AM
03/03/17 12:33 AM
jcc
Bitopia
Car systems are designed for at least 6 sigma statistical performance" OK you lost me, care to explain?
[Re: Mattax]
#2262601
03/03/17 12:43 PM
03/03/17 12:43 PM
Mattax
Phila. Pa.
Sigma is shorthand for Standard Deviation. In brief, standard deviation is how far off from the normal most items will be. Automotive manufacturers implemented statistical quality assurance programs that built into both the design and manufacturing a whole range of practices to insure the final assembly of the subsystem would always be in specification. In brief.If a part is being made there is going to be variation. There will be an average (mean), a maximum and a minumum. If the item is measured and plotted and there are enough samples most of the measurements should fall in the middle. Here's an example I found on-line showing Tire Pressures for a motorcyle. With enough samples, the histogram ends up being shaped like a bell, hence bell curve. Most of the results will be within one standard deviation of the average (mean). Going out plus minus three standard deviations (ie 6 sigma) covers most of the results. So six sigma helps insure minumum defects But if we are making 100,000 parts or filling 500,000 tires we need to know whether its likely that every one will fall within the acceptable plus/minus limits of our product. If we're planning on making a million cars, then statistically 12 sigma as shown below could still potentially have out of spec items. This is why I mentioned that 6 sigma is not enough on safety systems. So in addition to going beyond 6 sigma for safety systems, engineers have always added factors of safety to the design limits.
[Re: Mattax]
#2262615
03/03/17 01:10 PM
03/03/17 01:10 PM
Posts: 19,548 north of coder
moparx
the ultimate goal is 100% defect free, but that is usually unobtainable. what is obtainable, however, [if monitored correctly] is the end consumer gets 100% reliability because no defective product is released for consumption. but we all know that goal is VERY hard to accomplish as well. the company i worked for as a machinist/shift supervisor [before my retirement] practiced 6 Sigma. the objective goal was no defective parts reached the customer. as such, there were many inspections during machining that caught defects before the parts machined went to final assembly. when defects were caught in subsequent steps that were caused in the previous operations of the part in question, i was called upon the carpet even if my crew had nothing to do with the defect. unqualified parts were then sent back for rework [if possible, and i came up with some truly unique ways of repairing things that worked better than the original design called for], or scrapped. and when the company hired unqualified workers, it got bit hard every time.
[Re: Mattax]
#2319241
06/11/17 01:44 AM
06/11/17 01:44 AM
Mattax
Phila. Pa.
Found a summary of the J661 friction test procedure. The description seems to be in line with the test results that can be found on the web (with some effort). This summary comes from an orphaned webpage which in turn appears to reference http://ducatigarage.netfirms.com/brakepads.html which is a defunct website. The Chase Test_______________________________________________________ The Chase Test is used to assign a two character code (e.g. EE, FF, GG, HH, etc) to a specific friction formulation. These characters represent the coefficient of friction when a 1" square piece of friction material is subjected to varying conditions of load, temperature, pressure and rubbing speed on a test apparatus known as the Chase machine. The first letter of the code represents the normal friction coefficient. This is defined as the the average of four test data points measured at 200, 250, 300 and 400 degrees Farenheit. The second letter of the code represents the hot friction coefficient based on a fade and recovery test. We all should know what brake fade is. If you've ever had to use the front brake extensively and found that its effectiveness quickly diminished, that's fade. Recovery is basically the period where the brakes are gradually cooling off. The hot friction coefficient is defined as the average of 10 data points located at 400 and 300F. on the first recovery cycle of the pad; 450, 500, 550, 600 and 650F. on the second fade cycle; and 500, 400, and 300F on the second recovery cycle. __________________________________________________________
