Re: 20 inch springs or longer?
[Re: Jeremiah]
#2250175
02/09/17 03:48 AM
02/09/17 03:48 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I see, thanks for the info. I'm thinking of trying a longer front segment to move the tire away from the wheel arch a little. Looks like a call to Calvert is in order.
I'll assume a 4" longer spring won't move the wheel back 4". Thoughts? Yes if you use the factory mounts it will move it back approximately four inches.
Brett Miller W9 cnc'd heads STR Chassis fabraction
