1970 340 ID/original application #2246285
02/03/17 01:16 AM
02/03/17 01:16 AM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
I have a 1970 340 block and would like to find out what it was originally installed in.
The cast date is 8 or 9/5/70
The front of block stamp is P(or F)340 R32540012
Pan rail stamping is: 0B379684
Any help appreciated,Thanks,Ron
Re: 1970 340 ID/original application [Re: RTSrunner] #2246289
02/03/17 01:20 AM
02/03/17 01:20 AM
New York
rarefish Online content
rarefish  Online Content
New York
No way to tell without a full VIN
Re: 1970 340 ID/original application [Re: RTSrunner] #2246342
02/03/17 03:16 AM
02/03/17 03:16 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
not true
it would've been a 340 Duster
is the VIN stamping easily readable? is it possibly 0B379634
I decoded a fender tag for blush someone??? blush ~7 years ago for VS29H0B379634 shock
scope
Re: 1970 340 ID/original application [Re: RTSrunner] #2246349
02/03/17 03:29 AM
02/03/17 03:29 AM
Pittsburgh,PA
Pittsburgh,PA
Dan's the man!...Again! I knew you would chime in,thanks!It is definitely an 8 in the VIN stamp,very clear. I'll try to post a pic next.
Re: 1970 340 ID/original application [Re: RTSrunner] #2246355
02/03/17 03:43 AM
02/03/17 03:43 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the stamp on the front of the block should be:
FW340P32540012
F = 1970 model year
W = Windsor, ONT engine assembly plant
340 = cu.in.
P = premium fuel
3254 = Thursday 6/25/70 engine assembly date
0012 = engine unit number
VS29H0B379684 would've been scheduled 6/12/70 - is the 3254 accurate? or the car was built LATE, LATE, LATE (missed by 13+ days)
Re: 1970 340 ID/original application [Re: 6bblgt] #2246364
02/03/17 04:07 AM
02/03/17 04:07 AM
Pittsburgh,PA
Pittsburgh,PA
Dan,I'm texting you pics of the numbers
Re: 1970 340 ID/original application [Re: RTSrunner] #2246365
02/03/17 04:09 AM
02/03/17 04:09 AM
Pittsburgh,PA
Pittsburgh,PA
You are correct,it is a P after the 340,not an R, Thx
Re: 1970 340 ID/original application [Re: rarefish] #2246369
02/03/17 04:23 AM
02/03/17 04:23 AM
Pittsburgh,PA
Pittsburgh,PA
I think Dan,6bblGT does a little reverse engineering and has a serious database built. Taking the VIN sequence vs the build plant/factory and cid,etc. as to what model was built where and when.
Re: 1970 340 ID/original application [Re: RTSrunner] #2246380
02/03/17 05:27 AM
02/03/17 05:27 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
VINs were assigned in batches - since '70 Duster production was in excess of 200,000 units the Duster batches are in the 1,000 car neighborhood. shock
Re: 1970 340 ID/original application [Re: 6bblgt] #2246384
02/03/17 07:20 AM
02/03/17 07:20 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
At Hamtramck & LA, they are actually Valiant VIN sequence batches, so the Valiant Dusters VINs are mixed with the Valiant 4-door VINs.
Re: 1970 340 ID/original application [Re: Alaskan_TA] #2246387
02/03/17 08:00 AM
02/03/17 08:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I had it in my head that it was in excess of 250,000 & looked up the Duster number and saw it was short of that number - now I know why? - another 40K+ VALIANT 4-doors up thanks!
they did make a ton of them ..... June 1970 total Valiant production = 43,297 units eek
1970 Plymouth A-body VALIANTs ~260K VS. 1970-1974 E-body ~320K shock
Re: 1970 340 ID/original application [Re: RTSrunner] #2246463
02/03/17 12:35 PM
02/03/17 12:35 PM
Pittsburgh,PA
Pittsburgh,PA
Thanks guys,that's a lot of A-bodies!
Re: 1970 340 ID/original application [Re: RTSrunner] #2246799
02/03/17 08:42 PM
02/03/17 08:42 PM
New York
New York
Let me know what car my G 440 HP2 block came from. The VIN on the block is 1B367187
Thanks...
Re: 1970 340 ID/original application [Re: rarefish] #2246826
02/03/17 09:47 PM
02/03/17 09:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Thanks...
'71 is not my year, but........
JS23V1B367187
Re: 1970 340 ID/original application [Re: Alaskan_TA] #2247022
02/04/17 02:46 AM
02/04/17 02:46 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& someone said you can't tell a 440+6 engine from the VIN stamping whistling
Re: 1970 340 ID/original application [Re: Alaskan_TA] #2247126
02/04/17 12:37 PM
02/04/17 12:37 PM
New York
New York
Thanks...
JS23V1B367187
I wonder if the car still exists?
Re: 1970 340 ID/original application [Re: RTSrunner] #2247127
02/04/17 12:40 PM
02/04/17 12:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Pretty sure it does, happy hunting. :-)
Re: 1970 340 ID/original application [Re: RTSrunner] #2255378
02/18/17 04:34 AM
02/18/17 04:34 AM
Pittsburgh,PA
Pittsburgh,PA
I dug out another one to ID. A 1970 340 also:
Stamped on the front of block is FW340P 3084 0313
Pan rail partial VIN 0B236819
Casting date is XX 69,I have to clean it off more to clarify
Any ideas what this one is from? Dan the man...???
RT
Re: 1970 340 ID/original application [Re: RTSrunner] #2255383
02/18/17 05:04 AM
02/18/17 05:04 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
FW340P 3084 (Tuesday 1/6/70) 0313
Casting date is 11*14*69
for comparison scope also previously reported 340 missing a car (both from '70 Cudas)
FW340P 3087 (Friday 1/9/70) 0027
Pan rail partial VIN 0B236799
Casting date is 11*19*69
Re: 1970 340 ID/original application [Re: 6bblgt] #2255386
02/18/17 05:38 AM
02/18/17 05:38 AM
Pittsburgh,PA
Pittsburgh,PA
Casting date is XX 69 fill in please
for comparison also previously reported 340 missing a car (both from '70 Cudas)
Thanks dan,I'll get the casting number tomorrow.You believe this is from a 'Cuda then? Looks like yet another close VIN sequence motor.It's cool finding this stuff/info! Thanks,RT
