Re: Brake pedal will not return...stays on floor
[Re: Lee]
#2260200
02/26/17 11:59 PM
02/26/17 11:59 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Hi
1969 Roadrunner, power drum brakes. New master, wheel cylinders, and hoses. Brakes will stop car just fine, but brake pedal will not come back up, keeping brakes applied, have to pull pedal up with your foot. Do not know the history on the car, a friend just bought it, drove off the trailer into shop for a cam change and said brake work. Brake booster bad??? New master?...has the booster to master pushrod airgap been adjusted properly? you'll need .020 to .060 airgap
[Re: Lee]
#2260293
02/27/17 02:37 AM
02/27/17 02:37 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
loosen the nut on the brake pedal rod where it goes thru the brake pedal..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2260303
02/27/17 03:13 AM
02/27/17 03:13 AM
Posts: 410 Chicago
Lee
Chicago
loosen the nut on the brake pedal rod where it goes thru the brake pedal.. Did that....... Lee
[Re: Lee]
#2260306
02/27/17 03:39 AM
02/27/17 03:39 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
You might have to hone the piston in the master. If they sit long they tend to get funky in there and won't back out. Had it happen a couple times on my Mopar master I use for racing.
