Re: Fuel Pump Replacement - 1970 440 motor [Re: NTOLERANCE] #225189
02/19/09 12:30 AM
02/19/09 12:30 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
If the rod won't go up far enough to allow the fuel pump arm to go all the way in, just take the coil wire off, bump the starter a bit and get the fuel pump eccentric to move out of the way. This will allow the pump arm to go all the way in or close to it. The bolt towards the firewall can be a pitb to get started sometimes. Try to get it started by hand before you put a socket on it.
Re: Fuel Pump Replacement - 1970 440 motor [Re: RapidRobert] #225190
02/19/09 10:33 AM
02/19/09 10:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A slight dab of brown wheel bearing grease works good. You're not using enough to have any effect on the lube qualities of your eng oil
