Re: Perfect match
[Re: Old School]
#2255483
02/18/17 02:06 PM
02/18/17 02:06 PM
BradH
Just your basic 93-octane "street car", right? Still waiting to hear what type & size of tires you're planning to use on the street. Oh, any intentions of taking it to the track on occasion?
Re: Perfect match
[Re: BradH]
#2255491
02/18/17 02:21 PM
02/18/17 02:21 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Just your basic 93-octane "street car", right? Still waiting to hear what type & size of tires you're planning to use on the street. Oh, any intentions of taking it to the track on occasion? Now it has 275 60 r15 drag radials on it. I think I can get a little bit bigger tire in it. I'm hoping the lightweight will help somewhat with traction. I'm sure I will take it to the track sooner or later. but really I just built it to be a street car. Also all my "street cars"require race gasππ
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Perfect match
[Re: Old School]
#2255495
02/18/17 02:32 PM
02/18/17 02:32 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
NICE ! Question; What did you use for attaching your breathers on the valve covers ? ( i am doing a 500" INDY motor and need to drill my valve covers and curious what you did with yours,,baffles also ? ) Did you have to use a "smaller" MSD distributor ( same issue,, curious how it clears the INDY covers ) thanks,,,NICE car and motor, Doug
Re: Perfect match
[Re: Airwoofer]
#2255521
02/18/17 03:44 PM
02/18/17 03:44 PM
Old School
Virginia Beach, VA
I think you should have milled off the brand name from the intake like you (and I) did with the valve covers. Nice fish, and it shoulld be a real blast to drive. Yes I am not a fan of Indy either! All my other junk is indy also, so I'm trying to keep everything compatible...
Re: Perfect match
[Re: BradH]
#2255553
02/18/17 05:22 PM
02/18/17 05:22 PM
Old School
Virginia Beach, VA
I guess you must love a challenge. I don't think you'll be able to tell whether the road is wet or dry w/ that combination. I'm not scared. It's nothing that I'm not used to with all the other Cars tooππ
Re: Perfect match
[Re: 69CHARGERMD]
#2255626
02/18/17 08:25 PM
02/18/17 08:25 PM
Old School
Virginia Beach, VA
NICE ! Question; What did you use for attaching your breathers on the valve covers ? ( i am doing a 500" INDY motor and need to drill my valve covers and curious what you did with yours,,baffles also ? ) Did you have to use a "smaller" MSD distributor ( same issue,, curious how it clears the INDY covers ) thanks,,,NICE car and motor, Doug Thanks Doug I appreciate it. The regular MSD Pro Billet distributor works with the Indy valve covers no problem. I use these Mr Gasket grommets with the breathers. Theese grommets do not require any baffles.
Re: Perfect match
[Re: Old School]
#2256081
02/19/17 05:05 PM
02/19/17 05:05 PM
Posts: 31,019 Oregon
AndyF
Clutch is a distant memory. I have zero concerns about the clutch. It's a McLeod dual disk. Same one I run in all my cars. The other cars are a lot heavier and with a higher gear ratio. These clutches are almost bulletproof I have one that is over 20 years old without being touched!ππ Here are a couple pictures of the dual disc setup that I mentioned in the PM.
Re: Perfect match
[Re: Twostick]
#2256232
02/19/17 09:14 PM
02/19/17 09:14 PM
Old School
Virginia Beach, VA
How is that clutch for grabbing with solid hubs in the disks?
Not sure if it's related but when they went to ceramic disks on big trucks in the late 70's they had solid hubs. The clutch pedal might as well have been a toggle switch. They went to torsion springs in the hubs.
Kevin I use that same clutch in all the cars. they engage very smooth. I think it has to do with the middle plate....
Re: Perfect match
[Re: Streetwize]
#2257872
02/22/17 07:59 PM
02/22/17 07:59 PM
Old School
Virginia Beach, VA
So cool, my friend!
