Re: Blown Hemi questions? [Re: Twostick] #2258463
02/24/17 01:15 AM
02/24/17 01:15 AM
Originally Posted By Twostick
I believe the physics dictate that the lower CR theoretically will make more power at the same boost level. A larger volume to pack air and fuel into. More air and fuel equals more power, yes?
Wrong down
The first blown gas hemi motor I built was bigger C.I.(499 vs 496 C.I.) with less compression ratio(7.8 to 1) and it made less HP per C.I. than the smaller motor with more compression ratio made at the same amount of boost and RPM shock
Science and theory is one thing, reality and results in the real world is sometimes different shruggy work
Re: Blown Hemi questions? [Re: hemi-itis] #2258471
02/24/17 01:22 AM
02/24/17 01:22 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'd be looking for gains with the shape of the piston top, flame travel and all that witchcraft. It's safe to assume the new heads flow a bunch more than the old ones?
With that displacement there should be no shortage of NA torque so I'd keep the CR in the 7's if I could and if 8 psi didn't make me smile there's always 10. I think the lower CR gives you that possibility on gas.
Kevin
Re: Blown Hemi questions? [Re: hemi-itis] #2258493
02/24/17 01:52 AM
02/24/17 01:52 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Compression is your friend if you run enough octane
Re: Blown Hemi questions? [Re: FastmOp] #2258525
02/24/17 02:52 AM
02/24/17 02:52 AM
Great Neck,LI,new york
hemi-itis Offline OP
That what I'm thinking.4/5 lbs on the street on pump junk and up the octane when I change the pulley.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Blown Hemi questions? [Re: hemi-itis] #2258529
02/24/17 03:06 AM
02/24/17 03:06 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd go 9.5 on your junk. My turbo car has a lot more then that but I run C-16
Re: Blown Hemi questions? [Re: hemi-itis] #2258634
02/24/17 12:03 PM
02/24/17 12:03 PM
Fast op,do you street drive your car?With 9.5:1 me thinks maybe 3lbs of boost on the street???
Re: Blown Hemi questions? [Re: hemi-itis] #2258683
02/24/17 01:40 PM
02/24/17 01:40 PM
I think 5 to 7 lbs. on the street with 9.5 to 1 compression on 91 octane non ethanol pump swill up twocents
Re: Blown Hemi questions? [Re: hemi-itis] #2258698
02/24/17 02:05 PM
02/24/17 02:05 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nope, I have street cars for that.
My Procharged SRT Challenger is over 10to1 and makes 10 pounds of boost on 93 octane. But on your deal I would stick to 9.5 to 1. Under 8 to 1 is just not efficient and your giving up power.
Re: Blown Hemi questions? [Re: FastmOp] #2258987
02/24/17 11:44 PM
02/24/17 11:44 PM
Parts unknown
590 Challenger Offline
Parts unknown
I think your right, I would think at least 9, you have plenty of power for the street (and you don't seem over concerned with that anyways) and no one wants it to be a turd at the track
Re: Blown Hemi questions? [Re: 590 Challenger] #2260871
02/28/17 02:15 AM
02/28/17 02:15 AM
Looked at the charts today. 9:1 i would have to stay at 3 to 4 lbs on premium pump.
Re: Blown Hemi questions? [Re: hemi-itis] #2260967
02/28/17 12:04 PM
02/28/17 12:04 PM
Parts unknown
Parts unknown
I’m no expert so take this for what it’s worth.
I have heard because of the aluminum heads which dissipate heat so fast you can run your compression normally 1-2 points higher than with iron heads. I have also been told many times more boost can’t make up for low compression (of course it does to some point) I guess you really need to decide where you want it to run its absolute best. On the street or at the track? I would think 7 to one with aluminum heads and more boost at the track it would still move but not be at its best. Maybe you prefer to make it run it’s best on the street.
I don’t think one choice would be best for both but Once again I’m no expert
Re: Blown Hemi questions? [Re: hemi-itis] #2260972
02/28/17 12:14 PM
02/28/17 12:14 PM
Want to be able to burn pump junk and then change fuel & pully and go racing!!
