Page 2 of 3 1 2 3
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: DaytonaTurbo] #2246412
02/03/17 10:24 AM
02/03/17 10:24 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
Originally Posted By DaytonaTurbo
Magnum engine from 1992-95 are OBD-1 and used a hydraulic 4sp transmission with converter lockup and overdrive toggled on/off with a simple 12v circuit operated by the ECU.
96+ went to a fully electronic transmission and OBD-2 at the same time. For this reason neither the electronics or transmission will swap between 92-95 and 96+.
The BEST thing you could do is swap a 92 dakota engine wiring harness into your 91, and hope and pray the connector at the dash stayed the same. Alternatively you could swap out all the wiring(dash board, lighting, etc) if you wanted to avoid rewiring stuff.
I used a 1995 harness/ecu for my swap, I found the engine wiring harness section is remarkably self-contained once you gut out the lighting, abs, etc. All that's left to hook up is a power, ground and a keyed power. You will need a speed sensor hooked up or you will stall on decel.
The early magnums will want around 35psi of fuel pressure. The TBI's were more like 14 and the 96+ units went to 55 I think. Oblivious to this fact, I first installed a 55psi GM LS-1 fuel pressure regulator/filter because they are easy to retrofit to just about anything. It ran, but rich so I put smaller injectors on to compensate.
The OBD-1 computer doesn't care what transmission you put behind it, so long as its hydraulic. If you put a 3sp behind it, you may get a code for overdrive and lockup circuits open, however it won't affect driveability. I have a stick shift so I found a stick shift ECU for mine so this isn't an issue for me either way. If memory serves, the OBD-1 magnum ecu does have a circuit that tells the ECU if you're in gear or not, however I'm not sure what the function of this is, perhaps to cancel cruise control if you nudge the shifter into neutral?
You will have to transfer over your LA sensors for your dash gauges to work. Also I wouldn't expect the a/c connections to be the same but not sure on that as I don't have a/c in my swap.
So I have a chance to buy a 2001 5.2 with 27k miles on it that was in a fire and melted all the electronic connectors. If I bought that motor could I not just swap the sensors, distributor and the TBI (with drilling the magnum heads for LA intake) and have the current system run the engine?
What would be the absolutely easiest thing to do to make that engine work in a 91 dakota?
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2246980
02/04/17 01:55 AM
02/04/17 01:55 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
BUMP
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2247006
02/04/17 02:23 AM
02/04/17 02:23 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe you can just swap over the stuff from the 91 motor onto the Magnum 5.2 and it should run. The intake will be the biggest problem. Gene
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: poorboy] #2247083
02/04/17 10:36 AM
02/04/17 10:36 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
What about the engine mounts? I've heard a lot of conflicting stuff about it.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2247123
02/04/17 12:32 PM
02/04/17 12:32 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted By jerseybud
2. Luckily dodge kept the motor mount ears cast into the block all the way thru 2000 on the 318 and 2003 on the 5.9. Just need the brackets which you should already have on your LA
jerseybud nailed it. Our '93 Ramcharger has a '97 318 replacing the original, no mount modification required. The later mounts are just along for the ride.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2248606
02/06/17 05:28 PM
02/06/17 05:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes, you could.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2248943
02/07/17 03:04 AM
02/07/17 03:04 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I have a 5.2 sitting at my house if you want to pull the intake and what wiring is left on it the motor was pulled from a 94 jeep just pm me you can have it i was saving it for a spare for my truck. I live in south stafford
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2251470
02/11/17 06:51 AM
02/11/17 06:51 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
Well, I got a 2001 5.2 from a Dakota with 27k miles on it. I'm hoping I can just swap everything over from the LA 318 onto it and be rolling.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: mopwrd340] #2251471
02/11/17 07:01 AM
02/11/17 07:01 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
I appreciate that, if something comes up I will def take you up on that. Right now I think I have everything I need to do the job.
My worries are motor mount issues (since this engine is a 2001) Someone said "up to 2000" they kept the block casting the same as far a motor mounts. Hopefully that isn't going to be an issue.
I'm going to try to make an adapter for the LA intake bolts so I don't have to re-drill the magnum heads. I've read you can drill the intake manifold and make an angled spacer to let the bolts run strait down.
One other thing I wondered if it's possible to just swap the TBI assembly onto the magnum intake... I haven't looked at it that closely but I just wonder if there is some way to make an adapter or something to just use the Keg intake with the 91 TBI.... Obviously you would have to block off the injector holes.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2251490
02/11/17 10:35 AM
02/11/17 10:35 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
What trans am I looking for if I decide to do the transmission? 42RH? The engine I'm using is a 2001 Magnum 5.2 but I'm running it off the 91 TBI computer and TBI...
So I could use any v8 trans from like 89-95 when things stayed OBDI?
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2251491
02/11/17 10:36 AM
02/11/17 10:36 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
I would like to keep a trans with overdrive and a lockup converter if possible for gas mileage.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2251509
02/11/17 11:47 AM
02/11/17 11:47 AM
Manitoba, Canada
Manitoba, Canada
You'll be looking for a 95 or older 42RH or 46RH.
You don't want to put the TBI on the magnum intake. The magnum intake is designed for dry flow only and putting a TBI on top will give you an engine that runs like a bag of crap. You could put a propane mixer on there, because it's a gaseous fuel.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2252037
02/12/17 02:25 AM
02/12/17 02:25 AM
ky.
K
kenworth_goose Offline
K
ky.
I have a 2001 5.9 and it still has the old style mounts on the block. It also has the newer style mounts on the block.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: kenworth_goose] #2252096
02/12/17 07:38 AM
02/12/17 07:38 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
This is a 5.2. Hopefully it does not matter.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: DaytonaTurbo] #2252097
02/12/17 07:44 AM
02/12/17 07:44 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
Is there anything I should keep from the Magnum setup? What sensor feedbacks does the TBI setup work off of? RPM, Coolant Temp, IAT, TPS?
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: DaytonaTurbo] #2252098
02/12/17 07:59 AM
02/12/17 07:59 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
What about aftermarket intakes? Any real benefit to putting something like the AirGap on there and fitting the TBI to it? Does an adapter to do this exist?
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: DaytonaTurbo] #2252100
02/12/17 08:14 AM
02/12/17 08:14 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
What trans is in there now? The 42rh or 46rh?
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2253028
02/13/17 05:09 PM
02/13/17 05:09 PM
Manitoba, Canada
Manitoba, Canada
I think your dakota would have the 42RH.
I haven't tried it so I couldn't say. I would think you would still be flow limited by the TBI throttle body but I don't know what that flow is.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2253927
02/15/17 06:03 AM
02/15/17 06:03 AM
Stafford, VA
O
ojcool Offline OP
ojcool  Offline OP
O
Stafford, VA
Is there any reason I cannot leave the Magnum flex plate on there instead of switching to the LA plate? I want to leave the crack position sensor in place in case I decide to get rid of the TBI setup and convert to MPI.
Re: 1991 Dakota 5.2 2wd Magnum Swap [Re: ojcool] #2254799
02/16/17 11:22 PM
02/16/17 11:22 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
You can leave the Magnum flex plate, and depending on what transmission you're using....you may have to oval out one bolt hole where the torque converter bolts up. I think this is the case of you are using a 904 or 727. A 5.2 flex plate will not have weights welded to it, and a 5.9 flex plate will. The weights for Magnum 5.9's are on the flex plate instead of the converter like LA 360's. You use a neutral balance converter with either a 5.2 or 5.9 Magnum.
Page 2 of 3 1 2 3
