Re: .035 quench too tight on a 572? [Re: Kelob_pie] #2260667
02/27/17 08:18 PM
02/27/17 08:18 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yup, the .040 would go in if it was me. You will not notice any difference from .035 to .055. And I'm a guy that's ran pistons out of the bore .005
Nice build. Sounds like a great street combo to me. I like motors that crackle. Sounds like I combo I built a few years ago.
Re: .035 quench too tight on a 572? [Re: Kelob_pie] #2261110
02/28/17 04:19 PM
02/28/17 04:19 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
After reading this it has me worried as well. 511 with a .039 gasket and piston .002 out of bore. 6500-7000 max rpm. Todd at competition wedge engines told me to set quench as close to .035-.040, but after reading this i think ill pull the heads and replace gaskets with a .045 or maybe a .050.
Re: .035 quench too tight on a 572? [Re: mopar dave] #2261172
02/28/17 06:42 PM
02/28/17 06:42 PM
Check how high the highest part of the pistons will get when you rock them cold, add .037+ for safety thumbs twocents
Re: .035 quench too tight on a 572? [Re: Cab_Burge] #2261468
03/01/17 02:25 AM
03/01/17 02:25 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Using ICON flat top, left side measures .034 and right .037 quench. All the piston tops are .003 difference left to right. Im just gonna put a .050 multi layer gasket and call it good. That will give .011 more quench.
Re: .035 quench too tight on a 572? [Re: Kelob_pie] #2263593
03/05/17 11:57 AM
03/05/17 11:57 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
If you need new cometics, Don at 4secondsflat FBO has them with the lowest price I have found at $165/pr BB. He suggested I go with a .045, but ICON suggested a .051. I ordered .051. This will put me at a .045 quench. Didn't meen to steal your post, just wanted to contribute some info. Good luck with whatever you do.
