Re: Under car rearend Video
[Re: WHITEDART]
#2248552
02/06/17 03:57 PM
02/06/17 03:57 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Snowflakes.
[Re: WHITEDART]
#2248554
02/06/17 04:00 PM
02/06/17 04:00 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
I think everyone that watches the video can tell my car is a piece of sh!t.. I never claimed to be the best or better than than anyone else... I already explained that I didn't think the shock settings were correct. But that's where I ended up that day.. to go A to B.... [/quote]
Man, where you coming from? I don't think Monte was saying anything bad (Sh!t) about your car, all he said was that the owner knows that the car was far from working good and that is why you posted the video. Before you start pounding the keys on your keyboard, sit down and try to comprehend what people are trying to tell you.
Monte was trying to help.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: Monte_Smith]
#2248567
02/06/17 04:12 PM
02/06/17 04:12 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Nobody said anything about your car being that. But you have posted several questions here, as well as putting up this video. Only trying to help you, based on what I see. If you would rather not have any more comments from me........I will gladly bow out, just say the word.
Trying to make a small tire leaf car 60ft hard is a tough job. You are doing fine, but there is definitely more there. In case you haven't noticed, I don't sugar coat things......LOL!!! Ask me what I see or think and I will tell you. I would rather hear things straight and that's the way I tend to give it. Some are not like that and I understand that as well. We are grown men, should be able to have a conversation and not take it personally..........because it's NOT personal. You don't know me, I don't know you. I didn't realize you were trying to help.🖒.. reading from your post and others here on this site have been a great help... thanks I'm going to make the move to the 275 Pro at the next race. I'm sure I will have many questions for you concerning that... I see a lot of the guys try to make the change at our local tracks.. and they are not successful.. I feel there may be a slight advantage to the tire and I want to make it work. I will probably a bunch of questions soon
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Cab_Burge]
#2248589
02/06/17 04:51 PM
02/06/17 04:51 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
WD... Here's some that's solid...
[Re: WHITEDART]
#2248611
02/06/17 05:36 PM
02/06/17 05:36 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Your definitely moving in the right direction, I am sure you will keep picking away at it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: WHITEDART]
#2248697
02/06/17 08:46 PM
02/06/17 08:46 PM
Posts: 4,699 On the parachute mount
n20mstr
Listen to the man.......(Monte is a good source of info, and when you don't listen, you find out later he was correct ...lol )
It does look like too hard of a hit. Might actually work with a radial, but is that shock good enough to keep it down ? After the hit
What shocks are those, and they have too much shaft showing , especially for a leaf spring car
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2248745
02/06/17 09:58 PM
02/06/17 09:58 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Listen to the man.......(Monte is a good source of info, and when you don't listen, you find out later he was correct ...lol ) lol, yup.
[Re: dbran451]
#2248811
02/06/17 11:17 PM
02/06/17 11:17 PM
WHITEDART
bean town ....Ca
I think your car is bad running cal tracs and leafs watched a couple of your videos and was wondering what trans are you running since you are leaving at around 5k I run a two speed glide 3000lb..I leave the starting line between 5 and 6000 RPM depending on the track conditions..
[Re: VernMotor]
#2248816
02/06/17 11:27 PM
02/06/17 11:27 PM
WHITEDART
bean town ....Ca
Cool video it stayed hooked up the hole time...is that a tie down on the bottom of the housing?