Larry and Todd are awesome to work with, they are both friends of my buddy Hollis Page ( HpEngines)
Any dyno sheets on the intake comparison? Pretty amazed the little 337 still made as much as it did as high up as it did on THAT BIG 588" MOTOR!
Just wanted to see at what RPM the big indy started to really walk the dog on it. Hey Bobby! I posted the dyno sheet for the two manifolds on the first page of this post. I'll see if I can post it again. On my motor it still made 850 horsepower with the 337 manifold. It may have made more with a bigger 4150 carb. Todd only had an 850 double pumper at Dyno Time. On the dyno sheet the two top lines are the Dominator and the two bottom lines are the 850 double Pumper. Look how dramatically the power falls off with the 337 manifold....
Re: Perfect match
[Re: twayne24365]
#2257875
02/22/17 08:06 PM
02/22/17 08:06 PM
Old School
Virginia Beach, VA
how do you like the QuickTime bell? I have one for my big block dart and was wondering if there are any problems as far as the fitment an linkage set up? man don't get me started on this QuickTime bellhousing. All my other cars use a Lakewood bellhousing which has no problems. This is my first QuickTime bellhousing I mainly got it because it's half the weight of a Lakewood. For starters none of the front bearing retainer adapter rings are even close to being correct. I had to get their engineering department to custom make me one. The bolt kit is not complete like the lakewood is. I have not had a chance to mock up the linkage yet when I do I will post results. So far though not really impressed with it. But it is lighter!
Re: Perfect match
[Re: Old School]
#2258071
02/23/17 03:00 AM
02/23/17 03:00 AM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
man don't get me started on this QuickTime bellhousing. All my other cars use a Lakewood bellhousing which has no problems. This is my first QuickTime bellhousing I mainly got it because it's half the weight of a Lakewood. For starters none of the front bearing retainer adapter rings are even close to being correct. I had to get their engineering department to custom make me one. The bolt kit is not complete like the lakewood is. I have not had a chance to mock up the linkage yet when I do I will post results. So far though not really impressed with it. But it is lighter! My brother used one in his Charger, a 6.1 with a tremec, as part of a keisler kit. When we went to install the trans onto the bell housing we ran into the same bearing retainer problem. Keisler told him the transmission bolts would line up the transmission and not to worry. When he contacted Quicktime they were unconcerned about the lack of a properly centred bearing retainer. We had a local machinist make a adapter ring to go onto the transmission. The starter was also a problem no real way to properly locate the starter like a stock bell housing. Just trial and error until you find the right spot and hope the starter bolts stay tight. i don't like them at all. I never found much feedback about quicktime on this site, I always wondered if others had problems with them as well. Is a Lakewood much better?
1974 Roadrunner
1967 Charger
Re: Perfect match
[Re: Saskabusa]
#2258077
02/23/17 03:15 AM
02/23/17 03:15 AM
Old School
Virginia Beach, VA
man don't get me started on this QuickTime bellhousing. All my other cars use a Lakewood bellhousing which has no problems. This is my first QuickTime bellhousing I mainly got it because it's half the weight of a Lakewood. For starters none of the front bearing retainer adapter rings are even close to being correct. I had to get their engineering department to custom make me one. The bolt kit is not complete like the lakewood is. I have not had a chance to mock up the linkage yet when I do I will post results. So far though not really impressed with it. But it is lighter! My brother used one in his Charger, a 6.1 with a tremec, as part of a keisler kit. When we went to install the trans onto the bell housing we ran into the same bearing retainer problem. Keisler told him the transmission bolts would line up the transmission and not to worry. When he contacted Quicktime they were unconcerned about the lack of a properly centred bearing retainer. We had a local machinist make a adapter ring to go onto the transmission. The starter was also a problem no real way to properly locate the starter like a stock bell housing. Just trial and error until you find the right spot and hope the starter bolts stay tight. i don't like them at all. I never found much feedback about quicktime on this site, I always wondered if others had problems with them as well. Is a Lakewood much better? I think it is much better and also twice as heavy
