Re: degreeing cam
[Re: junkyardmaxie]
#2252376
02/12/17 04:52 PM
02/12/17 04:52 PM
Posts: 4,457 Washington
madscientist
Washington
its it a big deal to degree the cam for street use or just put it in straight up ? s/b 340 520 lift comp solid lifter cam Yes, it's a big deal. If you don't do it, how will you know where the cam is timed? If you have tuning issues, or performance problems that will be one thing you can't cross off your list.
Re: degreeing cam
[Re: junkyardmaxie]
#2252410
02/12/17 05:55 PM
02/12/17 05:55 PM
Posts: 31,112 Oregon
AndyF
its it a big deal to degree the cam for street use or just put it in straight up ? s/b 340 520 lift comp solid lifter cam Classic trade off of time and money. If you have the time and you have the tools it is a good thing to do. If you want to learn more about how an engine runs then it is a good thing to do. If you're trying to squeeze the last little bit of performance out of your engine then it something that you need to do. If you're just trying to get the sucker running so you can get to work on Monday then skip it.
Re: degreeing cam
[Re: junkyardmaxie]
#2252583
02/12/17 09:55 PM
02/12/17 09:55 PM
Posts: 43,367 Bend,OR USA
Cab_Burge
Degree that rascal and try at least 3 to 5 degrees advanced on the intake lobes What lobe separation angle is this cam ground on? 340 motors aren't torque monsters to start with so by advancing the cam you will increase the bottom end torque for a very small amount of loss on top end HP Torque is what moves the cars,(monsters ) not HP
Re: degreeing cam
[Re: junkyardmaxie]
#2252709
02/13/17 12:38 AM
02/13/17 12:38 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I have not installed a cam withOUT degreeing it in since I was a teen
Re: degreeing cam
[Re: Pacnorthcuda]
#2252742
02/13/17 01:21 AM
02/13/17 01:21 AM
hemi-itis
I have not installed a cam with degreeing it in since I was a teen Ummmm..........I'm thinking that's not what you meant. Right you are! I fixed it
Re: degreeing cam
[Re: junkyardmaxie]
#2252790
02/13/17 03:12 AM
02/13/17 03:12 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
its it a big deal to degree the cam for street use or just put it in straight up ? s/b 340 520 lift comp solid lifter cam For a street car with a SB 340, and that cam yes, You will definitely want it advanced. At minimum, put it in 4* advanced. Most newer timing gears have up to the 4* advanced and 4* retarded adjustments. Pick the 4* advance slot if you decide Not to degree it. No way, would I put that cam in a street car, straight up.
Re: degreeing cam
[Re: Sport440]
#2253064
02/13/17 06:03 PM
02/13/17 06:03 PM
dogdays
The most important thing is, your question is wrong from the start. You have no way to really know if the cam is installed straight up unless you degree it in.
The advice to advance the cam 4 degrees makes sense, except for one little thing.....Most any street cam you buy will have the cam ground 4 degrees advanced with the cam installed dot-to-dot, assuming that all the keyways and dots are in the right places. So installing it with the timing set in the 4 degrees advanced setting will probably put the cam ahead by 8 degrees.
If you're using a single pattern cam, straight up will be when the engine is at TDC and the intake and exhaust lifter are even with each other. This is called "split overlap" and is a quick and dirty way to see if you are close. The more modern asymmetrical lobes won't be as close as older symmetrical lobes, but probably close enough. If the exhaust lobe is larger, then the lifters will be even when the cam is advanced. (I think I'm right on this.)
If you are asking the question then you probably aren't building an engine looking for that last tenth. You're probably OK just installing dot-to-dot. But if you have the time, it's worth it to learn how it works. Your life will be richer for it.
R.
Re: degreeing cam
[Re: dogdays]
#2253108
02/13/17 07:44 PM
02/13/17 07:44 PM
Sport440
Canton, Ohio
Yep, your right on both statements.
Further, if the OPs cam is a single pattern he will be able to tell if its advanced from straight up, intake and exhaust lifter Even with each other by this rule of thumb.
Every 0.004-0.005 equates to about 1* of camshaft duration. So if the cam were advanced say 4*, the intake lifter would be .016/.020 higher then the exhaust. Probably be better to just use 0.0045 though.
Now none of this works unless your absolutely sure your at TDC.
By the way, those calculations are from way back old school from Joe Sherman. I had my own, but cant find them. While cams have different rates of lift, they all move pretty much the same down low on overlap, but hence the .004-.005 per 1 degree.
R.
Re: degreeing cam
[Re: scottb]
#2253111
02/13/17 07:55 PM
02/13/17 07:55 PM
Posts: 20,205 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Does anyone make the off set key ways anymore mp no longer carries them Summit has them.
Re: degreeing cam
[Re: scottb]
#2253152
02/13/17 09:02 PM
02/13/17 09:02 PM
Cab_Burge
Try Mr. Gasket at Summit or Jegs. I keep several of each degree offsets and types, SB cam and early hemi as well as for BB cranks and bushings for the cam gear on B and RB motors. I've seen more than one 3 way BB three bolt timing set have the can gear dot off by one tooth Which is 12 degrees
Re: degreeing cam
[Re: Cab_Burge]
#2253322
02/14/17 01:29 AM
02/14/17 01:29 AM
RapidRobert
Agreed, I would definitely degree it then you will know if you are good & you will know how to do it in the future. it takes a bit of reading to catch on to how it works but once you grasp it it is simple (it is when the intake lobe reaches max lift, how many degrees is that exact point past TDC) IE 106 degrees and if that lobe peakes earlier such as only 102 degrees past TDC then the cam is advanced as it is peaking earlier.
Re: degreeing cam
[Re: RapidRobert]
#2253565
02/14/17 03:32 PM
02/14/17 03:32 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Agreed, I would definitely degree it then you will know if you are good & you will know how to do it in the future. it takes a bit of reading to catch on to how it works but once you grasp it it is simple (it is when the intake lobe reaches max lift, how many degrees is that exact point past TDC) IE 106 degrees and if that lobe peakes earlier such as only 102 degrees past TDC then the cam is advanced as it is peaking earlier. And the reason it gets confusing when reading how to do it, is because the whole 'use a piston stop, spin one way, note the degree, spin backwards the other way, note the degree, subtract the 2, divide by 2, move gear wheel that far' process and conversely before max lift, past max lift is because of dwell times where the piston sits at TDC for a degree or 2 of crank rotation, and how the valve hangs at max lift for a few degrees, and you're trying to find the exact point in the middle It's confusing to read the steps but once you start doing it, it just clicks and makes sense
**Photobucket sucks**
