Lash cap damaged valve tips
#2254522
02/16/17 12:54 PM
02/16/17 12:54 PM
Posts: 48 the Netherlands
dutchrunner
the Netherlands
Always thought lash caps protect your valve tips? Found 5 (No 1-2-3-4-5) intake valve tips damaged under lash caps. Tops of all caps are fine and also all rockers. Looks like the valve tip was too soft and now there is like a pin on the same place as the small hole that's in the lash cap. Engine is about 7000 miles street driven. Gen 2 hemi with StageV heads and solid roller efi cam. Wide pad rockers and "street springs". What the xxx happened? No 6-7-8 are fine.
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
Re: Lash cap damaged valve tips
[Re: dutchrunner]
#2254545
02/16/17 01:29 PM
02/16/17 01:29 PM
dutchrunner
the Netherlands
Lash is as per cam instructions. As are the other 3 which are not damaged.
[Re: dutchrunner]
#2254597
02/16/17 02:56 PM
02/16/17 02:56 PM
dutchrunner
the Netherlands
Not sure where the valves came from. Are StageV custom heads Cam specs are known D-1749-13-11/20/13. .659/.631 lift and matching springs. Just trying to find out wat could have caused this. Want to prevent repeat with new valves.
[Re: dutchrunner]
#2254720
02/16/17 07:52 PM
02/16/17 07:52 PM
Posts: 4,457 Washington
madscientist
Washington
I have seen this when the valve train has an issue. It could be not enough spring pressure, too much spring pressure, not enough spring rate, valves too heavy or the big one, push rods that flex, or flex too much.
That will hammer stuff that would not normally ever see damage.
[Re: dutchrunner]
#2254894
02/17/17 02:43 AM
02/17/17 02:43 AM
dutchrunner
the Netherlands
My speedshop called the valve supplier where they bought the valves from when we rebuild the engine. He says it's turning the lascaps and this causes them to eat-up the tips. Changing all intake and installing locking lashcaps. @ Cab_Burge . It's a street engine. average rpm 4000 and max 6000. @ Madscientist . There all checked for spring pressure and installed height.
[Re: BSB67]
#2254969
02/17/17 12:15 PM
02/17/17 12:15 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Ive seen this before. Cam profile are typically more radical on intake side. The valve spring is not keeping the valve under control. Most of us don't have a spintron to test the valvetrain.
You have an unhappy intake valve train. Talk with your cam grinder about your intake lobe profile.
Some things they may tell you may surprise you. Seat pressure and weak springs kill parts. You are getting an early warning. I suspect you have too much valvespring for the lift. Meaning the valvespring is not being cycled properly. If you do not open the valve to .050" from coil bind the spring will dance around. For years we set spring height based on a psi for seat pressure or the manufacturer reccomendation for installed height. PAC has me setting spring height based on full open spring height. Amazing the difference it has made in valvespring life.
I regularly turn 9,000 and get incredible life.
[Re: dutchrunner]
#2255043
02/17/17 03:00 PM
02/17/17 03:00 PM
Posts: 1,505 TN
SCATPACK 1
TN
That is good info Leon. i never new thought of that before. Always just set them for seat pressure and mad sure max lift was not coil bind. I am going to give your set up a try on my next set. Thanks for sharing
Old Geezer Racing
[Re: Leon441]
#2255068
02/17/17 03:55 PM
02/17/17 03:55 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I regularly turn 9,000 and get incredible life. enlightening info, Leon. Now we're learning!! glad I checked in on this thread.
[Re: dutchrunner]
#2255388
02/18/17 06:16 AM
02/18/17 06:16 AM
dutchrunner
the Netherlands
Thanks for this input. Will forward to speedshop. Cam is based on EFI can in Mr. Nedbal's book. Should be right.
[Re: dutchrunner]
#2257971
02/22/17 11:47 PM
02/22/17 11:47 PM
Posts: 80 new york
68HEMIRR
new york
Dutch.....are you setting your lash at operating temperature?.....did this with mine when it was on the dyno......when i got home and was cooled off i checked it cold.....mine grew .019.....something to look into
BORN TO BE WILD
[Re: 68HEMIRR]
#2257995
02/23/17 12:36 AM
02/23/17 12:36 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Dutch.....are you setting your lash at operating temperature?.....did this with mine when it was on the dyno......when i got home and was cooled off i checked it cold.....mine grew .019.....something to look into Did it grow and got wider or did it tighten up when cooled off ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: dutchrunner]
#2258119
02/23/17 11:06 AM
02/23/17 11:06 AM
Posts: 80 new york
68HEMIRR
new york
stage v aluminum heads....keith black aluminum block.....hot lash....22 intake...24 exhaust.....cold lash.....003 intake....005 exhaust.....tightened up by .019
BORN TO BE WILD
[Re: dutchrunner]
#2258330
02/23/17 09:13 PM
02/23/17 09:13 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Leon has it right. There is nothing wrong with the valves or the lash caps. What IS wrong is something in the valvetrain.
Now while it could be too much spring pressure, it could also be too little for how aggressive the intake lobe is and could actually be trying to "throw" the lifter off the cam......OR it falls out from under the lifter on the backside. This beats the hell out of valvetrain parts. How MUCH lift is of little consequence, it's how aggressive the lobe is.
We have guys on Drag Week with cams over an inch of lift and they live just fine. I just have to slow the lobes down and set the parts up right.
HEMI valvetrain is inherently bad already. Mismatched parts make it horrible
