Re: School me on balancers... [Re: StealthWedge67] #2253864
02/15/17 01:27 AM
02/15/17 01:27 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Originally Posted By StealthWedge67
Dampers are one of those things I hear people say you shouldn't scrimp on, but how often do you see a damper cause a problem? I suppose the more RPM's a motor sees, the more you need to consider this piece (??). My 451 sees 6400, and I've never had a problem with this one:
https://www.summitracing.com/parts/pfs-8...=MobileSwitchNo
popcorn
That would be me. Twice. Summit SFI junk. Ring became unbonded to the hub. I caught the first one during a routine freshen up, but the second actually came off of the hub. Good thing it was at idle in the garage! Called Summit both times, acted like it was no big deal.
Never again will I trust a "bargain" dampener.
Re: School me on balancers... [Re: cudadoug] #2253866
02/15/17 01:30 AM
02/15/17 01:30 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
popcorn
Yeah, I readily acknowledge that it's something I should upgrade. Especially since I'm racing the car more and more these days.
Re: School me on balancers... [Re: OhioMopar] #2253872
02/15/17 01:40 AM
02/15/17 01:40 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Innovators West here too.
Re: School me on balancers... [Re: OhioMopar] #2253915
02/15/17 03:57 AM
02/15/17 03:57 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I had a CAT fluid balancer on my 493. 6 years after I built it, it went back to get aluminum caps. I got a call saying the bearings were still like new and that I could reuse them if I wanted. Changed them but that was a cheap balancer and I beat on that motor for 6 years
Re: School me on balancers... [Re: OhioMopar] #2253943
02/15/17 10:24 AM
02/15/17 10:24 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have the TCI rattler on both motors and no noise when running only when you shut down and the plates relax one quick rattle. I was told that the design was barrow from fighter planes in ww2.
Re: School me on balancers... [Re: an8sec70cuda] #2253991
02/15/17 01:10 PM
02/15/17 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By an8sec70cuda
I have had good sevice from ATI and Fluidamper. I tried one BHJ damper on a fairly mild 500+ hp 440 and it slipped the outer ring after about 6 months of use. No more BHJ for me.
Only bad thing about ATI is you better spray it w/ clear coat before you put it on. Otherwise you'll barely be able to read the timing marks after a year or so.
Maybe where you live but not in Cally.............lol I went from a Fluidamper to an ATI and the later is glass smooth compared to some harmonics from the fd..............
