Re: Under car rearend Video [Re: WHITEDART] #2248552
02/06/17 03:57 PM
02/06/17 03:57 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Snowflakes.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Under car rearend Video [Re: WHITEDART] #2248554
02/06/17 04:00 PM
02/06/17 04:00 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
I think everyone that watches the video can tell my car is a piece of sh!t.. I never claimed to be the best or better than than anyone else... I already explained that I didn't think the shock settings were correct. But that's where I ended up that day.. to go A to B.... [/quote]
Man, where you coming from? I don't think Monte was saying anything bad (Sh!t) about your car, all he said was that the owner knows that the car was far from working good and that is why you posted the video. Before you start pounding the keys on your keyboard, sit down and try to comprehend what people are trying to tell you.
Monte was trying to help.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Under car rearend Video [Re: Monte_Smith] #2248567
02/06/17 04:12 PM
02/06/17 04:12 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Originally Posted By Monte_Smith
Nobody said anything about your car being that. But you have posted several questions here, as well as putting up this video. Only trying to help you, based on what I see. If you would rather not have any more comments from me........I will gladly bow out, just say the word.
Trying to make a small tire leaf car 60ft hard is a tough job. You are doing fine, but there is definitely more there. In case you haven't noticed, I don't sugar coat things......LOL!!! Ask me what I see or think and I will tell you. I would rather hear things straight and that's the way I tend to give it. Some are not like that and I understand that as well. We are grown men, should be able to have a conversation and not take it personally..........because it's NOT personal. You don't know me, I don't know you.
I didn't realize you were trying to help.🖒.. reading from your post and others here on this site have been a great help... thanks I'm going to make the move to the 275 Pro at the next race.
I'm sure I will have many questions for you concerning that... I see a lot of the guys try to make the change at our local tracks.. and they are not successful.. I feel there may be a slight advantage to the tire and I want to make it work.
I will probably a bunch of questions soon
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Under car rearend Video [Re: WHITEDART] #2248575
02/06/17 04:23 PM
02/06/17 04:23 PM
The bias ply tires are way easier to hook on a bad track, not so with the same size radial work That was why I carried both in my car trailer, use what works best that day up
We don't race for second place, do we work whistling
DUDE, your doing good bow Don't quit or get mad, keep getting faster to make it harder for all the other racers to beat you wrench devil up
Re: Under car rearend Video [Re: Cab_Burge] #2248589
02/06/17 04:51 PM
02/06/17 04:51 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
WD...
Here's some that's solid...
Re: Under car rearend Video [Re: WHITEDART] #2248611
02/06/17 05:36 PM
02/06/17 05:36 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Your definitely moving in the right direction, I am sure you will keep picking away at it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Under car rearend Video [Re: WHITEDART] #2248668
02/06/17 07:30 PM
02/06/17 07:30 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I ran drag radials for years, now I have bias ply on my '65 Dart, definitely was a learning curve going to the bias ply. Now when I race the husband's Challenger with radials it feels weird.
Re: Under car rearend Video [Re: WHITEDART] #2248697
02/06/17 08:46 PM
02/06/17 08:46 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Listen to the man.......(Monte is a good source of info, and when you don't listen, you find out later he was correct ...lol )
It does look like too hard of a hit. Might actually work with a radial, but is that shock good enough to keep it down ? After the hit
What shocks are those, and they have too much shaft showing , especially for a leaf spring car
....BAD A$$ STREET CAR.....
Re: Under car rearend Video [Re: n20mstr] #2248745
02/06/17 09:58 PM
02/06/17 09:58 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
lol, yup.
Re: Under car rearend Video [Re: WHITEDART] #2248800
02/06/17 11:06 PM
02/06/17 11:06 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
I think your car is bad running cal tracs and leafs watched a couple of your videos and was wondering what trans are you running since you are leaving at around 5k
Re: Under car rearend Video [Re: WHITEDART] #2248809
02/06/17 11:16 PM
02/06/17 11:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Not the big HP Or High dollar parts. But this is our's. 6.70 pass in the 1/8
https://www.youtube.com/watch?v=g89FM_2Pja0
Re: Under car rearend Video [Re: dbran451] #2248811
02/06/17 11:17 PM
02/06/17 11:17 PM
bean town ....Ca
W
W
bean town ....Ca
I run a two speed glide 3000lb..I leave the starting line between 5 and 6000 RPM depending on the track conditions..
Re: Under car rearend Video [Re: VernMotor] #2248816
02/06/17 11:27 PM
02/06/17 11:27 PM
bean town ....Ca
W
W
bean town ....Ca
Cool video it stayed hooked up the hole time...is that a tie down on the bottom of the housing?
Re: Under car rearend Video [Re: WHITEDART] #2248834
02/06/17 11:50 PM
02/06/17 11:50 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yes it is.Not sure it is the right thing to do. But did it many years ago. I don't seem to have any problems with it, But I also tie it down to the frame so the car is not bouncing up and down it the trailer. I was surprise how much my rear end moves around. seem's loose..
