Re: Project big block a body headers.
[Re: mikeysmopars]
#2250643
02/09/17 09:23 PM
02/09/17 09:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would run your engine through my program if I was back home to tell you what you need for a header but I know for fact that they are way to long.. the transition on the step is way off also... sorry but I wont be home for a month or so
[Re: Sport440]
#2250651
02/09/17 09:35 PM
02/09/17 09:35 PM
MR_P_BODY
Definitely long Mike, probably the longest ive ever heard of. The 2"1/4 will be more forgiving, how much, I don't know. Its good to know he can cut 12" or more so inches off if need be. And he probably will. Be looking forward to his next outings results. Problem is that they will be a complete re-design if he cuts any out of them... next question would be if its a full chassis car.. that would making changing them easier
[Re: mikeysmopars]
#2250744
02/10/17 12:09 AM
02/10/17 12:09 AM
Posts: 8,373 fredericksburg,va
cudaman1969
fredericksburg,va
Have you tried to put them in the car yet?Did you think about putting a slip tube fit splitting the length? They were built on the car and I didn't want slip tubes. as big as these are they come out one piece. I had to cut into the firewall to have them go back far enough for a 26" tall front runner and I'm boxing them in as we speak. I'll send more pix after they are done. I've seen pipes the long on a basically stock 440 Duster, went 12.50s carrying the wheels 4 ft in the air out 50-75 ft. But my biggest question, what are those bumps-marks on the frame tubing??
[Re: mikeysmopars]
#2250757
02/10/17 12:28 AM
02/10/17 12:28 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I'll be anxious to see your track results, especially since you've already ran some other fenderwells and underchassis headers on the car. I honestly don't think they'll slow the car down much if any at all, and the car has to be very easy to work on the way it is set up, which I'm sure was your main goal.
[Re: mikeysmopars]
#2251167
02/10/17 06:06 PM
02/10/17 06:06 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
Be interesting to see how they work. They are definitely long but you have enough data from other headers to compare with for sure.
[Re: mikeysmopars]
#2251169
02/10/17 06:07 PM
02/10/17 06:07 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
You better get cracking, this will be the first March Meets I participate in after just watching for over 30 years. I've never gotten to do Ron's BBQ, that's what I'm looking forward to most! What ever you get from the black Valiant with be good, that car has nice parts. I'm not 100% sure which direction Chris is going with it but I think there may be an aluminum block in that cars future BBQ is friday night again..... And headers will be BBQ black by sunday hopefully.......
[Re: moparx]
#2254152
02/15/17 06:49 PM
02/15/17 06:49 PM
ProSport
Akron, Ohio
Looks good! My next project will have those V-band clamps, not sure what I'm doing wrong with my Walker band clamps but they keep crimping my pipes even when I oil them. do you have a pic on how the crimp looks ? Here's one....
[Re: ProSport]
#2254481
02/16/17 11:21 AM
02/16/17 11:21 AM
Posts: 19,687 north of coder
moparx
Looks good! My next project will have those V-band clamps, not sure what I'm doing wrong with my Walker band clamps but they keep crimping my pipes even when I oil them. do you have a pic on how the crimp looks ? Here's one.... wow ! i thought those band clamps were supposed to keep the pipes round for easy disassembly ? i was hoping to use those types next time instead of having to weld up every joint for v-band ones. or maybe i'll do like i did once for some tail pipes. i cut a slit about 1 1/2" long in the pipe using the thickest cutoff wheel i could find. i think it was 3/16" or maybe 1/4". then i welded two strips of 5/6"x ?? thick [i forget] on either side of the slit with two 5/16" holes in one, and 5/16-18 threads in the other. slid the pipes on and tightened the bolts. that worked good and no leaks. when it came time to remove, loosened the bolts and the joint came apart with a little effort, but the pipe[s] remained round. now i wonder if those band clamps are even worth it ?
[Re: mikeysmopars]
#2254526
02/16/17 01:01 PM
02/16/17 01:01 PM
ProSport
Akron, Ohio
I think I'm doing something wrong with the band clamps but I've tried Summit brand and Walker, both crimp the pipes and cause a leak. Those V-bands look like the ticket.
[Re: ProSport]
#2256409
02/20/17 02:38 AM
02/20/17 02:38 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Here they are after getting them coated and installed. As long as they are they go in pretty easy. They sound great and was going to TNT this weekend at Famoso but stormageddin rolled through and got cancelled. Have to wait to see how they work.
Founder and CEO of the Central Valley Mopar Drag Pack
