Re: Lash caps stuck
[Re: MR_P_BODY]
#224996
02/15/09 12:30 PM
02/15/09 12:30 PM
Posts: 3,695 nc
emarine01
nc
Hey all , thanks for all the input , we got the caps off, with some major heat , I think when we were messing with cam lash we went too much on the intake clearance +.015 too see how the engine changed with different cam timing, made 2 passes and must have beat the caps in, something to think about for the next time , will order new caps & locks and have at it again, THANKS!!
Re: Lash caps stuck
[Re: emarine01]
#224998
02/15/09 12:49 PM
02/15/09 12:49 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I would have pulled the heads off before I put torch? near my valves and springs.......but, I've been accused of overcomplicating things. If you used a torch, I'd be concerned about ruining the valve springs in particular.
