Engine installation from bottom help #2238707
01/21/17 10:03 PM
01/21/17 10:03 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
Ok guys,
I have seen a bunch of you install engine from the bottom and I am trying to plan putting my engine trans in this too. I ordered snowmobile dollys to use. I have a engine hoist. I have a couple of questions though.
1 How heavy is the front of a 1971 Dodge challenger?
2 The bumper/grill is on the car. Can I get square tube steel, and attach it the holes in the frame just in front of the k member, then attach the hoist to the center of that to lift?
3 It seem like I have to lift the front very high. Is there any problems lifting the car this high? Like the hoist wont go high enough, or attaching like I said above The angle of the hoist will hit the front grill support or the rear of the car hits the ground?
The car is a 1971 Dodge Challenger Convertible and the engine is a 440 6 pack. Any help / thoughts would be greatly appreciated.
Sanman68
Re: Engine installation from bottom help [Re: sanman68] #2238738
01/21/17 10:43 PM
01/21/17 10:43 PM
I ain't never done a bottom eng install but I have jacked the front way up with a hoist for other issues & I dont see a problem bolting on a transverse piece of stout metal then hooking the hoist chain to that & I would bolt the chain to each side then run the chains up to the hoist for a more stable lifting. I would take the grill and any other potential interference item off & on a regular eng install (from the top) I remove EVERYTHING such as steering column/master cyl which some dont apply to this situation but just saying. remove more items than you think you need to & that will be the exact amt to have out of the way.
Re: Engine installation from bottom help [Re: sanman68] #2238748
01/21/17 11:06 PM
01/21/17 11:06 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
This is how I do it.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Engine installation from bottom help [Re: sanman68] #2238752
01/21/17 11:13 PM
01/21/17 11:13 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I made a simple bar that fits in the location you described. I reinforced a few furniture dollies to roll the engine and trans on.
The cherry picker works great for this technique without having to remove the bumper & grill. The last picture is the 408 Magnum from my '68 on the dollies. I didn't have to remove the bumper or grill for that install either.
This was the first time in nearly 40 years that I didn't drop the engine in from the top. I'll never do it the old way again.
I did this in my garage with an 8" ceiling by myself.
Re: Engine installation from bottom help [Re: sanman68] #2238757
01/21/17 11:17 PM
01/21/17 11:17 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
I like your lifting bracket. That's what I had I mind.
Sanman
Re: Engine installation from bottom help [Re: sanman68] #2238761
01/21/17 11:20 PM
01/21/17 11:20 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Sanman
It was made from some scrap metal I had laying around. The bolts keep it from moving once its in place.
Re: Engine installation from bottom help [Re: sanman68] #2250756
02/09/17 11:27 PM
02/09/17 11:27 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
I got the engine installed from the bottom. Thanks for all your help. I added a video link. It went in pretty easy.
Sanman68
https://www.youtube.com/watch?v=nam9tta49q8&t=20s
Re: Engine pointed wrong way in picture [Re: sanman68] #2250858
02/10/17 02:14 AM
02/10/17 02:14 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
In the first picture, the engine is pointing the wrong way. I hope that you correct this because I don't know how many modifications you'd have to make to get it to fit in there that way.
Good luck.
Re: Engine installation from bottom help [Re: Jjs72D] #2250992
02/10/17 12:18 PM
02/10/17 12:18 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I install mine with the rear wheels on the ground. With the engine dolly I use and the lift holding the car I've found it easier to install the trans cross member on the trans first and then use that as your first point of contact as the body is bring lowered down. Put those 4 bolts in and that helps align everything else. Come down a little lower and catch the 2 rear K frame bolts and then down a little more for the front two.
Tighten the 4 K frame bolts and then use the lift to bring the car back up and set on jack stands. up
It literally takes 10-15 minutes.
...FAFO...
Re: Engine installation from bottom help [Re: sanman68] #2251016
02/10/17 12:58 PM
02/10/17 12:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
US Cartools lift brackets and engine dolley
Re: Engine installation from bottom help [Re: sanman68] #2251020
02/10/17 12:59 PM
02/10/17 12:59 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Engine installation from bottom help [Re: ScottSmith_Harms] #2251099
02/10/17 03:30 PM
02/10/17 03:30 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Engine installation from bottom help [Re: JMCFAN] #2251195
02/10/17 06:14 PM
02/10/17 06:14 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
The US tools dolly and lift setup are awesome. If you have the money or are going to do lots of cars get the US tool dolly and lift brackets.
But if you are only doing 1 car (or don't have the cash like me) it can be done for cheap. The 36" metal bar I got for $26 from the local metal store and I made the cart for about $25. The side benefit is I didn't have to remove the bumper and grill.
With your advise I got this done and appreciate all the help. The engine went it easy without damaging anything. It reduces the amount of time wrenching over the fenders cause most everything is installed already. I had never installed a engine like this before and wanted to show somebody else that it can be done.
Sanman68
Re: Engine installation from bottom help [Re: sanman68] #2251216
02/10/17 06:49 PM
02/10/17 06:49 PM
BDW Offline
BDW  Offline
How do you guys get the rear high enough to get the tires up on blocks?
Re: Engine installation from bottom help [Re: sanman68] #2251241
02/10/17 07:46 PM
02/10/17 07:46 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
A Challenger front end wo engine/Fenders/grill/bumper is light enough I was able to pick it up by myself. So an assembled front end cant be but 200-300 pounds more.....
There's no need to raise the rear IMHO.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Engine installation from bottom help [Re: sanman68] #2251284
02/10/17 09:02 PM
02/10/17 09:02 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
I used a floor jack. Nothing complicated. I may not have needed the blocks but I thought I wouldn't need to raise the car as high if I used them. It also made hooking up the crewmember, exhaust and other stuff easier.
Re: Engine pointed wrong way in picture [Re: Jjs72D] #2251354
02/10/17 10:52 PM
02/10/17 10:52 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Did you install it the way it looked in the picture ?
Re: Engine pointed wrong way in picture [Re: Jjs72D] #2251391
02/11/17 12:17 AM
02/11/17 12:17 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Nice job! Way cool that you did it without taking the front of the car apart too.
The next one I do I want to give this method a try. Sure looks easier than wrestling it in from the top while trying to get the headers to fit, etc.
Re: Engine installation from bottom help [Re: sanman68] #2251487
02/11/17 09:13 AM
02/11/17 09:13 AM
None
71rm23 Offline
71rm23  Offline
None
Sanman68
That's pretty much the same way I did it. Good job smile
Re: Engine installation from bottom help [Re: ScottSmith_Harms] #2251569
02/11/17 12:38 PM
02/11/17 12:38 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Dang Scott, you do some impressive work. Are you going to Spring Fling & Mopar Track Day at Willow Springs this year?
