Re: Caltac set up
[Re: Stanton]
#2248957
02/07/17 03:46 AM
02/07/17 03:46 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
NO, I meant UPWARD ... as in if it goes over a speed bump its got nowhere to go. HA well that's just crazy talk.. LOL Ya didn't think about that did I..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Caltac set up
[Re: scottb]
#2249036
02/07/17 12:38 PM
02/07/17 12:38 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Gazzard Bros offer angled sliders.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Caltac set up
[Re: justinp61]
#2249116
02/07/17 02:59 PM
02/07/17 02:59 PM
1967dartgt
Hilltown Pa
Gazzard Bros offer angled sliders. What's the advantage? Moves in the natural arc of the leaf spring. Supposed to be less drag.
Re: Caltac set up
[Re: Thumperdart]
#2249118
02/07/17 03:02 PM
02/07/17 03:02 PM
1967dartgt
Hilltown Pa
Hemi itis your Calvert sliders look identical to my speedway ones, packaging and everything. My car at rest the spring sits all the way back in the slider, I have hit the front of the slider before when I have had to pedal the car... it makes a hell of a noise That don't sound right at all no matter HOW fast you are........... Just means his shock isn't stiff enough to control it.
Re: Caltac set up
[Re: hemi-itis]
#2249256
02/07/17 07:29 PM
02/07/17 07:29 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Looking at the arc of the spring I would guess that it's hanging ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Gus Car is on the life with axel hanging.They will NEVER go this far foward! I put them in the middle and the witness marks show they never get too close to the front or the rear.If I were to do it again,,,I would buy the Calvert sliders! It also lowered the body about nches2 inches. ..I think you're going to have a problem with it that far forward..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Caltac set up
[Re: WHITEDART]
#2249337
02/07/17 09:55 PM
02/07/17 09:55 PM
Triple Threat
Renton Washington
Looking at the arc of the spring I would guess that it's hanging ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Gus Car is on the life with axel hanging.They will NEVER go this far foward! I put them in the middle and the witness marks show they never get too close to the front or the rear.If I were to do it again,,,I would buy the Calvert sliders! It also lowered the body about nches2 inches. ..I think you're going to have a problem with it that far forward.. I think so too. I ran sliders for the last 3 years. I've never seen any that far forward even with the suspension hanging.
Re: Caltac set up
[Re: scottb]
#2249428
02/08/17 12:06 AM
02/08/17 12:06 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I will get under the car again and triple check. I keep the shocks pretty tight and I don't think I'm hitting.But we'll see.Thanks guys!
Re: Caltac set up
[Re: SpareParts]
#2249429
02/08/17 12:10 AM
02/08/17 12:10 AM
hemi-itis
Hemi itis your Calvert sliders look identical to my speedway ones, packaging and everything. My car at rest the spring sits all the way back in the slider, I have hit the front of the slider before when I have had to pedal the car... it makes a hell of a noise That is alot of movement,what rear shocks are you using??
Re: Caltac set up
[Re: hemi-itis]
#2249482
02/08/17 01:37 AM
02/08/17 01:37 AM
WHITEDART
bean town ....Ca
Hemi itis your Calvert sliders look identical to my speedway ones, packaging and everything. My car at rest the spring sits all the way back in the slider, I have hit the front of the slider before when I have had to pedal the car... it makes a hell of a noise That is alot of movement,what rear shocks are you using?? I'm going to say it's more of bowling the rear spring..then shock control.. as the rearing end rotates it pulls the rear spring forward... you might be okay but it will be close that's why most guys put it further back... I would say put white grease on the track where the rollers roll take it out and test it. .🖒
Re: Caltac set up
[Re: scottb]
#2249486
02/08/17 01:42 AM
02/08/17 01:42 AM
hemi-itis
Will do that in the spring.For now I will get another look next time I'm at the garage.
